Mice got me!
/ Mice got me! #21
I wished I could use that solution. I’ve tried many times but coyotes and owls get them all.
Yeah the cats I've had would also decimate the snake population. I dislike snakes more than mice.
/ Mice got me! #22
I've had all sorts of barn cats. Hawks, coyotes or owls - cats go by the wayside. Now I have a little coyote that comes thru the yard - daily. I give the coyote treats - apples, old ham bones, rice - etc.
I have NO chipmunks nor mice any more. This will all work well until it attracts the skunks.
/ Mice got me! #23
Just repaired a broken hydraulic remote cable behind side console. Damn things chewed the plastic cover off the cable!
/ Mice got me! #27
Seems like mice and anger towards them has gotten much worse in recent years. Soy based insulation on wiring?
Like all rodents, mice populations oscillate between boom and bust levels. They must be at a high population plateau now.
/ Mice got me! #28
I've found this stuff works pretty good if your trying to minimize rodents getting into a older pole barn or garage, or use steel wool, but ive also experienced mice chewing right thru the rubber threshold on the overhead door. Ive bought tomcat by the bucket, and have put the corpses around the areas where they like to infiltrate. I do agree some years are worse than others with rodent numbers.
/ Mice got me! #29
I buy a bucket of Tom cat every year and keep the bait stations full. I don’t see many mice anymore.
/ Mice got me! #30
Yep it seems like when I think I've got the problem under control I relax baiting and they are back. Sometimes worse than others The scent of dead mice also is supposed to keep them away so I leave some of the corpses around the perimeter. I can say for certain dryer sheets don't work neither does a bar of Irish spring and most ultrasonic plugins I've tried.
VAC PUMP MUFFLERS QTY 5 (A60736)
VAC PUMP MUFFLERS...
WANCO LIGHT TOWER (A60736)
WANCO LIGHT TOWER...
TOYOTA FORKLIFT (INOPERABLE) (A60736)
TOYOTA FORKLIFT...
2019 Case IH True-Tandem 335VT (A60462)
2019 Case IH...
(1) Blackstone-OTR 39x15-22.5 Foam Filled Tire w/ Rim (A60463)
(1) Blackstone-OTR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
