1845 problem
/ 1845 problem
And the problem was?
The wiring harness I got off ebay ended up being the problem. The 2 wires that go onto the alternator came with the terminal ends already on them. one was a ring connector and the other was a slide on connector which was the way the old harness was , well the connectors on the ends should have been the opposite of what they were, changed the ends and put on alternator and it has not tripped the circuit breaker since then and I used it mowing for over 30 minutes so I think everything is good. don't know if it was made late friday afternoon or if some applications might use a different setup. Thanks to all for suggestions as what to look for
/ 1845 problem #53
@ernemats I'm glad that it is working for you now! Congratulations on fixing it.
Out of curiosity, why did you need an eBay engine harness to begin with?
All the best,
Peter
/ 1845 problem
All the best,
Peter
The old wiring harness was nothing but bare wires, I don't know if the mice chewed all covering off or if just old age deuteriation but none of the wires had any covering on them.
/ 1845 problem #55
Wow! That will do it.
I'm glad that it is fixed.
All the best, Peter
2015 Ram 1500 4x4 Crew Cab Pickup Truck (A59230)
2015 Ram 1500 4x4...
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
24in Digging Tooth Bucket Excavator Attachment (A60352)
24in Digging Tooth...
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
2016 Ford Explorer AWD XLT SUV (A59231)
2016 Ford Explorer...
2016 Case Magnum 310 (A60462)
2016 Case Magnum...
