Wood working clamps
/ Wood working clamps #1
tstex
Alleyton, Texas; Houston, TX
1997 Kubota M5400S
Are any of these type of clamps worthwhile investing in for holding 3/4” & 1” boards? Thank you very much.
/ Wood working clamps #2
What are you trying to hold? That looks like a gimmick IMO.
/ Wood working clamps #4
On second look, the clamping force is by some chinsey springs. 4570's gimmick is my opinion also.
/ Wood working clamps #5
I think that thing is a “jig” and meant to hold pieces in place while real clamps or nails are used to fasten.
/ Wood working clamps #6
My advice is to stick with clamp models which have been in production for years, and buy them from known and reputable manufacturers.
When I was younger, I bought all different kinds of low cost clamps from a bunch of screwball manufacturers. Most of them didn’t work well.
I started to make more money and have more discretionary money. I started buying known styles of clamps from known manufacturers. They work, and are easy to use. The ones I had been buying werent inexpensive. They were cheap, as in ”of poor quality and utility, thus low in cost”. And, in the end I spent far more money, because I have replaced all of them
It bothers me a bit when folks use cheap to mean inexpensive, so that now folks think they are synonyms. Cheap, means, “of poor quality, and utility, thus low in cost”.
/ Wood working clamps #7
I think they are supposed to be clamps, and a mechanically sterile set dresser, or photographer, stuck them together rotated 180-degrees from how they would need to be set up to actually work.
/ Wood working clamps #8
yes advertised as clamps and 180 degrees turned. But description also alludes to holding for screwing, nailing. They do not apply enough pressure to make a good glue joint even though they might be advertised that way too.
so reality is they might work as jigs…..
/ Wood working clamps #9
I would think you are right.
/ Wood working clamps #10
It would be easy to make some clamps like those shown and use a ratchet strap.
The picture shown has an incorrect orientation.
/ Wood working clamps #12
If you're doing picture frames, your cuts need to be very accurate and I would suggest an endless loop ratchet strap with standoffs at each corner. I've not found any of the clamps intended for 90* clamping to be very good, they can't apply the pressure needed by the glue and the angle always seems to need shims to make the proper angle.
3T, do or someone else have a recommendation on a ratchet strap w the standoffs' [90's] that work well?
What are you trying to hold? That looks like a gimmick IMO.View attachment 735910
4570, should have started this woodworking earlier, maybe could have just come over to your place and outsourced everything. you have quite a collection of clamps there. We just moved from Franklin TN back Hou Tx...really a beautiful state w all 4 seasons...Middle Tn is really nice.
I'm in the process of trying to design a coffee table w about a 5ft L, 18-22" W and 24" H. I have no clamps right now, but would like to have two 5 Ft Clamps that can ratchet down to 2 ft. Is there such an animal or do 5ft [or the larger clamps] go to only a certain size, and if you need to go to 2 ft, you just use a smaller clamp? thank you
PS / including a bery crude drawing of the “coffee table” I would like to build. The top L & R will have 2 mounted animals & the bottom a stereo and a few other things, thx again
/ Wood working clamps #15
Either pipe clamps or bar clamps are infinitely adjustable. A 5 foot long one will go all the way down to nothing. It’s kinda aggregating to use a long clamp for short clamp work though.
/ Wood working clamps #16
When I was learning boatbuilding the old boys had more clamps than I'd ever dreamed existed. As they explained it, the problem with most clamps is that they stay the same while the wood relaxes, making it hard to keep pressure on a joint.
Also, a lot of assemblies were rounded or scarfed - think of a 30 foot wooden mast made up of boards and blocks - but it is hard to clamp onto a rounded piece without sliding off.
They solved both problems by using three to ten foot lengths of 1" wide rubber strips cut out of old inner tubes, of which we had a barrel full. To use them they were wound multiple times around a joint. Keeping a little tension as you go, and with the final end tucked under a previous wind. Each turn adds more pressure. You would be amazed at how much final pressure is on that joint.
Another advantage was that laminations get slathered in glue which gets all over everything. But hardened glue would just pop right off the rubber strips when we unwound them.
rScotty
/ Wood working clamps #17
I have never bothered with shop bought clamps I just make a board and wedges as required I have several different sizes put away now that will do most things if I add a packer if not easy to make another set below is not an actual job I just chucked a few offcuts in to demonstrate the principle
/ Wood working clamps #18
Here's something from Amazon that would work for an endless strap:
Endless Strap
As for the standoffs, I only use them for picture frames and you can make them yourself, it's just a block of wood (can be square or round) with a hole in the center and a quarter of it cut out centered on the hole so it's not pressing on the glue seam. You'd round over any corner of the blocks the strap crosses so the strap isn't cut. For your coffee table I would use bar clamps instead of the endless strap, although you could use either.
Since you are moving to the Houston Texas area, check out the Rockler store at 3265 Southwest Fwy, Houston, TX 77027. They should have everything you need and should be able to help you with any projects. Since it is a specialty store the products will be more expensive, but stop in and check them out.
/ Wood working clamps #19
I agree with the bar and pipe clamps. With the pipe clamps you buy the end pieces, then go to the big box store for a pipe of whatever length you need. (I have ones from 2' up to 10' - length of pipe is the only limit and pipe sections can be connected together) Jest keep in mind the weight of the pipe and the twisting action and weight of the tail of the clamp. Also, the longer the clamp the more it will flex which may or may not affect your clamping - (usually not) the end pads contacting your wood will rotate some and you won't have even pressure on the pads and you could end up with indents. The way around that is to use a small block of wood between your work and the clamp pad.
Note: the wedges in post #17 work really really well, especially for flat pieces. For furniture, you'll still need clamps. There are specialty clamps for all kinds of things as well.
Thank you. very creative...if you are using really expensive wood or wood that already has a finished surface, how do you prevent from scratching the surface? Have you ever tried gluing felt or something else to the straight edge of the wedge?
Lift cylinder for model 48 john deere loader
Lift cylinder for...
2010 Rhodes AS3575-3 35ft. 75yd. Tri-Axle Aluminum End Dump Trailer (A64556)
2010 Rhodes...
20 Yard Roll Off Dumpster (A65579)
20 Yard Roll Off...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2007 DRAGON 150...
3pt Hitch Receiver  (A62679)
3pt Hitch Receiver...
2013 Chevrolet Silverado 1500 (A64194)
2013 Chevrolet...
