Wood working clamps
   / Wood working clamps #1
tstex
Platinum Member
Alleyton, Texas; Houston, TX
1997 Kubota M5400S
Are any of these type of clamps worthwhile investing in for holding 3/4” & 1” boards? Thank you very much.
   / Wood working clamps #2
What are you trying to hold? That looks like a gimmick IMO.
   / Wood working clamps #4
On second look, the clamping force is by some chinsey springs. 4570's gimmick is my opinion also.
   / Wood working clamps #5
I think that thing is a “jig” and meant to hold pieces in place while real clamps or nails are used to fasten.
   / Wood working clamps #6
My advice is to stick with clamp models which have been in production for years, and buy them from known and reputable manufacturers.
When I was younger, I bought all different kinds of low cost clamps from a bunch of screwball manufacturers. Most of them didn’t work well.
I started to make more money and have more discretionary money. I started buying known styles of clamps from known manufacturers. They work, and are easy to use. The ones I had been buying werent inexpensive. They were cheap, as in ”of poor quality and utility, thus low in cost”. And, in the end I spent far more money, because I have replaced all of them
It bothers me a bit when folks use cheap to mean inexpensive, so that now folks think they are synonyms. Cheap, means, “of poor quality, and utility, thus low in cost”.
   / Wood working clamps #7
I think they are supposed to be clamps, and a mechanically sterile set dresser, or photographer, stuck them together rotated 180-degrees from how they would need to be set up to actually work.
   / Wood working clamps #8
yes advertised as clamps and 180 degrees turned. But description also alludes to holding for screwing, nailing. They do not apply enough pressure to make a good glue joint even though they might be advertised that way too.
so reality is they might work as jigs…..
   / Wood working clamps #9
I would think you are right.
   / Wood working clamps #10
It would be easy to make some clamps like those shown and use a ratchet strap.
The picture shown has an incorrect orientation.
2017 Chevrolet Silverado 1500 (A52377)
2017 Chevrolet...
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
2015 GMC SIERRA 2500 SERVICE TRUCK (A52576)
2015 GMC SIERRA...
LMC G300JD LOT NUMBER 245 (A53084)
LMC G300JD LOT...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
8ft Perforated Metal (A51573)
8ft Perforated...
