Steering wheel knob placement
/ Steering wheel knob placement #41
Thumb breaker, wrist breaker, all the same. Mine is still at the store where it will remain until someone else takes it home.
Those attributes apply only to old manual steering vehicles, and maybe some power assist steering but not to hydraulic steering. Even my old Ford 1715, which is approaching 30 years, has hydraulic steering, there is no danger of steering wheel kick back.
/ Steering wheel knob placement #42
I recall them being called "suicide knobs".
That's what I remember.
A bit of trivia - Does anyone remember that Sammy Davis Jr lost his eye in a wreck when he hit the suicide knob. The Candy Man can..........
gg
/ Steering wheel knob placement #43
Once something gets a bad rap it's difficult to shake. To each his own but nowadays around here you get laughed at with a steering wheel knob.
/ Steering wheel knob placement #45
In a car or pickup it would look strange these days, but is perfectly acceptable on a piece of equipment, especially if one hand is operating the loader joystick.
/ Steering wheel knob placement #46
The Versahandler comes from the factory with a spinner made into the steering wheel: (y)
If anyone laughed at it, I would say "try it you will like it".
/ Steering wheel knob placement #47
I think it's just a matter of what feels right, I like mine closer to the 4 o'clock position.
/ Steering wheel knob placement #48
I have one on my little Power Trac. Since it's articulated hydraulic steering, the knob changes position throughout the day. It's never in the same place when I straighten out.
They used to call them necker's knobs around here; you could keep one hand on the wheel while you were groping your significant other sitting next to you on the bench seat. :sneaky:
I miss bench seats.
/ Steering wheel knob placement #49
On the plus side, TSC sells them in multiple colors. The JD green one matches my PT425 pretty well...
/ Steering wheel knob placement #50
I like that built in spinner.
Mine is bolt-on and sometimes the hardware that holds it on, hits my free hand and draws blood.
/ Steering wheel knob placement #51
The higher quality spinners don't have any exposed metal
/ Steering wheel knob placement #52
Not sure about other states,last I knew in NH knob on the steering wheel won't pass inspection.
/ Steering wheel knob placement #58
Well that would require me to open my wallet 1/8" more!
Yeah, it's about $25 but I like the no exposed metal. With my old dry thin skin all I have to do is look at a sharp edge or exposed metal and I start bleeding.
/ Steering wheel knob placement #60
The only time I ever had a steering wheel get away from me was on the narrow front end Farmall M. That could be a wristbreaker for sure!
I don't recall ever driving a tractor that didn't have one, except for my Max26xl when it was new. It wasn't long till I put one on it and I wouldn't want to go without one. Just makes the easy steering even easier in tight spots or constant back and forth directional jobs. Mine was mounted at about 10 o'clock but hasn't bothered me enough as it moves around to consider a 2nd one. Got mine from Tractor Supply. Its one of those cheap, easy add ons that I would recommend to anyone.
2024 Ford Explorer AWD SUV (A61574)
2024 Ford Explorer...
LMC Ag 400 Gal Front Mounted Tank (A64119)
LMC Ag 400 Gal...
Caterpillar Hydraulic Control Manuals (A63117)
Caterpillar...
Mini Skid 6 Way Blade (A56438)
Mini Skid 6 Way...
2005 INGERSOLL-RAND SD-116F TF  ROLLER (A59911)
2005...
Caterpillar 12H/140H/160H Motor Grader Parts and Service Manuals (A63117)
Caterpillar...
