Bolt On Forks
/ Bolt On Forks #1
marq
Member
Romeo MI
03 JD 2210
This summer will be building a garage, after the small accessory building I built 3 years ago it would have really been nice to have forks for my compact tractor.
Not looking to move heavy stuff, just move sheets of plywood, trusses, stacks of wood around, lift up shingles.
I see lots of ads for $100+ bolt on forks, do they function or just a waste of money? Is the extra for a quick change attachment for bucket just a better option?
Not sure I would have much use for them post building construction.
/ Bolt On Forks #2
They can bend buckets and don't lift near what they will when properly mounted. If you aren't familiar with leverage,try this. Lift and object with a 6"stick griped in your hand. Lift same object with 12" stick and notice additional stress to palm. The bucket between arms and forks cause's needless stress and limit's weight loader can lift. If you have one of the quick attach systems,by all means buy forks desighned for it. It isn't difficult to build a plate for ataching forks if you can weld.
/ Bolt On Forks #3
Many threads on this....here's one
/ Bolt On Forks #4
You'll get more search results with "clamp on forks" as they are commonly called.
/ Bolt On Forks #5
If you’re careful they are handy. If you have a teenager driving the tractor, they tend to rip the bucket off when they accidentally contact the ground
/ Bolt On Forks #6
I built a small 'pallet fork' thing out of a conveniently u-shaped c-channel assembly I picked up for free. I added factory tow hooks from a Jeep SUV to make it hang off a 3pt hitch frame i already had. Then i found out i could kinda hang it off a bucket, but it seemed like a bad idea. Well, i did it anyway, and over time of lifting heavier and heavier things i found out that as long as the load is near the base it will pick up near 1000lbs. I used it last weekend to unload a 700lb backhoe attachment off my buddy's trailer. I actually think most of the cheap clamp-on forks out there are still WAY better than this. So i would say, yes they have their place.
I found this video recently comparing some good and less-good ones:
/ Bolt On Forks #7
I think the chain on fork set ups are stronger. that does not take into account the overall bucket strength though.
Agree with the poster that said if you have a Quick attach buy the SS QA forks even if it costs more.
/ Bolt On Forks #8
No one has mentioned visibility. With bolt-on/clamp-on forks, you cannot see through the FEL. Some have recommended Titan forks. They have a chain wrap-around that reinforces the bucket where the forks are clamped.
I like the easy storage for clamp-on forks.
Don't have any but could have used them recently when the sales guy showed up with my box blade on a pallet in the bed of his F-150. He managed with a wrap around strap and clevis to hold it together. He removed the tail gate to get close and got my FEL right up against the box blade to wrap the strap around. He got it out with the 518# thing dangling out off the end of the FEL.
/ Bolt On Forks #9
Most people will recommend you spend the bucks for a full up set of SSQA pallet forks. But they won't send you the money.
IF you are going to want SSQA (or have SSQA) they are probably worth it. But I've made it 12 years with a pair of $120 Titan clamp ons. The only problem I've had with them was when my son left 2x4's in the uprights for a few years and I had to burn the 2x4's out.
Read the other threads.
IF you get clamp on's either build or buy a stabilizer bar so they stay straight ahead.
/ Bolt On Forks #10
As noted in many other such threads.....I'm a Clamp-On Forks Member. Has worked for me for the past 13 years and never bent a bucket on three different models of Kubota SCUT and CUT. I only repeat myself to aid the OP in this discussion. I guess one's budget and chores in the long term would be a deciding factor.
Cheers,
Mike
/ Bolt On Forks #11
I have some clamp ons I torque them down hard with a cheater bar which I noticed really helps keep them straight, when I need to be really precise with them I throttle down put it in low gear ie 1st and steer the tractor while I'm standing up in the OS. Probably not recommended but it works.
/ Bolt On Forks #12
I'm in the owner's group of clamp on forks. I don't have a need for a dedicated set of forks. Most times it is like you would be using them.... carrying building materials or the "odd job" infrequently. I have a set of the Titan 2000 lb with the stabilizer bar. The bar definitely helps to keep them straight.
My loader is rated at 1600 lbs, so they are more than strong enough for me. I have used them to lift a truck transmission out of the back of a pickup, a pallet of 15 80# bags of concrete, 40 sheets of metal roofing, plywood, 2x4's, etc....
Saving over $500 to get the clamp on vs. a dedicated SSQA helped to get more materials needed for the project.
/ Bolt On Forks #13
I have lifted 16" diameter x 10' long hardwood logs. Early on, I picked up a pair and saw the tractor grunt so I dropped one and went on. Even still, there was no damage.
Besides the cost of attachments is the cost of warehousing them. I cleared 1/2 an acre with mine. It wasn't nearly as nice as a set of grapplers or fork set but my need was temporary.
Now, I will just use them to move pallets of split wood.
/ Bolt On Forks #14
I've had bolt on forks for the bucket of my Ford 1720 tractor. The previous owner welded them up to fit the inside contour of the bucket and they bolt through the top of it. They're very solid and there's no deformities to the bucket and I've lifted many heavy objects.
/ Bolt On Forks #15
I fabricated a set of forks, to do various jobs around the property, mainly for brush work, but it also doubles as a sort of pallet forks and could be used for various lifts.... Depends on what need may be "after" construction work is done...
forks-1-jpg.686036
/ Bolt On Forks
Thank you guys, as noted, it's a special use but like everything uses/needs expand. Will look into the Titan brand!
I'm probably more limited with the fact that I no longer have any counter weight/box blade/deep ripper, were well into maintenance mode and mainly use tractor for mowing and moving wood chips.
/ Bolt On Forks #17
Oh you definitely need a counterweight! I bought a Woods BH70X backhoe to offset mine (at least that was the excuse I gave my wife :) )
/ Bolt On Forks #18
Definitely need counter weigh is and serious lifting with FEL
20190513_134020-jpg.678087
20190513_134501-jpg.678088
And no pics are not photoshoped... There is low bumper on JD (that you can not see) that wedges under lip of bucket... And JD weights in at 520 lbs. according to JD documentation
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
Cushman Hauler 800X (A64127)
Cushman Hauler...
L-Shaped Fuel Tank Hose and Electric Pump (A62679)
L-Shaped Fuel Tank...
Vermeer SC30TX Smart Sweep Stump Grinder (A62679)
Vermeer SC30TX...
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A61569)
2018 Regal 29OBX...
2000 Sterling L9513 Winch Truck (A63118)
2000 Sterling...
