New shop started
/ New shop started
I gotta go though and fix this thread at some point, damn photobucket
anyway
Got the plasma table installed today, now to learn how to program it
the test cut was an included test program
/ New shop started #383
anyway
Looks to me like you will be needing a bigger machine shop real soon.
hugs, Brandi
/ New shop started
god no
I’m done accumulating
(Maybe a Cnc router for wood shop)
But that’s it!
I promise!
/ New shop started #385
Hmmm..., maybe use the cnc plasma cutter with a RottoZip bolted to the head, all power to cutter head turned off, when you want to try wood?
/ New shop started #386
You will probably going to want to get the plasma out of there as soon as you can. Plasma smoke contains a lot of fine metal particles that does a job on machine ways and it looks like you have some nice machines in there. I am going to get one next year after I move my shop and it is going to go out on the covered porch away from the precision stuff. BTY, what is the big lathe on the right side of the picture? I need a good farm lathe that will swing 12" over the carriage.
/ New shop started
Water table seems to be doing quite well for dust, I’m pretty happy
I wipe and coat all ways prior to use or any carriage/saddle/table movement anyway ( due to years of combined wood/metal shop) so I will just keep that up
lathe is a 24(48”) swing x72” (iirc)monarch model 60
it was was an old hydraulic tracer model that had it butchered off
So not ideal for threading as compound is fixed parallel to work
Otherwise it is great machine
It is second only to my Rivett in fun
/ New shop started
I may try it sand, I have cut some wood on cnc mills for parts/projects or to minimize breakage/carnage in testing new program
will see, my cnc mills are old tech and easy to program ( polar coordinates not gcode) but less dynamic
I’m sure I will learn a great deal
(And bury the delicate torch tip in the table a bunch-I bought several extra consumables in prep)
/ New shop started #390
Wow - looks like you guys are really getting hit hard. Stay safe up there!
/ New shop started
Maybe 24?
Hard to say w the wind
Overall it has been a blast
/ New shop started #394
for us tool challenged, ok, we aren't talking about butterflies...
Image result for monarch ee
Monarch EE Series. Toolroom. Monarch's reputation for excellence is clearly reflected in the Model EE 10” Precision Toolmaker's Lathe; a tool so precise, sensitive and durable that it has become the standard to which all others are compared.
/ New shop started
Monarch is a fine machine
The Rivett 1020 was the answer to the EE and was equal in quality
I chose the Rivett as I didn’t want to deal with the Monarch drive system or retrofit
/ New shop started
Valentines gift from wife.
Should have it next week
80 hp Deutz, 3 buckets, aux hydraulics for grapple/hammer
2001, yard machine only. Bit over 900 hrs
/ New shop started
Ya, really wanted a 10-15k lb “mini” but for about 1/2 the price of a 3k hr mini, it was hard to pass up
/ New shop started #399
My twin uncles each worked for Monarch for over 40 years. Good machines.
/ New shop started #400
I ran an old Monarch in junior college, not sure what model but it was a sweet old lathe with variable speed head I think. If I remember right it had some sort of trick cross slide stop on it that I've never seen on another lathe.
I've run a Hardinge Super Precision since it was new in 1985, also a nice machine.
Hays LT1 Tender (A61307)
Hays LT1 Tender...
Zato Hydraulic Demolition Shears Excavator Attachment (A61567)
Zato Hydraulic...
2025 Heavy Duty Booster Cables (A61568)
2025 Heavy Duty...
2013 FORD F250 (A60460)
2013 FORD F250...
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
2019 GENIE GS-1930...
2004 GMC Sierra 3500 Pickup Truck (A55973)
2004 GMC Sierra...
