Can NOT get trailer lights to work
/ Can NOT get trailer lights to work #1
tstex
Alleyton, Texas; Houston, TX
1997 Kubota M5400S
Have a tandem 20ft trailer that I keep at my farm and is covered. My leasee's heifers ate off the 4 pin connector. Bought a new 4 pin connector [3M1FeMale] and spliced it onto the harness. Have a 2014 F-150 w trailer package. When I went to plug in the 4-pin connector, I first need to plug in my 7-4 pin vehicle to trailer adaptor into my truck. Well, I do recall going over a very steep [unmarked] dip in a farm road about 40 MPH, and the back end of the truck hit the ground in all the bouncing. That was 8-9 mo's ago.
So, when I went to plug in the adapter, instead of a round hole, it was oblong and the adapter would not fit. I finally was able [w force adjustments] to get the adapter into the trucks receptible, then plugged in the trailer connecter: Nothing. my truck also has a single separate receptacle that the trailer harness connector can plug into: still nothing. I unscrewed the white ground wire from the front of the trailer, took a wire brush, got fresh metal on all. Cut off the older exposed wire off the grd and got new fresh strands. Put it all back together: nothing.
Here are some questions:
  • Can perhaps a burned out light on the trailer cause a short and prevent the lights from working?
  • I inspected all the wiring on the trailer harness and didn't see anything spliced, cut or torn
  • Is there a way to test either one or both of the trucks trailer receptacles?
  • Every light and function on my truck's front, back and inside works fine. Could a burned out fuse cause the receptacle to fail?
Any questions or things for me to check out? I am all ears. I live 60 miles from ranch, but I can take pic's of my truck if needed. My trailer is remote.
The next time I am out there, I am going to ask one of my nbors to come over and see if I can plug in my trailer to his truck and see what happens. based on those results, I will know if it's my trailer. I have to move some furniture for someone and it involves a lot of turning and in Houston, so functioning lights are imperative.
/ Can NOT get trailer lights to work #2
/ Can NOT get trailer lights to work #3
Here's a couple things that come to mind. First verify if the plug on your truck is working.
Turn on parking lights and kick the emergency flashers on.
Then check each pin on there with a test light. You should have two pins that will flash, those go you brake light and flash when turn signal is on. Parking light pin should be on solid. Should also have another pin that is on for 12 volt power to charge trailer brake battery.
If they aren't working. Then it could have popped fuses.
I've had some of those 7 pin to 4 pin adapters go bad after a while as well. So you can test the 4 pin side with a test light as well.
I just had to replace the 7 pin plug on my service truck. They can be purchased at any auto parts store.
You can also upgrade your plug to a 7 pin and 4 pin as well depending on how the 7 pin mounts to your truck. They sell replacements for those as well.
Moss and Todd, really great suggestions !!!!
I'm off to get a plug tester and will see what I get and post back...what a great way to determine if it's my truck vs trailer.....thanks again
/ Can NOT get trailer lights to work #6
I guess I’m wondering why a 20 foot trailer has a 4 pin? No brakes?
The OP said tandem axle, so it's either a light weight small wheeled snowmobile hauler or perhaps it has surge brakes instead of electric.
Here's some answers:
I bought the receptacle tester and none of the lights are coming on when I turn on the lights or engage either signal. So it's my back circuitry or something else. The trailer has no built in brakes. I follow the trucks maximum load capacity w non-braking trailer
Does anyone know what the circuity is called for the back trailer lights? I'm trying to "ID" the fuse box to determine if my fuse is bad. If it's not, then I guess I will need to replace the receptacle(s), yes?
Thank you.
/ Can NOT get trailer lights to work #8
I think replacing the damaged receptacle would be one of the first things to do. There would have to be a reason for several circuits to stop working or blow a fuse, perhaps the damaged receptacle has allowed several circuits to ground out.
I think I found the problem
The wire assembly that comes from the electrical system will not stay engaged to the trailer adapter area. So none of the back receptacles were getting any power. When trying to attached that assembly, should it click in place or something?
/ Can NOT get trailer lights to work #10
That would be under 3000# for trailer and load in most if not all states.
/ Can NOT get trailer lights to work #11
It looks like to me, but I’m not any where near certain, there should be some kind of retainer or clip. I‘m looking at your second pic at about the 11 o’clock position. Sometimes there is a little red clip or some other kind of retainer.
/ Can NOT get trailer lights to work #12
you are missing the piece in the rectangle hole that clicks on to the socket. also, that ground pin is very corroded.
Thank you guys.
Herm, do you have a pic of the piece that I am missing and how it attaches?
I am assuming that the part that keeps the two bodies tightly together, when it went missing, it allowed moisture inside the receptacle and corroded some of the pins.
Does anyone know what is involved to replace the receptacle? Would a new receptacle have the new/missing piece?
Thanks again.
/ Can NOT get trailer lights to work #14
I’ve never seen the retaining clips for sale but they could be. I’ve seen several different styles so I don’t know what yours looks like. It most likely comes with the wiring harness and not the plug in socket.
Maybe a Ford dealer can sell the retainer?
/ Can NOT get trailer lights to work #17
If you haven't found the solution, check to make sure you are getting a good ground by attaching using a direct wire from the truck to the trailer frame to troubleshoot. My experience is that trailers have been sitting for while or that are rarely used sometimes do not want to ground through the hitch when just sitting on the ball.
Thanks John. I specifically removed the trailer ground, took my driller w circular wire brush and really gave the ground area a real good cleaning to the metal. Then did the same w the washers and bolt that holds in the wire. I then removed the exposed portion of wiring on the ground, removed the white insulation and exposed fresh wire, then put it all back. It's getting a good clean ground for sure.
The problem is I cannot keep the wire harness head securely attached to the trailer receptacle. Furthermore, as pointed out, the grd pin seems to be oxidized, but I cannot test it anyway as is...guess I am going to have to splice on a new harness cap and replace the receptacle. Unless someone has a better solution, I believe that is where i am...
/ Can NOT get trailer lights to work #19
/ Can NOT get trailer lights to work #20
It sounds like your trailer is 4 pin. You don’t have a 4 pin on the truck hiding under the bumper do you? Most of the trucks I’ve had in the past had both styles.
iDrive TDS-2010H...
2006 CHEVROLET 2500 SERVICE TRUCK (A63291)
2006 CHEVROLET...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
Topsoil Trommel (A57453)
Topsoil Trommel...
