snow roller for XC snow
   / snow roller for XC snow #91
Piston Bully with wide rubber tracks works excellent for packing trails the first time through . But we do snowmobile trails not cross country ski trails.
I operated a trail Bully 2 years ago with 40" something tracks. We're not getting one.
   / snow roller for XC snow #93
I Built a snow roller/packer from a 18" (I think it was 18") stainless steel thinwall pipe. I used to use it lots but haven't used it in years. Our trails are fairly bumpy and need lots of snow to make them smooth. We found out that using the roller, all of the snow would pack down and there was not enough loose fluffy snow to fill in the low spots. Our drag is fairly light and doesn't cut/shave hard snow easily. Now we drive around the trails once with two sleds and and it packs most of the trail and leaves some of the trail unpacked. When we drag it the loose snow gathers up on the drag and drops into the low spots. We get smother trails faster at the begining of the year this way. Having said all of this we dont get big 12" dumps of snow in one shot.
   / snow roller for XC snow #94
Interesting Stomper, thanks for sharing your experience. We are in the same boat here, usually not big snows and quite rough trails. Usually dragging an old chain link fence gate at the beginning for the first few snows seems to help make a base. Like you our snow is almost always light and fluffy at -20°c too….. to make a roller or not….. a small cabbed machine sure would be nice either way :).
Earlier I posted why you need X, Y and Z implements to match which conditions you might have today. (may have been in the drag thread) I'll find it and post it again.
You are not givng us much for details Stomp. Could you post pics of that roller? What sleds are you using? Seems your sleds will have higher PSI than that roller should have.
   / snow roller for XC snow #97
I will dig it out of the bush and get you a picture. You are correct in saying the sleds have a higher psi than the roller but our trails are in very bumpy and uneven country and by not packing the whole trail and leaving some of the snow unpacked, the light drag we use pulls the unpacked snow and dumps it in the low spots where it is needed. We pulled all of our groming equipment with a yamaha nytro and yamaha viper. My buddy did buy tracks for his polaris quad and that helps out alot with the grooming. We do not have a ski club for our local trails, it is myself and a buddy that do all the work and pay all the costs to keep these trails open and operating. We have a yearly operating budget of $0.00 and use our own personal equipment and time. Having heavey or expensive equipment is completly out of the question. Our equipment is what we could afford to build at the time to get the best result we could. It most likely isnt up to the standards of larger ski clubs, or probably any ski club for that matter, but over the years using it we found what works and what doesn't for our needs.
I spend more time grooming trails than I do skiing and my buddy doesn't even ski.
   / snow roller for XC snow #98
We've used the chain link fence option to. It actually works quite well. As for building a roller, I'm sure they have thier place and do what they are designed to do in the right conditions, but in our personal experiences we have found that for us, it's not worth the time or effort.
We are doiing about 3 miles of ski/snowshoe/walk/phat bike trails. I am personally paying for the construction of groomzila implement and already built and paid for the roller.
   / snow roller for XC snow #100
You sure have nice equipment for only 3 miles of trails. That’s awesome. We are doing around 7 miles.
flooring (A55758)
flooring (A55758)
2014 Ford Fusion SE Sedan (A55853)
2014 Ford Fusion...
1067 (A53342)
1067 (A53342)
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A55852)
2012 Freightliner...
2019 BOBCAT T450 SKID STEER (A52706)
2019 BOBCAT T450...
2005 COMPTANK ACID TRANSPORT TRAILER (A55745)
2005 COMPTANK ACID...
