Can anyone identify this blower?
/ Can anyone identify this blower? #1
Bob Rooks
Elite Member
Washington state
Yuchai Dozer (sold).
I saw this blower unit on CL for $25 so I jumped on it. I can't match it up to any of the known brands. I had a pressure washer cart and a 12HP Harbor Freight engine on hand so I decided to make a pull-behind leaf/debris blower. The unit has pillow bearings, four blade impeller, and a 1" shaft. It is about 30" in diameter. Any suggestions/advice is also welcome.
/ Can anyone identify this blower? #2
no clue, but very interesting. at that price it was a great deal :)
/ Can anyone identify this blower? #3
Looks like someone making a blower from old and new parts. I have a small 3 point model.
Yes, "someone" is me. That is a good looking unit you have there, but I dare say it appears much larger than mine.
Yes. A "before" picture might help some one recognize it easier.
I did take a couple of pics after I bought the blower unit, but danged if I know what happened to them. All it had was a stepped pulley on one side, and there was no evidence of any mounting points. The sides were clean except for the pillow bearing mounts, which seem to be at an odd angle too. I used hurricane bolts to mount the Unistrut, which gave me some flexibility in mounting. I don't believe this is a home made unit. Currently waiting on new pillow bearings.
/ Can anyone identify this blower? #9
It looks like you fabricated (or are fabricating) most of it yourself! Nice work.
Thank you. I just took it all apart and cleaned it up. The pillow bearings were questionable so they are being replaced as well as the 20 1/4" bolts that hold it together. Using Unistrut as a mock up to see how well/if it performs. If it goes well then I may weld it all together. Stay tuned. :D
/ Can anyone identify this blower? #11
OK being from the north, I have no idea what a "I used hurricane bolt" is. Can you explain ?
Also i would suggest that you use a coupler rather than a universal joint to connect the engine to the blower.
Something like this from Northern Tool:
Also called "sidewalk bolts". They are stainless steel with full threads and a very low profile and large (truss) head (great for using on sheet metal instead of fender washers). I used these to maximize impeller blade clearance. Sidewalk Bolts Slotted Stainless Steel Hurricane Bolts 3/8"-16 x 1" Qty 25: Amazon.com: Industrial & Scientific
Originally I thought about using a Lovejoy coupling, but neither the crankshaft or blower shaft is long enough to permit close coupling, and I needed the engine moved back anyway so the cart will balance. So I'm using a jack shaft with two U-joints. And alignment won't be that critical either.
/ Can anyone identify this blower? #13
OK thanks for that info. I never heard of them and being SS, quite pricey.
And on the use of U-joints, just remember, they don't like to run straight, they need the shafts to be offset a little.
Richard
Richard
Yep. Make those needle bearings earn their keep. :ROFLMAO:
/ Can anyone identify this blower? #15
You should always research what you are talking about before you post. For best lasting use, there must be at least some angle on the u-joints.
From Here:
An Expert Opinion, And Why Driveline Angles Matter
We know enough about driveshaft angles and transmission swaps to get ourselves into trouble, but we aren’t experts like the folks over at Silver Sport Transmission. So, we reached out and got their input about driveshaft angles. We talked to Dick McCord, vice president of engineering and operations, and got his thoughts on driveline angles for a street car setup – what can go wrong, and how to make sure your angles are within acceptable tolerances.
“If your driveshaft operating angle is too small, there will not be enough rotation of the needles in the u-joint caps and you’ll wear out your bearings due to lack of lubrication,” Dick explained. “You have to have some angle, a minimum of 1/2-degree, or the needles will brinell the surface of the u-joint, cross-bearing journal. U-joints were designed to operate at an angle, and if they don’t have an operating angle, they will wear out prematurely.”
From here:
U-Joint Angles - U-joints need a slight angle for proper lubrication. Without the correct angles, the needle bearings in the u-joint caps do not rotate. Those needle bearings need to rotate in order for the u-joint to operate reliably and smoothly. These u-joint angles should always be at least 1-degree to avoid wearing out the yoke bearings. U-joints fail at 30* degrees.
Years ago, I researched drive shafts and u-joints as I was in the process of designing a drive shaft to connect my Kawasaki Liquid cooled snowmobile engine to a water brake dynamometer.
Richard
Thank you for your concern Richard. I'm a Chief Engineer and have been doing shaft and coupling alignments for many years and am also schooled on the subject. I just thought in the interest of brevity I wouldn't go into details. My last ten-point alignment task was a 3 megawatt TEWAC alternator to a EMD 710-G diesel engine. That took a little while considering vibration isolators were involved.
I also did a water brake dyno when I was in R&D at PACCAR.
/ Can anyone identify this blower? #20
That impeller looks very primitive and I wonder if it was balanced, likely not which could explain the wear in the pillow blocks. With the square ends it must be very loud. How is the vibration in use?
2023 JCB S4550E ELECTRIC SCISSOR LIFT (A65053)
2023 JCB S4550E...
1999 FREIGHTLINER FLD70 ROLLBACK (A65643)
1999 FREIGHTLINER...
Pole / Log Dolly (A62613)
Pole / Log Dolly...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - Tier 2 - Irrigation Takeout (A63689)
Kubota V3600-T-E2...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
2004 International 7400 C&C 017797 (A62613)
2004 International...
