Can anyone identify this blower?
   / Can anyone identify this blower? #11
OK being from the north, I have no idea what a "I used hurricane bolt" is. Can you explain ?
Also i would suggest that you use a coupler rather than a universal joint to connect the engine to the blower.
Something like this from Northern Tool:
Also called "sidewalk bolts". They are stainless steel with full threads and a very low profile and large (truss) head (great for using on sheet metal instead of fender washers). I used these to maximize impeller blade clearance. Sidewalk Bolts Slotted Stainless Steel Hurricane Bolts 3/8"-16 x 1" Qty 25: Amazon.com: Industrial & Scientific
Originally I thought about using a Lovejoy coupling, but neither the crankshaft or blower shaft is long enough to permit close coupling, and I needed the engine moved back anyway so the cart will balance. So I'm using a jack shaft with two U-joints. And alignment won't be that critical either.
   / Can anyone identify this blower? #13
OK thanks for that info. I never heard of them and being SS, quite pricey.
And on the use of U-joints, just remember, they don't like to run straight, they need the shafts to be offset a little.
Richard
Richard
Yep. Make those needle bearings earn their keep. :ROFLMAO:
   / Can anyone identify this blower? #15
You should always research what you are talking about before you post. For best lasting use, there must be at least some angle on the u-joints.
From Here:
An Expert Opinion, And Why Driveline Angles Matter
We know enough about driveshaft angles and transmission swaps to get ourselves into trouble, but we aren’t experts like the folks over at Silver Sport Transmission. So, we reached out and got their input about driveshaft angles. We talked to Dick McCord, vice president of engineering and operations, and got his thoughts on driveline angles for a street car setup – what can go wrong, and how to make sure your angles are within acceptable tolerances.
“If your driveshaft operating angle is too small, there will not be enough rotation of the needles in the u-joint caps and you’ll wear out your bearings due to lack of lubrication,” Dick explained. “You have to have some angle, a minimum of 1/2-degree, or the needles will brinell the surface of the u-joint, cross-bearing journal. U-joints were designed to operate at an angle, and if they don’t have an operating angle, they will wear out prematurely.”
From here:
U-Joint Angles - U-joints need a slight angle for proper lubrication. Without the correct angles, the needle bearings in the u-joint caps do not rotate. Those needle bearings need to rotate in order for the u-joint to operate reliably and smoothly. These u-joint angles should always be at least 1-degree to avoid wearing out the yoke bearings. U-joints fail at 30* degrees.
Years ago, I researched drive shafts and u-joints as I was in the process of designing a drive shaft to connect my Kawasaki Liquid cooled snowmobile engine to a water brake dynamometer.
Richard
Thank you for your concern Richard. I'm a Chief Engineer and have been doing shaft and coupling alignments for many years and am also schooled on the subject. I just thought in the interest of brevity I wouldn't go into details. My last ten-point alignment task was a 3 megawatt TEWAC alternator to a EMD 710-G diesel engine. That took a little while considering vibration isolators were involved.
I also did a water brake dyno when I was in R&D at PACCAR.
   / Can anyone identify this blower? #20
That impeller looks very primitive and I wonder if it was balanced, likely not which could explain the wear in the pillow blocks. With the square ends it must be very loud. How is the vibration in use?
2007 MACK CV713 WINCH TRUCK (A53843)
2007 MACK CV713...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
70pc 12ft.x 3ft. White Metal Roof Panels (A53424)
70pc 12ft.x 3ft...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
