Furnace options
/ Furnace options #21
Hit the unit with a mower?!?
Who could possibly make that mistake?
MoKelly
I've got pictures, just need to find them LOL
Lots of people, particularly kids new to riding.
I'm lucky enough that the grade around my house along with some shrubs pretty much makes it pretty much impossible to nail anthing, even if I didn't have a "box" set up around the units.
Thing is, what people forget is your outdoor unit has particular clearances for air rotation which can become important if the unit is burried in "shrubs". Kind of "let's hide the outdoor unit so you can't actually see it" issue.
/ Furnace options #22
Yea - I’ve got pictures as well. Not one of my better moments!
MoKelly
/ Furnace options #23
So we are about a year out from moving onto our land. We have NG pipelines on the property, but apparently that does not mean we can get access to NG.
Gas companies do not like farm taps and will try to discourage you from getting one. I have a natural gas pipeline that crosses my property and was able to get a farm tap.
It would be worth a trip to the court house to see what the original easement says. In my case the easement from the 30's stated if they crossed your property you were entitled to a farm tap.
Don't take the word of the gas company, the real estate agent or any other backyard lawyers. See what the original document says and then go from there.
Doug in SW IA
/ Furnace options
@Sigarms. Ok, so here is a shot of our units in the city and the thermostat.
/ Furnace options #25
Maybe, but I use the flames to char peppers and similar techniques that don't work on induction. Gas also works when the power is out.
Be careful what you buy for appliances. My gas oven & range (put in in the 80's) will light with a match if the power is out. Some newer ones have a "safety" feature and require the electricity to be on.
/ Furnace options
Thanks, I have a new one we put in a few years ago. I will buy the same for the new house. Once I get what I like, I stick with it.
/ Furnace options #28
2 seperate systems? One Trane and the other looks like a Goodman?
Guess the tstat would be a communicating Trane XL1050? (Trane I don't care for per a number of reasons, but still great equipment when installed correctly)
You next system, don't buy anything "communicating" (proprietary to the manufacturer) and just get a good Honeywell, Aprialaire or Ecobee thermostat that anyone can buy. You can generally go 2 stage compressor, 2 stage gas valve with most manufacturers without getting into a communicating thermostat.
/ Furnace options
Thanks. Two systems are pretty common here. Big one for the main floor, little one for upstairs. You have a good eye. Is the Trane a variable speed? The thermostat 'came with' the Trane. The Goodman runs on its own thermostat.
/ Furnace options #30
What's funny is I didn't open the pics when responding earlier when I commented. Just surfing between downloading some documents.
Looking at the pic now, you got the TOP end line, variable speed compressor, and no doubt a variable speed constant airflow blower motor in your furnace, most likely two stage as well (if not fully modulating).
Yes, two systems can be comon here as well (but you can zone two levels with one system as well pretty good IMO if laid out right).
Thing is, you had to pay a pretty penny for that 20 SEER system. The way it's laid on the ground, you're only asking to hit it. Point being I'm surprised they didn't box it off like Ken did in his pic.
Just curious if the house came with that equipment or it was sold to you as a retrofit? For that kind of system (Trane 20 SEER), just surprised they didn't explain exactly what you were getting.
Kind of surprised by the Goodman next to it as well. Kind of like night and day per price point of install, but over time, the Goodman will be a lot cheaper to fix when it needs it ;) (although Goodman can seem to "weather" faster on their outdoor units than some others from my experience).
I believe Ken can tell you, after a while, it's pretty easy to pick out all the different manufacturers per thier outdoor units, even to the point when I see a Maratherm unit, I know it's made by Carrier LOL
Thing is, the longevity of a system has nothing to do with brand name IMO, but the person / company installing it makes all the world in the difference.
Only reason why I dislike proprietary communcation systems is sometimes the software updates from the manufacturer can be a pain in the arse fom time to time. That said, I would think you'd be very happy with that Trane system.
Not sure if it's good or bad that all my best friends work in the same industry as myself :unsure:
/ Furnace options #31
I did a complete central air install at brothers home... he was newly married and wife said no way was she living without A/C. Home only had a wall furnace.
Several local companies provided quotes and they were budget busters and all included Electrical Service Upgrade.
I told them I would spec the system and do the install as a wedding present... lots of fun in 130 degree attic.
By every bid my system was undersized... 3 vs 4 or even 5 ton.
I had 30amps to work with so bigger units out.
They lived there 17 years and thrilled with the system... Tempstar variable speed, multistage etc... neighbors liked it too as some had wind tunnels and noise or lost floor space
My question is just how much faith can be put in contractor recommendations as all specified much larger units?
17 years through week long heat waves and freezing spells seem to contradict...
/ Furnace options #32
That sounds like a great wedding present.
In my limited experience, HVAC installers seem to have lots of eyeballers, at least doing home installation. Very few seem willing to drill down and do a manual J computation. A few have left me wondering if they have ever done it. Don't get me wrong, I think it is a fair amount of work to get the correct cooling capacity close, and heat calculations have so many ways that they can be off.
So, I think that the HVAC installers tend to eyeball an oversized compressor to have enough capacity, and people freeze, and are happy with the ability to have blast freezing capabilities, not realizing the energy inefficiencies nor the issues with humidity control and lifetime reduction due to rapid cycling.
All the best,
Peter
/ Furnace options
@Sigarms . Thanks, our city place is about 25 years old. We've been here 15. Put in the Trane about 5 years ago. He explained it when we bought it. Our yard is small, there is really nothing to protect it from. Only use a cordless mower near it and no rock or anything to kick into it. It has saved us $100 a month and we keep the house at 74 in the summer. I am the miser. We used to keep it at 78 or more, wife was tired of being too hot and being of a certain age and married this long...she won. The new place will be better insulated and about 2/3 the size of this one. I would like a similar unit...I figure if you find something that works as advertised keep it. I'm sure you already know, but if others are reading this, the AC runs at a very low speed most of the time. It keeps the humidity under control and reduces the likelihood that it needs to run full blast. The old system was either off or on. The Goodman we just put in about 2 years ago. Only about 250 SF upstairs and we knew we would be moving soon.
/ Furnace options #35
Could be no one ever got fired oversizing...plus they can hedge saying extra capacity if you add on...
I think the mark of a good system is one you don't notice....
/ Furnace options #36
That's an old one.
I actually made up a formula that sounds pretty convincing because it requires the same kind of picture and instructions, but I included 4 different math formulas completely as a joke. When you involve math, it really sounds more legitimtate LMAO
Here is the reality with most HVAC contractors an (and this is what a lot do)...
Take the square footage of the house, and divide by 600. That is your tonnage of AC.
If it's an older house, add 1/2 ton to the above. If it's an older farmhouse, add 1 ton to the above (exact age that determines if it's "old" or not up for interpretation LOL). If the house is "new" and looks "tight" with good windows, subtract 1/2 ton.
What's required in NC is a block load for a basic change out. Garbage in, garbage out. Honestly, depending on the garbage inputed, the quick formula listed above will generally work more more often than naught.
Here is the thing though, when it comes to even North Carolina west of Greensboro, the heating load will generally exceed the cooling load. This is why guys generally oversize the the gas furnace. If you need 3 ton of air, guys will generally go with a 60,000 or 70,000 BTU gas furnace and only look at the input, not realizing that the AFUE will actually dtermine the actual output of the gas furnace (when you only need 36,000 BTU/h of cooling).
The hardest thing a contractor has to learn is to input the right date per insulation factors and other variables such as window types.... and trust the information he's inputting. What guys end up doing is changing the input data to what they "think" the house really needs. I've caught myself doing this as well when I first started doing loads, not trusting the program.
On a sidenote, I know who installed the system in my own home when we bought it around 2004 (house build in 1988, decent insulation). Contractor is one of the better ones in my area and on new homes, they due a load for everything, even back then, and I trust his manual D's and J's. 3,500 square feet, and a total of 7 ton was installed. First floor took more load than usual due to all the windows (loaded with windows, not the norm).
Pull-Behind Spreader Tractor Attachment (A61572)
Pull-Behind...
2015 Sealine F380 Flybridge Motor Yacht Boat (A59231)
2015 Sealine F380...
John Deere 12in Channel Tooth Bucket Excavator Attachment (A64194)
John Deere 12in...
2014 John Deere 644K High Lift Articulated Wheel Loader (A61572)
2014 John Deere...
2013 Case 850L Dozer w/ Ripper (A64047)
2013 Case 850L...
JOHN DEERE 220 CENTER FOLD DISC HARROW (A63291)
JOHN DEERE 220...
