Trailer Lights Gurus--Got a Question.
/ Trailer Lights Gurus--Got a Question. #101
If it were me, i'd have both (all) trailer white ground wires going into the trailer connector pin that connects to the truck white/gnd socket.
If you have the LED white wires grounded to the trailer, it sounds like you are using the actual hitch ball as the ground circuit to the truck. That will be very intermittent......
The white wire at the trailer's plug is connected to the frame (usually). But yes, personally, I like to tie all the ground points together.
/ Trailer Lights Gurus--Got a Question. #102
I am waiting on a trailer kit to arrive. The biggest issue with this kit is the lights because they are each grounded to the trailer rather than a wire tying them all together. I have already receive the jacketed trailer wire that I'm going to use instead of the wire that comes with it so that I can run the ground wire to all the lights. My FIL who does not want to pay $2.80 a foot for the jacketed stuff is going use the wires that come with mine to rewire his because rodents chewed through his wires. I told him that why I'm using the jacketed stuff, but up to him if he wants to fix wires every year. Yes, I bought the kit even knowing this, but the price is right and even with the modifications I'm going to make is will still be less than one already put together + I'll get what I really need instead of settling for what I can find. Who knows, I may end up getting different lights as well, but from what I understand the newer ones come with LEDs, will see about this when I get it.
/ Trailer Lights Gurus--Got a Question. #103
If you wish to change that you can use plastic isolators and a plastic bushing, then run the wires as you want. Not a fan of grounding via the trailer frame myself.
/ Trailer Lights Gurus--Got a Question. #104
Yeah, i have not seen this trailer frame grounding thing. Must be something new. But i can see the benefit of ground to trailer frame as long as the white wire is "also" run back to the tow vehicle frame through the connector.
/ Trailer Lights Gurus--Got a Question. #106
I dont know who on first but i know his grampa and where the white wire should go.....
My trailer with the frame grounding is about 25 years old. I would think that the advantage of frame grounding would be less wire to break.
/ Trailer Lights Gurus--Got a Question. #110
If the wires are attached to bare metal, not painted, and there is a solid connection from one end to the other, the kit I'm getting is designed to fold and there is paint on all the frame parts. You'd have to grind all the paint off at the ground points and every location where the parts connect, thus removing any rust prevention that paint might be supplying. Gotta love the people that design these type of things that don't understand that paint does not conduct electricity very well.
/ Trailer Lights Gurus--Got a Question. #111
Stakon ring terminal and a small self-tapping screw.
/ Trailer Lights Gurus--Got a Question. #112
Which is why you usually use a star washer to break though the paint when using the frame as a ground.
/ Trailer Lights Gurus--Got a Question. #113
I agree with that, but it doesn't solve the problem with all the frame parts being painted. You'd also need to replace all the flat washers that come with the kit with star washers and even then I would not be 100% sure of all the connections. It may work fine on a trailer that has been welded together before painting. This is a picture of the frame parts in this kit, not mine, it is one I stole off of harbor freight. With all of this paint the wiring kit should really have a ground wire to run to all of the lights, but then again, it's not so expensive that I'm worried about replacing their wire with my own.
/ Trailer Lights Gurus--Got a Question. #114
Agree, connecting all the grounds together is better in the long run. I connect to the frame and connect them all together. Mainly because the lights are usually attached to the frame when I get the trailer anyways, so just easier to add wire and terminal and connect them all. Many paths to ground is a good thing.
Except in the case of house wiring where a subpanel with neutral and ground is involved. Right?
/ Trailer Lights Gurus--Got a Question. #116
You enjoy the mysterious ground loop effects?
Keeping gremlins inline since 1879! Go christmas lightbulbs!
/ Trailer Lights Gurus--Got a Question. #117
Can you elaborate?
MY 2005 Chevy has no flasher or control other than turnsignal switch, and all truck body lighting is controlled by PCM (power control module) and there is a complete set of different fuses and wiring harness (from body lights) to rear of truck for trailer lighting... Wondering if PO truck may have same setup?
I really doubt it as the truck has no power seats, windows, door locks or even cruise control. It's pretty much bare bones. Doesn't even have a back seat. :)
/ Trailer Lights Gurus--Got a Question. #119
On a folding trailer best to run a ground to each fixture.... Or make flexible bonding jumper at each bend/fold... Always grind paint off frame for "ANY" ground connection ...Use a good anti corrosion compound at ground bond to prevent corrosion...
/ Trailer Lights Gurus--Got a Question. #120
OK.... It may be pre-all the computer/PCM controlled functions.... Various makes of vehicles implemented it in different years.....
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A66734)
2025 Kivel 42in...
2011 UD Thermoplastic Truck (A64194)
2011 UD...
2025 Precisions Provencal 22ft. 5th wheel Mobile Office/ Showroom Trailer (A64556)
2025 Precisions...
Unused 2025 USA Attachments EB1024 24in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
Unused 2025 USA...
2018 GMC Terrain AWD SUV (A66738)
2018 GMC Terrain...
2017 Autocar Xpeditor T/A New Way 31ASL 31yd. Side Loader Garbage Truck (A66736)
2017 Autocar...
