Trailer Lights Gurus--Got a Question.
/ Trailer Lights Gurus--Got a Question. #41
Yes, but that is because it runs off the running light wire. The 12V line primary purpose is to charge the capacitors to power the trailers brake actuators.
I wasn't aware of those capacitors. Will you please tell us where they are located on this '03 Dodge Dakota and one other vehicle of any make or model? If not on truck,tell us location on a make and preferably model trailer. I'm pretty sure they will be listed in parts list for truck or trailer. Always god to keep spares.
/ Trailer Lights Gurus--Got a Question. #43
My 57 sure doesn't, not even a switch for hazards.
Who leaves their vehicle to go get a flat repaired??? I put on the spare and drive the flat to the shop.
Owners of 2014 Dodge Grand Caravans with hide-a-way 2nd and 3rd row seats to name some that do. I'm sure there's others,like those who forgot spare,spare is flat or never had a spare since buying truck. But this shouldn't prevent you nameing a vehicle so let's hear it.
/ Trailer Lights Gurus--Got a Question. #44
Yes both trailer lights are connected to white leads on trailer harness. The white lead on pickup harness is attached to pickup frame.
Test results are in:
Fuse slot "C" in engine compartment labeled "Trailer Tow Connector" is an inactive slot so no fuse.
Fuse slot "T" in engine compartment labeled "Trailer Tow Connector" was empty so I installed a fuse.
Now getting "blinking power" at trailer connector between white and green and white and yellow pins with ignition switch on but LIGHT SWITCH OFF in the pickup. Hazards working also. No power to brown on connector which is as it should be with pickup lights off.
Haven't connected trailer yet but will do and expect all lights to be working as they should. Been working on this for almost 10 hours now with about 90 minutes out for lunch and nap. Going to have a beer now if you all don't mind.
Edit: Thanks to herm0016 in post #29 for arousing my suspicion that a fuse was lacking even though is wasn't necessarily the fuse for 12 VDC power.
The weird thing is that I've been pulling this trailer around for about 20 years now and have checked the old trailer lights on occasion, even last week, and found them to be working without the pickup lights on.
I suspect that the new lights, being LED, may have had something to do with it since the fuse was missing. Just weird.
Thanks to all for weighing in on the thread.
Not sure just how adding a fuse for a feature the truck doesnt have made it work, but I'm glad you finally got it working (y)
/ Trailer Lights Gurus--Got a Question. #45
Please explain where said capacitor are found..... The trailer brakes on my trailer (with 7 pin connector) are controlled by after market controller (below dash) which is actuated off brake pedal switch....
The other constant positive 12 volt lead (on 7 pin connector) to rear is to either charge the battery for trailer breakway brake circuit or maybe power lamps inside of a enclosed trailer ....
/ Trailer Lights Gurus--Got a Question. #46
Why would the trailer brake actuators be on the vehicle? What good would that do after the trailer leaves the hitch and tears off the wiring?
The controller is on the vehicle and a rudimentary receiver on the trailer to apply the proper pressure to the brake actuators whether they be electric, hydraulic, or pneumatic.
/ Trailer Lights Gurus--Got a Question. #47
Btw 1966 hazards were optional, 1967/1968+ they were required by USA DOT.
/ Trailer Lights Gurus--Got a Question. #48
Are you trolling us...?
I give up! After installing the fuse and finding the connections worked on the trailer connector as described in post #38 above with the pickup lights off, I hooked the trailer up and now find that none of the trailer light functions are working with or without the fuse and with or without the pickup lights on! Go figure.
Edit: So I go out now and did some more troubleshooting and find that the fuse I plugged in was in an inactive port BUT now I have all light functions working on the trailer connector again even with lights OFF.
I'm thinking there is a bad and intermittent connection somewhere in the pickup aftermarket trailer harness. Will pull the harness in the morning and clean all the connections as someone suggested above.
/ Trailer Lights Gurus--Got a Question. #50
Take a break and start again tomorrow. Start from the top and make sure the trailer lights still work, then double check that adapter ground where it connects to your truck. Personally, still betting on the tralier light adapter kit you installed years ago being faulty, or at least dirty connections on it.
Take that break. You're going in circles at this point.
Good advice. Will do.
/ Trailer Lights Gurus--Got a Question. #52
Actuator is on truck.... Breakaway battery and activation switch is on trailer.... Small tether to a pull pin comes out of switch and locks up trailer breaks... DOT and State law says in trailers over 1500 pounds it has have breakaway and to be able to hold trailer brakes lock for at least 20 minutes...
Excuse me but my electric brakes are powered directly from proportional controller under dash to magnets (actuator) on backing plates of trailer axles, the is no rudimentary receiver in electrical brake system... Yes there is some hydraulic serge system on trailers but they don't have any controls from operator cab..... Have not seem any pneumatic brakes on pick up level trucks (mainly reserved for LRGE trucks)...
/ Trailer Lights Gurus--Got a Question. #53
I'm thinking there is a bad and intermittent connection somewhere in the pickup aftermarket trailer harness. Will pull the harness in the morning and clean all the connections as someone suggested above..
Might investigate whether there is factory harness on board but not connected..... All truck wiring may be in place but just no 4 pin or 7 pin connector on rear.... Climb under truck and find where wire harness goes from front to rear of truck and follow it back, look for a Plug/Socket with 4 to 7 wires on it that is not connected to anything.....
Something like this may be solution to stock truck wiring...
/ Trailer Lights Gurus--Got a Question. #54
Trolling might be an understatment. I think more accurate to ask "are you intentionally makeing yourself out as a fool or are you actually clueless and don't know how to admit it?"
No not trolling. Reminding myself why anger management said I had to participate.
I find your ignorance refreshing and productive.
/ Trailer Lights Gurus--Got a Question. #55
What!? Anger management says you have to participate? Does this work for alcoholism too?! -- we have to drink?!?! WoooooooHooooooo!!!!!
/ Trailer Lights Gurus--Got a Question. #57
We drove out to Oklahoma and back last weekend. I'd guess we saw at least 20 cars/pickups/suvs/small trailers laying on the side of the road with one tire missing and no one around.
However, I don't recall any of them having their flashers on. 🤣
/ Trailer Lights Gurus--Got a Question. #58
You know, guys, the trailer brake actuator is not on the truck. The trailer brake controller is on the truck. The thing that actuates the brakes is on the trailer. If it wasn't, the trailer would have no brakes if it broke away.
The magnet in the brake assembly controls the actuator arm in the brake that applies pressure to the shoes that grab the drum. It gets the voltage from the brake controller in the cab. Brake controller, not actuator. Controller.
/ Trailer Lights Gurus--Got a Question. #59
Pretty tough statement for someone who has been pretty much wrong all the way along....
Show me where I am wrong with proof and while your at it, tell me which of these you install in your vehicles under the dash:
Not a tough statement; I truly think you are an ignorant kid, sure you have lots of knowledge and are helpful, however your attitude diminishes that a lot.
/ Trailer Lights Gurus--Got a Question. #60
And to add a little bit more to that...
2010 Chevrolet HHR SUV (A61574)
2010 Chevrolet HHR...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
2012 Dodge Ram 1500 4wd (A62679)
2012 Dodge Ram...
2006 GMC Savana 3500 Box Truck (A61573)
2006 GMC Savana...
