allen ledford
Thanks for the info. I have another question. The Caroni has 2 belts. some of the other brands have 3 belts for the same size mower. Is 3 belts better?
Typically more are better. In the end it is more about belt width - wider means more hp can be transmitted (so 3 are usually wider than 2 but depends on the belt). For the same hp, wider belt means less stress on the belt.Thanks for the info. I have another question. The Caroni has 2 belts. some of the other brands have 3 belts for the same size mower. Is 3 belts better?
Beside Determining the speed ratio, in general a smaller pulley is worse on belts because of the lower contact area (allows more slippage) and greater bending (wear on the belt) so more tension is required to properly transmit HP. Those are general considerations though and depends on specific design calculations which vary by total belt path, belt width, hp to be transmitted, potential desire to allow slippage to reduce shock loading, etc.Please try to explain the pully diameter factor.
I found the Jack shaft simple and effective as long as the gearbox which has vertical adjustment is adjusted with the output shaft.As far as belt quantity goes, my Alamo SHD88 only has 1 belt, a size C belt. As far as I know all Alamo mowers use 1 belt. I've had the belt shred when I've hit things I probably shouldn't have hit (logs that jammed the rotor tight). Otherwise it would last for a long time. I think the belt is the "shear pin" on my mower. It saves the gearbox from certain demise when my mower finds things my eyes didn't. It provides more of a cushion than a slip clutch would. I just keep an extra belt on hand at all times as I typically only go through 1 a year.
Belt tension mechanisms are important. It's best to have an extra pulley as the tensioner. I feel spring tensioners are better than solid tensioners. I've seen the Chinese mowers use the jack shaft (between the gearbox and the belt) as the tensioning mechanism. That is a poor design in my opinion. It does not guarantee parallelism between the pulleys. Pulleys that are not parallel will cause all sorts of issues with the belt(s).
What are you looking/needing to mow?I can't stand it any longer. I just got to get me one of these damn FLAIL mowers. I live in north central Louisiana and we have no dealers in my part of the woods. I have been looking at a CARONI brand mower 73" for about $ 2600.00
Do any of you guys have any info on this brand. this REDNECK COONASS needs some help. My tractor is 65 HP.
Thanks for info,
Allen
What exactly do the tines do for you on that Nova mower? Are those mulching tines? Mine has a stationary strip of teeth that do the mulching.What are you looking/needing to mow?
I'm running a 7' flail on my 55hp Kioti and am mowing all sorts of crap, in which case I had to have a mulcher type of flail (as well as having hydraulic side-shift): the flail is rated for 60hp to 120hp machines (I have to operate at slower ground speeds so I figured I could get by being a bit under-powered). Prices have gone up and are now around $4,300 for this flail: I got mine for $3,500. Lighter-duty flails are, of course, less.
My Pruzzo has fixed teeth out of dull bar stock. Seems to provide a good fixed jaw for the hammers to chew up & mulch stuff against.What exactly do the tines do for you on that Nova mower? Are those mulching tines? Mine has a stationary strip of teeth that do the mulching.
Right now on FB-marketplace here in my “Hometown” of Denton, Tx is a Ford 917 for a modest $950! (Rolls eyes) it’s been listed for about 2 weeks as of tomorrow.I can't stand it any longer. I just got to get me one of these damn FLAIL mowers. I live in north central Louisiana and we have no dealers in my part of the woods. I have been looking at a CARONI brand mower 73" for about $ 2600.00
Thanks for info,
Allen
That one has been on and off for more than 6 months. (I’ve been tracking it or was until I bought a different unit)Right now on FB-marketplace here in my “Hometown” of Denton, Tx is a Ford 917 for a modest $950! (Rolls eyes) it’s been listed for about 2 weeks as of tomorrow.
This is what I've been using and cutting with a 40hp PTO for the last 6 years. Of course with the fields beat back now it's much easier.I think I am going to get the Sicma MLA - 160. Anyone have experience with this brand/flail?
