Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #7,221
Thanks for the info. I have another question. The Caroni has 2 belts. some of the other brands have 3 belts for the same size mower. Is 3 belts better?
/ Let's talk flail mowers #7,223
Typically more are better. In the end it is more about belt width - wider means more hp can be transmitted (so 3 are usually wider than 2 but depends on the belt). For the same hp, wider belt means less stress on the belt.
hpwever you DO want a weakest link - slipping a belt, even if it has to be replaced, is a good way to prevent damage should you jam the rotor.
Then there is belt material; Kevlar type are typically better and last longer.
Finally you can get combo belts, where you can buy one wide belt that is the same width as 2 (or 3) standard belt. Advantage there is there is no “matching” of lots to ensure different belts don’t have slightly different characteristics.
However proper belt run design with tensioner, etc and proper tensioning and pulley alignment is far more critical to belt life than the belt itself. There is a large amount of science around belts that can be used; depends on the machine manufacturer which is one reason why the Chinese imports are regarded as slightly inferior to US/Italian models which typically draw on that body of engineering knowledge more heavily
/ Let's talk flail mowers #7,224
Please try to explain the pully diameter factor.
Beside Determining the speed ratio, in general a smaller pulley is worse on belts because of the lower contact area (allows more slippage) and greater bending (wear on the belt) so more tension is required to properly transmit HP. Those are general considerations though and depends on specific design calculations which vary by total belt path, belt width, hp to be transmitted, potential desire to allow slippage to reduce shock loading, etc.
/ Let's talk flail mowers #7,225
As far as belt quantity goes, my Alamo SHD88 only has 1 belt, a size C belt. As far as I know all Alamo mowers use 1 belt. I've had the belt shred when I've hit things I probably shouldn't have hit (logs that jammed the rotor tight). Otherwise it would last for a long time. I think the belt is the "shear pin" on my mower. It saves the gearbox from certain demise when my mower finds things my eyes didn't. It provides more of a cushion than a slip clutch would. I just keep an extra belt on hand at all times as I typically only go through 1 a year.
Belt tension mechanisms are important. It's best to have an extra pulley as the tensioner. I feel spring tensioners are better than solid tensioners. I've seen the Chinese mowers use the jack shaft (between the gearbox and the belt) as the tensioning mechanism. That is a poor design in my opinion. It does not guarantee parallelism between the pulleys. Pulleys that are not parallel will cause all sorts of issues with the belt(s).
/ Let's talk flail mowers #7,226
I found the Jack shaft simple and effective as long as the gearbox which has vertical adjustment is adjusted with the output shaft.
/ Let's talk flail mowers #7,228
I can't stand it any longer. I just got to get me one of these damn FLAIL mowers. I live in north central Louisiana and we have no dealers in my part of the woods. I have been looking at a CARONI brand mower 73" for about $ 2600.00
Do any of you guys have any info on this brand. this REDNECK COONASS needs some help. My tractor is 65 HP.
Thanks for info,
Allen
What are you looking/needing to mow?
I'm running a 7' flail on my 55hp Kioti and am mowing all sorts of crap, in which case I had to have a mulcher type of flail (as well as having hydraulic side-shift): the flail is rated for 60hp to 120hp machines (I have to operate at slower ground speeds so I figured I could get by being a bit under-powered). Prices have gone up and are now around $4,300 for this flail: I got mine for $3,500. Lighter-duty flails are, of course, less.
/ Let's talk flail mowers #7,229
I have a Bestco AGL 165 Ditch bank flail mower. Anybody gone to the Y blades on this one? If so where did you get them since I would also need the appropriate spacers? Emailed Bestco awaiting a response, but perhaps there is a better source.
Thanks\Mike
/ Let's talk flail mowers #7,230
What exactly do the tines do for you on that Nova mower? Are those mulching tines? Mine has a stationary strip of teeth that do the mulching.
/ Let's talk flail mowers #7,231
I think I am going to get the Sicma MLA - 160. Anyone have experience with this brand/flail?
/ Let's talk flail mowers #7,232
My Pruzzo has fixed teeth out of dull bar stock. Seems to provide a good fixed jaw for the hammers to chew up & mulch stuff against.
/ Let's talk flail mowers #7,233
Thanks for info,
Allen
Right now on FB-marketplace here in my “Hometown” of Denton, Tx is a Ford 917 for a modest $950! (Rolls eyes) it’s been listed for about 2 weeks as of tomorrow.
/ Let's talk flail mowers #7,234
That one has been on and off for more than 6 months. (I’ve been tracking it or was until I bought a different unit)
/ Let's talk flail mowers #7,235
Depends on condition - if it's in good condition and not in need of major overhaul it's perfectly OK asking price.
/ Let's talk flail mowers #7,236
Ford 917 is a good choice because it has decent aftermarket support. Also, Alamo course cut blades will fit on that unit as well (in the course cut positions). As arto said, if it is in good condition that's a fair price for it. I bought one missing the rear roller for $750, made a new roller for it and replace the blades. After using it for a year I sold it for $1200.
/ Let's talk flail mowers #7,239
Interweb says it's 87" cut and 94" overall. Looks like a very good mower. I'm curious if he has knives or hammers on it? I have the Italian Maschio 300 with hammers.
/ Let's talk flail mowers #7,240
New member of flail mower nation with a Loftness 177/72M. I have a post on it including pictures. Loftness 3pt Flail (new to me)
I’m looking for recommendations on improved mulching. With y knives I would have thought I would get good mulching but I end up with nicely cut grass and long blades laying on it. What I have done:
All blades new or freshly sharpened.
run at 540 rpm
mowed slowly
Top link parallel to gearbox shaft
Run back over it - doesn’t seem to help, and neither fresh nor 2 day old dry cuttings seem to be picked back up by the flails.
What else can I do to improve recutting/mulching?
Tilt overall mower forward/backward with hydraulic top link
Try a higher roller setting or lower (can’t go much higher/lower cut but I have some room)
Add some heavy material over back discharge chute to possibly encourage recutting (what I have is the original discharge deflector which has no adjustment)
Which of the above or other ideas are most likely to help more finely shred the cuttings?
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
New/Unused Hydraulic Thumb for CFG Mini Skid Steer (A61166)
New/Unused...
2025 X39 Hydraulic Trencher Skid Steer Attachment (A61567)
2025 X39 Hydraulic...
2014 Chevrolet Silverado1500 Pickup Truck, VIN # 1GCNCPEH0EZ393232 (A61165)
2014 Chevrolet...
2025 80in. Hydraulic Dual Cylinder Grapple Bucket Skid Steer Attachment (A61567)
2025 80in...
JOHN DEERE 4440 TRACTOR (A62130)
JOHN DEERE 4440...
