Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #7,241
By raising the rear roller you are lowering the cutting height;
this is what you need to do to recut the material finely as long as
the belts are tight and the gearbox is level-never mind the shaft.
/ Let's talk flail mowers #7,242
I don't think knives are as good at mulching as hammers are. Mine mulches really well and it doesn't matter much how I set it up.
/ Let's talk flail mowers #7,243
Does that apply to tall grass as well?
curiosity only. The one I have doesn’t allow for hammers, only y knives
/ Let's talk flail mowers #7,245
I have hammers on mine. They were getting pretty beat up so I thought about replacing them. But at 24 canuckastan dollars each and needing 55 of them I thought I’d try sharpening them. So I flipped it on its back and spent an hour with a grinder and cleaned em up. They’re working almost like new.
/ Let's talk flail mowers #7,246
Looky what I just picked up 🙂👍
/ Let's talk flail mowers #7,247
It's to hot to keep unpacking this thing but here is a better picture.
/ Let's talk flail mowers #7,248
Hammers or blades? That mower looks like a first cousin to my Maschio. Some assembly required.
/ Let's talk flail mowers #7,249
Hammers. Going to try and get it together tomorrow. It's sicma, so another Italian brand. Appears to be very stout
/ Let's talk flail mowers #7,250
You will love it. Mine cuts grass as good as my FM but will grind anything to a pulp. I see you got the slide version as well. Mine is 10' and weighs 2100 pounds.
/ Let's talk flail mowers #7,251
I was worried about getting one to big for my tractor 55hp. So I got 5'. It weighs 1000 lbs. It might take me a little longer but I got music and cold drinks 😅
It's the ditch bank one. I needed for different areas on the property
/ Let's talk flail mowers #7,252
Let us know how you like it and some pics when you get it together and hooked up.
/ Let's talk flail mowers #7,253
Man the heat is really getting to me. That and putting this together would have been easier if I had a helper. Almost done but I can't even touch my tools they are so hot 🥵. I hope it's worth it 😃
/ Let's talk flail mowers #7,254
Sorry to bump my own post.
To me the flail just looks better on the tractor than the RC did. I don't know why, I guess it looks like a real agriculture tool.
I know I will be posting in a week wishing I got a bigger one 🤣. Anyways this was the biggest ditch bank that was recommended for my tractor .
/ Let's talk flail mowers #7,255
I want to welcome you as the newest member of the "Flail Mower Nations" from the State of Tenn.
You will not be disappointed as you have purchased a high quality farm implement.
Once you become more used to using the mower you will be fine and you will not want
a bigger flail shredder for your mule.
Your mower typically will be raised to vertical for transporting it and it would be very
good practice for you to just drive around with the flail mower raised in the vertical position
with the three point hitch raised up half way and that will allow you to fully see how the
mower will affect the tractors movement as the slight swaying motion will remind you to
slow down, brake and steer firmly in the direction you are traveling in.
This also applies to operating in reverse with the mower raised while you are mowing a
brush line of weed trees to keep a path open.
Follow the manual directions for operation your flail shredder and be sure to watch
your ditch edges to maintain adequate traction and balance and you will have a
great mown area that will require little work as long as you know your tractors limitations
as far as following the centerline of the tractor hood making sure that the front and rear
wheels are on solid ground and your tractor is not on a side hill grade that is greater than
15%.
I would definitely want you to have a slope and grade scale that you can purchase from wallymart
or from AMAZON shipping it over night.
Buying it from amazon will pretty much guarantee you will have one before you begin mowing the next day.
If you have a weight for your pallet forks all the better as the front end will be in better contact with the ground too.
Your rear roller is set to mow very low and you will need to decide if you want to mow that low on your first mowing.
If you want to adjust it follow the manuals directions to reset the rear roller and then mow for a while and decide
if you wish to mow that low.
The major benefit of mowing at the lowest setting is that it will enable you to beat back the invasive plants like poison
oak and poison ivy and sumac.
Happy mowing.
/ Let's talk flail mowers #7,256
15%.
Happy mowing.
Yes it mows to low. Funny thing is I lowered it quite a bit already, but it needs to be lower.
/ Let's talk flail mowers #7,257
Right now your beautiful flail mower is set to mow as low as possible as the rear roller is the same height as the side skids.
Do you want to raise the cutting height? is that what you mean?
/ Let's talk flail mowers #7,258
Yes bad terminology. I mean I needed to raise the cutting height
/ Let's talk flail mowers #7,259
I am glad we cleared that up. You can adjust the rear roller with the mower in the vertical position
too so just be careful releasing the bolts and slide it slowly outward to the point where you want to
set it making sure you follow the manuals instructions.
/ Let's talk flail mowers #7,260
I'm no flail expert, but from my limited exposure it seems that flails do best on grass when set to low mowing heights (rear roller set up higher): better vacuum in which grass gets lifted up and cut. Doesn't seem to matter much for brush. And it's more so in brush that you want to be up a bit more because such ground is likely less developed and therefore more hidden dangers right above surface level.
Nice setup!
2016 Nissan Titan XD Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
2022 EZ-GO ELITE...
2012 BMW 328i Coupe (A61569)
2012 BMW 328i...
(4) 25x10-12 4 Wheeler Tires w/Rims (A64127)
(4) 25x10-12 4...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
2018 CATERPILLAR 573D FELLER BUNCHER (A64276)
2018 CATERPILLAR...
