Whole house generator
/ Whole house generator #21
I paid I think $4,000 for my 22 kW generac from Lowe's using a 20% coupon 3 years ago. Had an electrician charged me 1800 bucks to install it that included the cost of the disconnects and aluminum wire. I'm located in Southern Maine on the New Hampshire border everyone else was quoting me 9,000 plus was crazy
/ Whole house generator #22
The stipulation is needs to be installed by an Authorized Generac Service provider. Didn’t know until I was reading the fine print. Did not know a Generac Service guy was 5 miles away until I was looking for the service.
That’s bs. Ive repaired many owner installed units. But it DOES have to be installed per code and per installation manual. GENERAC has never asked me who installed unit. They do ask for pictures showing installation in questionable problems. I have had calls for warranty issues where unit won’t start, to find it hooked up to a propane grill canister. Of course GENERAC won’t warranty that.
GENERAC has always paid for warranty repairs on properly installed units that I have serviced.
the ONLY stipulation GENERAC has is WARRANTY REPAIRS have to be done thru generac certified repair facility. Not installation.
/ Whole house generator #23
I have removed that from my previous post. My misinterpretation. Sorry if I caused any angst here, not my intention.
/ Whole house generator #24
My local electrical contractor just published a notice that there is an approximate 6 month lead time to deliver a whole house generator.
/ Whole house generator #25
If there lucky. there supposed to be opening a second assembly plant back East. Not sure when. This will really help.
its not just generators. Getting repair and maint parts also is slow. I stocked up on air filters, spark plugs, oil filter and oil . The order was placed 6 weeks ago, but only received last Thursday.
/ Whole house generator #26
These lead time things are confusing. Some may well be running that long, maybe even most. I ordered my 16KW on November 26th and it was delivered on December 30th. Nobody has been able to explain how it arrived in 4 weeks instead of the 12-16 weeks initially estimated.
/ Whole house generator #27
Took two months, but my local company finally received their shipment. They installed my generator unit on Friday. It's a 18kw surge / 12.5kw continuous. Propane install should be on Wednesday. The portable 22kw gas unit I have been using for the past 8 years has done a great job and was only needed a handful of times. At least I won't have to go out - move it to its location and plug it. Getting too old for that stuff.
/ Whole house generator #28
does natural gas or propane make more sense for a whole house generator on a rural property. At this point, I do not have either on the property. Thanks!
/ Whole house generator #30
All about cost and availability. Is NG available? If so, what would it cost to run it to the house/generator location? Is there an LP supplier local? If so, what are their charges for tanks and installation? Then check recurring rate for the gas.
/ Whole house generator #31
I keep hearing that the prices of propane tanks has skyrocketed. A lot of propane suppliers won’t rent for generator use only, as the refill rate is low. Just my observations
/ Whole house generator #32
As you are in Texas, I would point out that natural gas isn't always available when you want it. E.g. last winter. Recent actions by ERCOT don't give me the warm and fuzzies that it won't happen again.
I would recommend propane, if you don't have natural gas on the property. Buy a big tank, fill it, and connect up your standby generator.
Or go for solar, and add batteries. There are commercial batteries, e.g. Tesla Powerwalls, LG, Enphase, and others, and there are lots of DIY versions made from lead acid, or old electric car batteries, e.g. Prius, Leaf, etc.
All the best,
Peter
/ Whole house generator #33
Fuel storage is a big consideration. There are a couple big advantages to propane:
1. Propane does not go bad. Even diesel has a limited tank life, though with stabilant and good filters you can keep it around for a few years.
2. Your fuel supply is on-site. I heard that the problem during last winter's ice storm was that the natural gas supplies froze at the well heads before the water could be extracted. I didn't hear that residential supplies were interrupted, but they had to shut down power plants.
/ Whole house generator #34
Propane won't go bad but the colder it gets the less the tank will provide.
Many bury their tanks to take advantage of ground heat.
Come spring you'll find that many tanks have about 1/3 propane remaining in them.
OK, you can heat a propane tank but when needed for a power outage it's rather counter productive.
/ Whole house generator #35
thats onbe of the reasons i buried mine...that and the fact a 1000 gal tank is mighty ugly outdoors.
question, i have a customer thats looking at purchasing a solar generator. i have no knowlege about these units. shes looking at an ecoflow delts with 160 watt solar panel. there mighty expensive at nearly 1500bucks. just wondering if anyone has used a solar generator.
/ Whole house generator #36
In an area prone to fires, I think burying a propane tank is a great idea. I know that I wish mine was.
I think that the "solar generators" are really expensive for what you get; a small solar panel and a small battery. But if all you need is to charge a phone or two, and don't want to/can't run a car, or run a generator, it is ok. (Do the math: 160W times six hours of sunshine is less than 1kWh of power. Not a lot. And you need to be able to leave it out somewhere to charge.)
I think most people underestimate their needs until they live through a multi day outage. Sure, I have lived for long times with no power, but that sort of living involves dried or canned food, no phone, kerosene lights, and cold water baths. Not for everyone...
We have solar and are adding large scale batteries, but recently we have had power shut offs of increasing frequency ever year, and just had to face facts that for us grid power was no longer something that we could rely on. Ten or twenty times the price, (before subsidies) but you get AC, freezers, and internet...after subsidies, it can be a lot less, but it depends on where you live. (26% federal credit if paired with solar or wind)
Definitely a YMMV item in my view...
All the best,
Peter
/ Whole house generator #37
Bought a 22KW Generac brand new in a crate from someone CL for $4500 and installed it with my electrician. 2 smart switches and a lot of wiring. Works great.
Downside is its NG. NG was dirt cheap, but now its going up in price....
Maybe Ill put some solar panels across the front of my house to show my neighbors I'm woke?
Careful. Some of us are so rural we dont have power from the power company so we need those solar panels!
Now if you have a grid-tied solar system.... I watched a special on the California PG&E utility company that sends a bunch of city dwellers their so called "Net Zero" energy summary so they feel good about themselves "helping" the environment. The dirty secret is they take the total solar produced by their house - the amount they use. If they produce more than they use, then are Net Zero! However, when the sun goes down their homes are run by fossil fuels...which is actually when we usually consume the most electricity. So during the day they sell the excess to Arizona, but at night they have to buy it back at a higher rate! What a crock!
/ Whole house generator #38
Our 15kW just tops the batteries off if solar doesnt produce enough...which is only a few days a year. The beauty of it is our house never surges or has a brown/black out. We are always running on either solar excess or batteries. The generator doesnt provide power to anything. It just charges batteries when they get low.
/ Whole house generator #39
5 years ago I installed a 10kw MEB803 military tactically quiet generator on my off grid property. Then I installed 6 370w solar panels and 8 Battle Born lithium por4 batteries running through a Victron 3kw inverter. The generator is a Perkins diesel that uses 5 gallons of fuel in 9 hours at full capacity. The genny runs the house and recharges the batteries at the same time when we need it which is about 20 times a year. I have a remote start for it inside the house. All in it cost me about $17k. The generator I got from a government surplus auction site with 34 hours on it for $3800. I feed the generator from a 200 gallon tank with offroad diesel that doubles as a fueling station for the tractor. PG&E can suck rocks!
/ Whole house generator #40
We had a pretty good freeze here and the power was out for a week. A bigger generator might be a good idea and I'm curious bout this one. I'm not sold on Generac and I've always thought of Cummins as being a good brand. Anybody know anything about this generator?
