How long before Compact Diesels are obsolete?
/ How long before Compact Diesels are obsolete? #201
Electric vehicle success is going to depend largely on solar affordability. I think it has been coming down but haven't done any research to support that notion. I have seen a large solar field just east of me. The panels are on automated pivots that follow the sun. I'm talking several hundred acres as far as the eye can see.
Most of us have some solar panels in use. I have been pleased with my limited use of panels to keep batteries charged.
The problem with solar on equipment that operates during the day is the need for a separate battery bank. The solar panels will need to charge an idle battery bank during the day to then transfer that charge to the batteries that are parked at night
We avoid that with "Grid Tie" where available. The Solar PV is tied the Grid, and the Battery Charger is also tied to the grid. The grid gets the valuable Day Time Peak Use supply from the Solar PV, and then we charge the batteries when it is handy for us. Win-Win for most local grids.
/ How long before Compact Diesels are obsolete? #202
Rural Michigan? Grew up there. A smaller or reducing local economy make for difficult budgets. No one wants to invest in a risky or potential shrinking market. In much of the US we use a "Service Life" model. Most components have a 25 to 50 year Service Life. So that means we will replace up to 4% per year (for 25 year life equipment) or down to 2% (for 50 year life equipment) any given year. Add on some growth (again, for growing local economies) of 1 to 2% per year -- and we are replacing or expanding around 5% every year.
So for now, in Texas -- folks just ask about chargers, and we are happy to put in new transformers, lines, etc., as needed. Happy to sell the extra electricity to a new customer. Locally that means the grid is continually renewing all around US. But again, that is an expanding market and economy.
Sort of ironic on the reducing or shrinking Michigan model -- if Michigan had embraced EVs, upfront, the whole region would be leading US. Instead they half-assed the Volt, and then the dealers backstabbed the whole thing.
I see Texas did well this past winter with their electric grid :ROFLMAO: Search Eddie walker post(rural living) on how long his neutral primary line has been laying on the ground UNFIXED..Little food for thought if you think the NEW GREEN deal is the answer you my friend are WRONG..Been in this business for well over 40 years..
/ How long before Compact Diesels are obsolete? #203
Here is what we (should) have learnted regarding the Texas Snowpocalypse:
1. Good Regulation = Good Results.
2. Bad Regulation = Bad Results.
3. No Regulation (Texas) = Stupid. ;)
but as far as 40 years, you may want to consider that trying to drive forward while looking in the rear-view mirror does not always work the best.
You may (or may not) like some of this. Maybe try the first 10 minutes or so.
Good stuff for opening minds that can still be opened >>>
/ How long before Compact Diesels are obsolete? #204
I see a lot of the discussion on here about batteries, batteries, batteries.
That may not be the full path ahead.
Anyone look this over? Any thoughts?
/ How long before Compact Diesels are obsolete? #205
What is your back ground in the electric gird? Just curious
/ How long before Compact Diesels are obsolete? #206
Worked all three sides on Engineering side -- EPC Contractor, Engineer of Record, and Owner's Rep. -- Technical side -- Texas Master and J-Man.
Did some time as a Site Engineer for the Big Generator -- TXU, and later as a Staff Engineer for them for compliance, and then a bunch of Substation Design and Build since. My preference would some HVDC, but we do not have a lot of that going on.
You were correct -- the Eddie Walker story is out there. I had gotten notices that Oncor (that is our Poles and Wires for the Public Utilities area -- non-Co-op areas) was looking to drag a bunch of Engineers back in for local assignments. My guess is Eddie's area may be "missing" an Engineer?
/ How long before Compact Diesels are obsolete? #207
Why do you need a engineer for a downed power line ?? You need a electric lineman to fix it..
/ How long before Compact Diesels are obsolete? #208
In a sane world, yes.
But in this case -- to get the work assigned and make sure it happens.
/ How long before Compact Diesels are obsolete? #209
the reason nothing gets done out in the field is due to the engineers. i was just at a job for a friend of mine getting power to his new house. line crew was there along with the engineer. the engineer is running off of these tangents telling us how we cant run power the way were planning, telling us how to do it the proper way. after 30 minutes of back and forth he leaves. the foreman comes over to us and tells us hell put it in the way we wanted to. there was no problem with that method.
/ How long before Compact Diesels are obsolete? #210
hahaha ahhhh. I feel your pain.
Some days, I help cause it.
Anymore, I try to do like the Penguins in the kid's movie Madagascar.
"Smile and Wave, just Smile and Wave."
/ How long before Compact Diesels are obsolete? #212
So what did you think of that Tony Seba stuff? You check any of it?
Where is your service area? I grew up around the area between Battle Creek and Athens.
Used to farm there.
/ How long before Compact Diesels are obsolete? #214
Used to farm there.
Jackson ,Adrain,bronson,south Monroe ..
/ How long before Compact Diesels are obsolete? #215
That maps close to the old homelands.
Do you deal with much services to Central Pivot Irrigators? (taking this back a bit towards Tractors and Farming)
/ How long before Compact Diesels are obsolete? #216
Phil Timmons what happens when you have 10 or 15 stop signs traveling in town? your 250 watts is a steady speed it takes more juice to get up to speed so it will take a lot more wattage with all the start and stops going on. Then there is the time you want to pass someone and that takes a lot more juice.
willy
/ How long before Compact Diesels are obsolete? #217
Phil your movie he talks about cell phones a lot but as
you know farmers don't have any where the cell phones
as in the people in the cities what has this got to do with
farm tractors???
willy
/ How long before Compact Diesels are obsolete? #218
willy
These are just working numbers. There is not some magic "always" numbers. You do not really have to over-think this stuff.
Where EVs tend to "drop" mileage, if that is what you are asking? Winter. That is when you use cabin heat. Since the EV portion generates so little heat (unlike an ICE with waste heat for the cabin). For me -- with a Volt, and a combo ICE and EV option --- I just run the ICE for the first 5 miles or so, get the car really warm, defrost the windows, and then switch to EV without heat.
But really, I drive about 80 mph most of the time, and those numbers (250 watt-hours per mile) work out.
As far as stops go, with EVs -- most have re-generative braking. So you take your foot off the gas, and it starts backfeeding the battery, anyway.
/ How long before Compact Diesels are obsolete? #219
farm tractors???
willy
If you follow through some of Tony Seba's stuff what he is REALLY talking about is Technology Shifts. How things seem to stay the same, the same, the same . . . and suddenly switch.
Shifts in Agriculture follow this, as well. We did Horses. Forever. Then Steam, Then ICEs. Now no other than Amish use horses. This is all just within 100 years.
So Tractors going electric . . . Diesel, then Diesel, then Diesel -- then suddenly Electric. Not saying this is so, but just the way things tend to work. But behind ALL of the Tech Shifts -- they are already going on for YEARS before folks notice. Look at this essay discussion from over 10 years ago -- all about this stuff. I am still working on Design Tests and Releases on this stuff. >>>
/ How long before Compact Diesels are obsolete? #220
Oh. My beef with electrical engineers hit a head back in 1997 in calif when I was hired on by a contractor I used to work for to remodel a 125 unit hud project damaged by northridge earthquake. Even though I lived in Idaho, the guy wanted me to be site super and he would give me the electrical side.
first meeting with elect engineer they threw this huge set of blueprints at me and I dug down to find electrical. They had us repowering all the buildings. They planned on doing this by sawcutting the he** out of the parking lot and running miles of pipes all over the place. Each building had 12 units and 6 saw cuts. There would be nothing left of the place. Also, each conduit run had maybe 12-20 elbows in the drawings. I pointed out to him that after 4 90s I’d need an exposed j box. He had no idea what I was talking about.
i had to redesign the system myself. I ended up adding soffits in each building to access all units and ran SER cable. I saved the contractor so much money he gave me a complete custom set of kitchen cabinets and appliances as a bonus.
the engineer had charged a heck of a lot of $$ for a plan that would be illegal to install.
2017 Ram 5500 Bucket Truck (A61307)
2017 Ram 5500...
2015 C.GALLEGOS PNEUMATIC TRAILER (A60736)
2015 C.GALLEGOS...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
BOX BLADE (A58214)
BOX BLADE (A58214)
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
