Engine design affects starting
/ Engine design affects starting #21
No, many "use to be" direct injection, the pre chambers came along with emission BS.
SR
You have that backwards, IDI was more common early on, DI is the norm for modern tier 4 final.
IDI runs on a lower injection pressure and are typically lower cost in the fuel delivery side, they also can be more tolerant of fuels.
Kubota use to offer both DI and IDI in the same series/displacement, now due to emissions requirement pretty much everything common rail DI except for the lower HP engines that fall under the 19Kw threshold.
If I had my rather I prefer DI, but I've never had a problem with my IDI's. The worst engine I have for starting (with a starting aid at least) is my forklift with a Nissan SD25, takes about 30sec of glow plug at least and might take 2 tries below freezing. It also has about 6k hrs of most likely hard work.
/ Engine design affects starting #22
The Nissan SD are a good old design, licenced from Mercedes Benz if I'm not mistaken.
/ Engine design affects starting #23
They are stout for sure, mine is in an 80's Nissan forklift so I'm sure its had a rough life, biggest problems I'm finding it parts availability is a bit scarce in the US. They are very popular in Australia though!
/ Engine design affects starting #24
Lots of Datsun/Nissan pickups and vans used it and a few large sedans mostly used as taxis her in Norway in the late seventies and eighties.
/ Engine design affects starting #25
There were some trucks with them in the US also but not nearly the numbers as other places, most of those have rotted into the ground now anyways so are pretty rare to find.
I have a friend that works for Nissan and can usually get any part if its available, there pretty much nothing available here.
Took a while to find a valve cover gasket for my forklift, i would have had to pay a lot to get one from Australia but I managed to find one from a forklift parts supply company.
/ Engine design affects starting #26
You mean, "if there are glow plugs in the engine"...
Some direct injection diesels have a glow plug in the intake tract...
SR
Different entirely. Heaters for intake air. They are not in the precombustion chamber. Glow plugs do not survive in a direct injection combustion chamber.
/ Engine design affects starting #27
Not entirely true, there are a number of DI engines with glow plugs in the combustion chamber.
The Duramax and Powerstroke engines are the first that come to mind.
/ Engine design affects starting #28
SR
Maybe check up on you information sources. The direct is more efficient and usually has higher compression ratios. The pre combustion is more tolerant of fuel quality.
/ Engine design affects starting #29
My Ford has the heater in the intake stream. One reason NOT to use ether. Unless, of course, you want a face full of flames or exploding air filter(s).
I've never had a problem starting the old Ford and until recently, the heater wasn't even wired or working. I installed a new one with wiring during my restore. Anxious to see if it really makes a difference down here in the South. But, I don't have it running yet. It's been too cold or wet to finish the painting and assembly.
Glad I started this thread. I have learned more about diesel engine design than I expected.
/ Engine design affects starting #31
Quite wrong, most DI engines of modern design have glow plugs direct in to the cylinder. A picture of a k9k 1.5 dCI used by Nissan/Renault, same as have owned several of and this is a very typical small diesel engine for smaller cars, a 1.5l in a range of 70 to 110hp.
/ Engine design affects starting #32
SR
JD 1010/2010 diesels had pre-combustion chambers where glow plugs & injectors were installed back in 1960-1965
/ Engine design affects starting #33
I'm glad you started it too. But just remember that what you get online is often opinion built around bias rather than facts based on science. So take it with a grain of salt.
There are lots of ways to heat an incoming charge to make it affect starting. Heating the charge in the manifold has been around for a long time. Also, indirect injection with and without various shapes of precombustion chambers and with or without glow plugs has been around for 50 years or more. The even simpler direct injection has been around even longer - also with and without glow plugs.
There are other even older methods - like hot bulbs. Injection itself can take place over a huge range of pressures and nozzle types.
A good designer can make just about any design work. As for glow plugs themselves, I've found them to be really durable even when they live right there in the combustion chamber. Most of my problems with glow plugs turned out to be problems with the high amperage wiring and relays that they require.
enjoy,
rScotty
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
20ft Phelan Lowboy Trailer (A65563)
20ft Phelan Lowboy...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
2022 EZ-GO ELITE...
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
