tree grower
- Joined
- Dec 29, 2007
- Messages
- 208
- Location
- Cuttingsville, VT
- Tractor
- Ford 1210, Bobcat 742B, John Deere 1050
This is a very theoretical question, probably aimed at an automotive / engine engineer. Why do JD engines start so well without need of glow plugs, compared to other diesel engines? I have had my 1050 for 8 yrs (Yanmar engine), and even though it sits from December to March without starting, it will start instantly w/o glow plugs. I used a friend's 350 crawler that had not been started for many months, but it only turned over a couple times before starting--no glow plugs. Another friend has a Samsung excavator which had not been started in 8 yrs, but with new batteries he said the starter had barely engaged before it was up and running beautifully. My little Ford 1210 (Shibauru engine) needs glow plugs unless it is hot. My F 350 7.3 idi is the same. I assume the answer pertains to engine combustion chamber design, ie compression ratio, injection pattern, or some related factor. I'm curious as ****.
