Retaining walls and patio
   / Retaining walls and patio
So I've got the retaining wall under control, it's just a matter of time to stack and backfill.
For the pavers, I'm planning on running pvc for a couple of channel drains back there, then a layer of weed barrier followed by 4 inches of granite fines compacted, then 2 inches of washed concrete sand for the base. Am I good with that setup? 20210107_121104.jpeg
   / Retaining walls and patio #62
How are you transporting all that crushed rock back fill to this area?
I don't see any tractor or (heaven forbid) wheel barrow tracks. How will you do it when the wall gets higher? It makes me tired just thinking about it.
I was lucky on my walls. The taller wall I could approach from below at right angles with my BX24 and just dump the gravel. The shorter wall I had to work from above and parallel. Some shovel work but not too bad. I can understand now the reluctance to geogrid.
Doug in SW IA
Doug in SW IA
Wheel barrow and 5 gallon buckets.
I think because of the volume of gravel needed to fill this long straight section, in addition to all the work needed on the patio, we'll bring in a bx for help. We've already moved about 13 yards of rock by hand.
   / Retaining walls and patio #64
Need to build stoneboat out of tin. blocks & stone both ride fine.
   / Retaining walls and patio #66
I do not see how it would make a better tool than a wheelbarrow
   / Retaining walls and patio #67
You can pull it with a tractor. You can pull it with a tractor and a chain when there is no room for the tractor close. You can pull it with a cable and block (sheave) when you don't have straight line access for a chain. With a wheelbarrow, you are still carrying a fraction of the weight with your back.
The drawback to a stone boat is that you don't have a good dump height for gravel.
   / Retaining walls and patio #68
Ifn I was going to change up from a wheelbarrow I would go for a Toro Dingo, they can fit in most places a Wheelbarrow fits, even if you only rented one for a day or two, may make a huge difference in the amount of work you need to expend moving all those blocks
   / Retaining walls and patio #69
How would that be different from a wheel barrow?
DON'T tip
Don't hafta fight it
Blocks slide on, minimal lifting
Only gotta lift block once
Tow in and out wid rope
Dump height on wheelbarrow go away fast by 2nd row block above grade.
1991 Eager Beaver 24ft. T/A Dovetail Equipment Trailer (A56858)
1991 Eager Beaver...
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
MILWAUKEE 14" Abrasive Cut-Off Machine (A59076)
MILWAUKEE 14"...
2019 KUBOTA SVL75-2 SKID STEER (A52709)
2019 KUBOTA...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
New/Unused CFG Industrial MX50R Mini Excavator (A57453)
New/Unused CFG...
