Xfaxman
Super Star Member
- Joined
- Feb 8, 2013
- Messages
- 13,295
- Location
- Guthrie, OK
- Tractor
- Toolcat 5610 G - Bobcat V417 - TORO+Loader
I've always wanted an Anvil, but never really had a use for one. But I still want one because they are really cool!!!!
My truck driver friend who is always showing up with things knew that the one I had years ago wound up being left in Kuwait when I moved back to Texas and knew I needed or wanted one
He was watching an online auction saw it and at the last minute out bid and won it I'm not aware of or concerned with country of origin though I believe it to be somewhere in Eastern Europe not western Asia it is brand new weighs 400 LBS. has a 1 1/4" Hardy and a 7/8" pritchel made of cast steel and has an induction hardened face It is modeled closely but not perfectly after an 1800s Peter Wright. But who cares REALLY? It is probably made better than that of old and it will outlast me and several generations after me anyway.
I would start by building a forge and then probably do some serious online learning. Some metal gate work and garden art for sure.
Yeah I'm lucky... Terry is only a couple hour drive and a 90min ferry for me!Man I wish you were my neighbor.
Over 2 years of adding the red sandy clay fill to the shop floor and it being packed down over and over had turned it almost into sand stone.
But now it is time to break it up for the next step in the process of making it into a durable floor that hopefully will not sluff off dust everytime something hard is dragged across it To do this the fill must first be broken up.
the rake Eddy was dragging behind his little tractor would scratch and scratch and eventually do a pretty good job but not nearly deep enough.
My leveling drag blade was too un wieldy in the confined area given its size plus it would just drag over the super hard spots.
I tried my tandem disk and this broke up some of the area quite well but I needed to bare down with so much force I was destroying it and still couldn't make it penetrate the really hard spots very well.
Even using the teeth on the back hoe bucket took all day to do less than 1/3 of the floor but at least with a lot of banging and only taking short gouging cuts each time it is finally being loosened into large rock like clods that should break up more easily
The box blade I have would have worked well I am sure. However there were 2 problems with trying it #1 was I don't have the ripper teeth for it and #2 my 8n would not have been able to do very well the Case 431 would be the tractor of choice but I haven't had time to work on it
But the bucket is so much fun. I have used my backhoe bucket for that task before. It is slow going.
Merry Christmas hugs, Brandi
Ultimately in order for the enzyme process we are going to blend into the floor to work properly we need to pulverize the fill to the consistency of flour down to a depth of at least 8 inches.
Can you let us know the name/website of this enzyme? This is something that could maybe work in my storage shed.
I think the soil type is critical. Intrigues me. Wouldn't work here. Anxious to see results!!
