Snow Equipment Owning/Operating Pictures of your snow weapons
/ Pictures of your snow weapons #5,621
Put my blower on last week.
/ Pictures of your snow weapons #5,623
I want to replace the chute deflector bar with an actuator (see photos). The welded brackets have large holes for the pins while the actuator has small end holes. I am looking for an easy to build attachment solution.
I am sure some have solved this problem. Why reinvent the wheel. Please share photos of your solution that might work for me.
/ Pictures of your snow weapons #5,624
Drill your existing brackets for a short extension mount your actuator to the extensions.
Or if you are going to make a yoke for the actuator bolt the yoke to your brackets and set the actuator in the yoke with a small pin.
/ Pictures of your snow weapons #5,625
View attachment 676230View attachment 676231
If you can weld and build some mounting brackets, this should not be a bad job to get done. Mount the screw shaft down to reduce water contamination.
/ Pictures of your snow weapons #5,626
Here is a photo of an actuator I added and I built the brackets for it.
/ Pictures of your snow weapons #5,627
I adapted the ends to fit larger pins.
/ Pictures of your snow weapons #5,628
woke up to 4 inches of new snow overnight....still coming down. good day to sit by the fireplace. its nice to be retired
/ Pictures of your snow weapons #5,630
Now its raining and some hail. 8 inches of snow so far. Will turn to slop
2014 JCB 930 (A53317)
2019 CATERPILLAR 326FL EXCAVATOR (A62129)
2019 CATERPILLAR...
THREE POINT ATTACHMENT (A58214)
THREE POINT...
PENDING SELLER CONFIRMATIONS (A59908)
PENDING SELLER...
Sdlanch SDLE20 (A60463)
Sdlanch SDLE20...
2024 Hurrican GF480 (A60463)
2024 Hurrican...
