Snow Equipment Owning/Operating Pictures of your snow weapons
/ Pictures of your snow weapons #5,621
Put my blower on last week.
/ Pictures of your snow weapons #5,623
I want to replace the chute deflector bar with an actuator (see photos). The welded brackets have large holes for the pins while the actuator has small end holes. I am looking for an easy to build attachment solution.
I am sure some have solved this problem. Why reinvent the wheel. Please share photos of your solution that might work for me.
/ Pictures of your snow weapons #5,624
Drill your existing brackets for a short extension mount your actuator to the extensions.
Or if you are going to make a yoke for the actuator bolt the yoke to your brackets and set the actuator in the yoke with a small pin.
/ Pictures of your snow weapons #5,625
View attachment 676230View attachment 676231
If you can weld and build some mounting brackets, this should not be a bad job to get done. Mount the screw shaft down to reduce water contamination.
/ Pictures of your snow weapons #5,626
Here is a photo of an actuator I added and I built the brackets for it.
/ Pictures of your snow weapons #5,627
I adapted the ends to fit larger pins.
/ Pictures of your snow weapons #5,628
woke up to 4 inches of new snow overnight....still coming down. good day to sit by the fireplace. its nice to be retired
/ Pictures of your snow weapons #5,630
Now its raining and some hail. 8 inches of snow so far. Will turn to slop
/ Pictures of your snow weapons #5,632
Just trying to put down a bit of a base so my blower doesn’t throw gravel around. Been going over the driveway with the rear blade and generally squashing the snow down a bit.
/ Pictures of your snow weapons #5,635
Here is my current setup. I also have a large capacity snow bucket, regular bucket, rear blade and rear facing snow blower. Hoping this setup is the best for my conditions. This year will tell the tale.
/ Pictures of your snow weapons #5,637
I was cleaning up the shop and just sold these four little guys this past week.
/ Pictures of your snow weapons #5,638
This 3.75 cubic yard snow bucket left with my NH telehandler last October.
along with my JD Gator and shop built snow blade...
...this 10 foot rear mount blade...
and these two loaders....
And I am very happy to say this is all I have left for snow removal today...
/ Pictures of your snow weapons #5,639
I'd like to know your plan!
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
2019 ALLMAND LIGHT PLANT (A60736)
2019 ALLMAND LIGHT...
20800 (A56859)
20800 (A56859)
Electric Concrete Mixer (A61166)
Electric Concrete...
2024 JOHN DEERE 325G SKID STEER (A62129)
2024 JOHN DEERE...
11" QUICK ATTACH EXCAVATOR BUCKET (A60429)
11" QUICK ATTACH...
