Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #5,621
Put my blower on last week.
   / Pictures of your snow weapons #5,623
I want to replace the chute deflector bar with an actuator (see photos). The welded brackets have large holes for the pins while the actuator has small end holes. I am looking for an easy to build attachment solution.
I am sure some have solved this problem. Why reinvent the wheel. Please share photos of your solution that might work for me.
   / Pictures of your snow weapons #5,624
Drill your existing brackets for a short extension mount your actuator to the extensions.
Or if you are going to make a yoke for the actuator bolt the yoke to your brackets and set the actuator in the yoke with a small pin.
   / Pictures of your snow weapons #5,625
View attachment 676230View attachment 676231
If you can weld and build some mounting brackets, this should not be a bad job to get done. Mount the screw shaft down to reduce water contamination.
   / Pictures of your snow weapons #5,626
Here is a photo of an actuator I added and I built the brackets for it.
   / Pictures of your snow weapons #5,627
I adapted the ends to fit larger pins.
   / Pictures of your snow weapons #5,628
woke up to 4 inches of new snow overnight....still coming down. good day to sit by the fireplace. its nice to be retired
   / Pictures of your snow weapons #5,629
here we go...another northern michigan winter on tap!
   / Pictures of your snow weapons #5,630
Now its raining and some hail. 8 inches of snow so far. Will turn to slop
UNUSED FUTURE JBD 32" MIXING BUCKET (A51248)
UNUSED FUTURE JBD...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
UNUSED X-STAR 101" X 25' BRIDGE PLATFORM (A51247)
UNUSED X-STAR 101"...
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
