Snow Equipment Owning/Operating Pictures of your snow weapons
/ Pictures of your snow weapons #5,621
Put my blower on last week.
/ Pictures of your snow weapons #5,623
I want to replace the chute deflector bar with an actuator (see photos). The welded brackets have large holes for the pins while the actuator has small end holes. I am looking for an easy to build attachment solution.
I am sure some have solved this problem. Why reinvent the wheel. Please share photos of your solution that might work for me.
/ Pictures of your snow weapons #5,624
Drill your existing brackets for a short extension mount your actuator to the extensions.
Or if you are going to make a yoke for the actuator bolt the yoke to your brackets and set the actuator in the yoke with a small pin.
/ Pictures of your snow weapons #5,625
View attachment 676230View attachment 676231
If you can weld and build some mounting brackets, this should not be a bad job to get done. Mount the screw shaft down to reduce water contamination.
/ Pictures of your snow weapons #5,626
Here is a photo of an actuator I added and I built the brackets for it.
/ Pictures of your snow weapons #5,627
I adapted the ends to fit larger pins.
/ Pictures of your snow weapons #5,628
woke up to 4 inches of new snow overnight....still coming down. good day to sit by the fireplace. its nice to be retired
/ Pictures of your snow weapons #5,630
Now its raining and some hail. 8 inches of snow so far. Will turn to slop
2013 PETERBILT 389 SLEEPER (INOPERABLE) (A60736)
2013 PETERBILT 389...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A61307)
2023 Kubota...
1999 Dorsey 45' Aluminum Citrus Trailer (A60462)
1999 Dorsey 45'...
2012 Kubota ZG222 (A60463)
2012 Kubota ZG222...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
Giyi RB66 Quick Attach 66" Rock Bucket (A60463)
Giyi RB66 Quick...
