Travelover
Elite Member
If you drive over a branch on the ground, it will flip up and go straight into something rotating and expensive.
And shortly after you buy the case of grease the other grease shows up....:magician:
If you set the parking brake, 11 times out of 10, you'll drive with the parking brake for a while.
2. If you use the loader bucket to haul tools to the work site and back, you will forget they are there and either dump the bucket or scoop something into it.
Bruce
Your dealer will have every part for every other tractor in stock, except for yours.
That is very, very true which is why I refrain from putting anything in my bucket. I never found the chain I had there and I looked everywhere I had been. Almost ran over my chainsaw after dumping it accidentally.
Murphy's Law is bad enough, but I really hate Cole's Law.
The object you need in the tractor mounted tool box, will always be at the bottom.
The three point lift arms will never be level, no matter what.
