Murphy's Laws of Tractors
   / Murphy's Laws of Tractors #81
If you drive over a branch on the ground, it will flip up and go straight into something rotating and expensive.
   / Murphy's Laws of Tractors #82
And shortly after you buy the case of grease the other grease shows up....:magician:
NAH, you find out your SIL raided your last tube when he ran out and forgot to tell ya.
   / Murphy's Laws of Tractors #83
When you notice the weather starting to turn colder and decide to install tire chains, it wont snow for another 2 months. Conversely, when you don't think it is going to snow, so you put off installing those chains, your area will experience the 'worst blizzard in history'
   / Murphy's Laws of Tractors #84
If you set the parking brake, 11 times out of 10, you'll drive with the parking brake for a while.
Had no idea there was a seat on my ROPS for people to watch while I drive
   / Murphy's Laws of Tractors #85
2. If you use the loader bucket to haul tools to the work site and back, you will forget they are there and either dump the bucket or scoop something into it.
Bruce
That is very, very true which is why I refrain from putting anything in my bucket. I never found the chain I had there and I looked everywhere I had been. Almost ran over my chainsaw after dumping it accidentally.
   / Murphy's Laws of Tractors #86
Your dealer will have every part for every other tractor in stock, except for yours.
NOT MY Kubota DEALER, they never have anything I need in stock nor anything anyone else needs. The only thing they keep in stock(at least some) is high dollar UTV oil which I dont ever use.
Yup, dumped some tools out of my bucket, after scooping a lot of dirt into the bucket, just a few days ago. Fortunately it was just a rake and shovel, they survived.
Someday we should make a list of all the laws here, and use a polling app to see which ones people feel are the most applicable to daily life.
   / Murphy's Laws of Tractors #88
You will forget to lock down the arms on the loader bucket when hauling pig manure.......
   / Murphy's Laws of Tractors #89
If it is delicate or easy damaged will be placed underfloor and have a dozen bolts to remove to repair.
Hydraulic filters, lines. wiring all so can be snagged in the brush. or covered with the animal produce wet and soggy.
ken
   / Murphy's Laws of Tractors #90
The object you need in the tractor mounted tool box, will always be at the bottom.
Mini -Excavator Heavy Duty Rock Ripper (New/Unused) (A59225)
Mini -Excavator...
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58216)
TOOTHED BUCKET...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
Heavy Duty 4-Way Lug Wrench (A57454)
Heavy Duty 4-Way...
UNUSED FUTURE CAT 305 12" EXCAVATOR BUCKET (A58376)
UNUSED FUTURE CAT...
