Gravel question
/ Gravel question #1
Capstone
Kaufman, TX
LS MT125
Anyone know what type of gravel the state (Tx in my case) uses for asphalt roads.
I see large piles all the time on the side of the road. Usually dark grey and almost black sometimes. I assume they use it to mix for road building.
Looks 1” or less and very uniform size.
/ Gravel question #2
Sounds like maybe it is ground-up asphalt removed from the road before paving. ?
Bruce
/ Gravel question #3
Why you buy asphalt, you specify the mix. Always go with the state highway mix. Contractors sell it and install it, but if you don't have in writing what the mix is, they will give you a cheaper mix and increase their profit.
/ Gravel question #4
Piles on side of road are for seal coat applications.
Spread hot liquid asphalt, and distribute the rock on top. Sweep off excess.
Not exactly sure what it is called
/ Gravel question #5
Here they call that chip and seal.
It's limestone chips here, because limestone is cheap and local.
/ Gravel question #6
Most all the secondary county roads, around here, use some form of crushed basalt and a smaller material - the size of rock salt. It's a mix. The big 'ol gravel trucks will dump a loooooong pile - right down the center of the road. The asphalt truck follows right behind - saturating this long pile. It's then spread and rolled. Locally this is called - chipseal.
This was done to the county road right here. After a couple two or three months it was still painful to walk on barefoot. The crushed basalt was sharp as razors.
/ Gravel question
Here’s what I’m seeing. I’m thinking about putting it down over a crushed concrete base if I can find a source.
/ Gravel question #9
Yes, chip n’ seal a term used for it.
No/little fines in this material generally, won’t ever pack and setup above a hard base.
/ Gravel question
I see your point about it not setting up without fines.
/ Gravel question #11
Bet it smooths your tires also.
. Yea - Newbury, it probably ground a few thousand miles out of them. It sure kept the "kids" from doing donuts and burnouts. It gave me a moment of thought - if I happened to go down on my motorcycle - it would be like sliding down a carrot grater.
/ Gravel question #12
/ Gravel question #13
Around NE Mississippi about 8 years ago they got a bunch of money for improving secondary roads. One of the counties would send out a crew that stripped the top few inches of the old road and right behind it, then or the next day, would be a crew laying down new asphalt. Another county would send out the stripper crew and leave the grooved pavement for months. I thought a tire dealer bribed them.
/ Gravel question #15
It doesn’t make a bad layer on top of what is already a solid base. It has less dust and doesn’t get all gooey during freeze thaw. It does not pack down well and will scatter though.
24in. Bucket w/ Teeth Excavator Attachment (A64194)
24in. Bucket w/...
2007 GMC C4500 Service Truck (A62679)
2007 GMC C4500...
2015 Kawasaki Prairie 400 ATV (A64557)
2015 Kawasaki...
Wolverine Quick Attach Brush Mower (A66408)
Wolverine Quick...
2007 Sterling L9500 Fuel & Lube Y22693 (A62613)
2007 Sterling...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
