New shop started
/ New shop started
Air
Yes, I need to add more support once I move it to drying spot
I was told I should paint the ends also?
/ New shop started #362
Yes, it is a good idea to coat the ends with something to minimize end checking. Drying happens much faster from end grain than from the flat sides or edges of the board (that's what trees do - transport water and nutrients up and down the trunk...) so it can dry too fast and lead to splits and checking that can ruin part or even all of the board. Some people say latex paint works, but there is also something made specifically for this called Anchorseal, IIRC. And make sure you strap down or weight down the pile over your stickers to help keep it flat while drying.
/ New shop started #363
Anchorseal and install supports every two feet with stickers every two feet.
hugs, Brandi
/ New shop started #364
hugs, Brandi
What makes Anchorseal so much better than latex paint? I have always used white latex paint with good success. Never tried Anchorseal to compare.
/ New shop started
What is the difference between supports versus stickers?
/ New shop started #366
I didn't say Anchorseal was better than latex paint. Anchorseal is what lots of full time sawyers use. Some people are funny and won't buy custom cut (high $$$) wood with latex paint on the ends.
hugs, Brandi
/ New shop started #367
Stickers are the same species of wood as being cut and stacked, so they won't stain the wood being dried. They are usually 1x1 inch and go between layers of stacked wood. Supports are what keeps it all off the ground. The higher the supports the better for airflow. My supports are at least 4x6s. Sometimes two pallets side by side for support of shorter boards. I started making 8 and 10 foot wide forklift pallets for easy moving of the those cut lengths.
hugs, Brandi
/ New shop started #368
hugs, Brandi
No offense... just wondering. Latex paint for me is basically free. Just leftover house paint and I use a junky roller. Seems the only purpose is to seal the ends. Surely doesn't have to look good. I do like seeing the edge grain though. Is Anchorseal clear?
/ New shop started #370
I've read that Anchorseal is better at the job than latex paint (keeping moisture in). Only what I have read as I have not used it or compared...
/ New shop started
Buried mosaic yesterday
Goodbye Mosaic
/ New shop started
Today, sigh
I learned what this color in the wood means
Now to re-tip my blade
Did some logging w the jeep
Red safety bar is for going down the road
/ New shop started #373
Was that a nail in the log?
/ New shop started #375
Goodbye Mosaic
Sorry to hear.
/ New shop started #376
Very sorry to hear about Mosaic - always sad when a pet passes. They are truly part of the family.
/ New shop started
Thx all
Tree was in the middle of a well-developed forest. I was somewhat shocked to find a nail. I should’ve metal detecting the tree but I didn’t think I would need to
/ New shop started #380
Ah yes, the telltale stain of iron in wood. Bummer.
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
Mini Skid 6 Way Blade (A56438)
Mini Skid 6 Way...
1991 FRUEHAUF 45'X96" FLATBED TRAILER (A65643)
1991 FRUEHAUF...
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
