Best way for clearing HUNDREDS of stumps?
/ Best way for clearing HUNDREDS of stumps? #31
I had 1800 evergreens removed and the stumps cut flush.
tree clearing day 3 019_1.JPGtree guys last day-chipping 025_1.JPGtree guys last day-chipping 010_1.JPG
/ Best way for clearing HUNDREDS of stumps? #32
^^^^ Did they blow the chips back out onto the ground, or is the chipper waiting for a truck?
/ Best way for clearing HUNDREDS of stumps? #33
They blew the chips to the ground and spread them with the Hydro-ax. The Hydro-ax also ground up the small brush like the Buckthorn and Mulberry. With the right equipment, good operators, lots of work gets done quickly....and safely.
/ Best way for clearing HUNDREDS of stumps? #34
You got your answer already, either knock over with dozer with roots attached, or cut and use excavator
/ Best way for clearing HUNDREDS of stumps? #35
How about a large mulcher on a cat? They seem to shred everything, and leave a smooth finished surface. I have seen them build trails in the bush and do a very good job.
I think with the amount of rocks in the ground here, that's probably a no-go. As most others have said, a large excavator is probably gonna be the way to go. Just a matter of comparing the cost of renting vs the cost of hiring it out.
/ Best way for clearing HUNDREDS of stumps? #37
It would have the same drawbacks as a stump grinder mostly. Any stump or pile of chips in a hole will rot & shrink over the years. Creating divots or holes. Perfectly fine in many situations, but not great for lawns & stuff. Downright hideous for foundations & roads.
/ Best way for clearing HUNDREDS of stumps? #39
The only problem with that is all of your topsoil ends up in the stump pile. You will also lose some with an excavator, but not as much.
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
Iranch IRGC40 (A60463)
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
2016 Doyle 10T Tender (A56435)
2016 Doyle 10T...
2012 INTERNATIONAL 4300 4X2 26FT NON CDL BOX TRUCK (A59908)
2012 INTERNATIONAL...
IGERSOLL-RAND AIR COMPRESOR (A60736)
IGERSOLL-RAND AIR...
