Best way for clearing HUNDREDS of stumps?
   / Best way for clearing HUNDREDS of stumps? #31
I had 1800 evergreens removed and the stumps cut flush.
tree clearing day 3 019_1.JPGtree guys last day-chipping 025_1.JPGtree guys last day-chipping 010_1.JPG
   / Best way for clearing HUNDREDS of stumps? #32
^^^^ Did they blow the chips back out onto the ground, or is the chipper waiting for a truck?
   / Best way for clearing HUNDREDS of stumps? #33
They blew the chips to the ground and spread them with the Hydro-ax. The Hydro-ax also ground up the small brush like the Buckthorn and Mulberry. With the right equipment, good operators, lots of work gets done quickly....and safely.
   / Best way for clearing HUNDREDS of stumps? #34
You got your answer already, either knock over with dozer with roots attached, or cut and use excavator
   / Best way for clearing HUNDREDS of stumps? #35
How about a large mulcher on a cat? They seem to shred everything, and leave a smooth finished surface. I have seen them build trails in the bush and do a very good job.
I think with the amount of rocks in the ground here, that's probably a no-go. As most others have said, a large excavator is probably gonna be the way to go. Just a matter of comparing the cost of renting vs the cost of hiring it out.
   / Best way for clearing HUNDREDS of stumps? #37
It would have the same drawbacks as a stump grinder mostly. Any stump or pile of chips in a hole will rot & shrink over the years. Creating divots or holes. Perfectly fine in many situations, but not great for lawns & stuff. Downright hideous for foundations & roads.
   / Best way for clearing HUNDREDS of stumps? #39
The only problem with that is all of your topsoil ends up in the stump pile. You will also lose some with an excavator, but not as much.
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
2011 Ford F-250 Crew Cab Pickup Truck (A55852)
2011 Ford F-250...
UNUSED FUTURE AD680 47" HYD PILE HAMMER (A57193)
UNUSED FUTURE...
2017 Ford F-350 (A56858)
2017 Ford F-350...
2007 CATERPILLAR D5G XL CRAWLER DOZER (A52707)
2007 CATERPILLAR...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A55851)
Miller Trailblazer...
