Best way for clearing HUNDREDS of stumps?
   / Best way for clearing HUNDREDS of stumps? #31
I had 1800 evergreens removed and the stumps cut flush.
tree clearing day 3 019_1.JPGtree guys last day-chipping 025_1.JPGtree guys last day-chipping 010_1.JPG
   / Best way for clearing HUNDREDS of stumps? #32
^^^^ Did they blow the chips back out onto the ground, or is the chipper waiting for a truck?
   / Best way for clearing HUNDREDS of stumps? #33
They blew the chips to the ground and spread them with the Hydro-ax. The Hydro-ax also ground up the small brush like the Buckthorn and Mulberry. With the right equipment, good operators, lots of work gets done quickly....and safely.
   / Best way for clearing HUNDREDS of stumps? #34
You got your answer already, either knock over with dozer with roots attached, or cut and use excavator
   / Best way for clearing HUNDREDS of stumps? #35
How about a large mulcher on a cat? They seem to shred everything, and leave a smooth finished surface. I have seen them build trails in the bush and do a very good job.
I think with the amount of rocks in the ground here, that's probably a no-go. As most others have said, a large excavator is probably gonna be the way to go. Just a matter of comparing the cost of renting vs the cost of hiring it out.
   / Best way for clearing HUNDREDS of stumps? #37
It would have the same drawbacks as a stump grinder mostly. Any stump or pile of chips in a hole will rot & shrink over the years. Creating divots or holes. Perfectly fine in many situations, but not great for lawns & stuff. Downright hideous for foundations & roads.
   / Best way for clearing HUNDREDS of stumps? #39
The only problem with that is all of your topsoil ends up in the stump pile. You will also lose some with an excavator, but not as much.
Ammco Brake Machine (A53424)
Ammco Brake...
2017 Ford F350 (A55973)
2017 Ford F350...
2013 Nissan Rouge SUV (A56859)
2013 Nissan Rouge...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
2018 Ford F-250 Reading Enclosed Service Truck (A53422)
2018 Ford F-250...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
