WinterDeere
Super Star Member
- Joined
- Sep 6, 2011
- Messages
- 13,249
- Location
- Rural 'burbs, north of Philly
- Tractor
- John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
Re: Modern safety features - "upgrading" from an older machine
On my 855, I almost always set the brake, but I have never had any reason short of towing the machine to shift it into neutral.
I do wonder why Deere has made some of these safety feature decisions. If it is true that Kubota has not done the same, then it would appear there are no safety laws requiring them to make these apparently poor and frustrating decisions.
I haven稚 gotten that far, my machine isn稚 due to arrive for another three weeks, but I think there might be an option to disable RIO thru the dash controls on this machine. I知 not too worried about it, I only got the mid-PTO on the off chance that I want to add a front snowblower down the road, I never plan to mow with this machine. I do use the rear PTO a lot, for my 3-point snowblower, fertilizer spreader, boom sprayer, and brush hog, but the RIO isn稚 active until you switch to mid-PTO. I am interested to hear it痴 a mechanical lockout you can disable, tho, at least on some machines.I was like screeeeew thiiiiiiiis!!!, found the rio switch where it mounts, ripped it out where the reverse pedal hits it, zip-tied it outta the way. End of story.
Holy crap, that has to be the dumbest 都afety feature I致e ever seen! Of course, we壇 be much better off leaving the gear engaged, if the brake doesn稚 need to be set. I知 really surprised to hear it works this way, but I never tested getting off the machine without setting the brake, I only tried getting off without setting gear to neutral.My 2025R JD does not require you to set the brake when you get off of it but it does require it to be in neutral. I had mine start to roll away on me once when I didn't get the brake set.
Agreed. It is a very poorly thought-out system, likely devised by lawyers, not users or engineers.The need to hit the pto switch to back up while the pto is running is stupid. How is it safer to look at the dash to find the pto button instead of just looking backwards?
The 855 system is great, it only shuts off the PTO if your butt leaves the seat, it doesn稚 kill the entire tractor ignition. The down side to this system is that an implement can continue to freewheel awhile, whereas killing the ignition will stop most implants cold in their tracks.The only safety I'm in favor of is the tractor shutting down the pto when your butt leaves the seat. If I somehow fall off the tractor while mowing, I want that mower deck turning off, just in case my hand or foot somehow wedges under that deck.
Amen, brother.Only slowly. A HST machine that you put in neutral can roll quite rapidly.
Yep, thatç—´ my usual way of going about these things. Just mentally preparing myself, here.Before I would disable anything I would give it a month. It could become a "muscle memory" thing where you just do it without thinking. I shortened my ROPS so I could leave it up all the time. Now I fasten my seatbelt every time I move the tractor, it is just second nature. If after a month it still really annoys you do what you want.
Doug in SW IA
Yeah, but with my luck that will be just as I知 finishing with my snow blowing, and backing it into the shed so I can head to work in the morning!Don't worry about idling. When your machine eventually needs a regen, it will perform it.
It definitely requires you to shift to neutral, I tested that (by accident, several times) myself, at the dealership. I never tested neutral without brake.As far as safety features, does Deere "require" you to set neutral and the parking brake on an HST machine?
What model year? What brand?That's one thing mine does NOT have. I can change direction at will while mowing or tilling.
Amazing. I can稚 understand why they would require a shift to neutral, but not application of the brake!I have a newer JD 2025r. Probably similar to yours in terms of safety items. Yes you have to put it in neutral but you don� have to set the brake but should.
Yeah, but I don稚 have trouble keeping my HST pedals adjusted for no creep, whether weæ±*e talking about my 1986 Deere 855 or my 1963(?) Cub Cadet 123 HST. Itç—´ just basic maintenance, and I知 an adult. No need for a nanny, even if sheç—´ wearing green and yellow.Some like their feet, others don't. Remember, HST machines can creep if they fall out of adjustment. Brakes are there for a reason.
My 1986 Deere 855 is a Yanmar, and so was my 1976 Deere 750, so that痴 nothing 渡ew to Deere. In fact, Yanmar made the entire 855 tractor, as I understand it.Generally new tractors over 25 horsepower will have a diesel particulate filter (DPF), tractors of under 25 horsepower do not. I have a 2019 L2501 Kubota and it's almost as straightforward and simple as my 1974 Mitsubishi. The only time I can't get off the seat without killing the engine is when the PTO is engaged. It is HST and I can leave it in gear with the engine running, not set the brake, and climb off with no problem. I know nothing about Deere other than they're green and yellow, oh and the new compact ones have Yanmar engines and are assembled in Augusta, GA.
