Modern safety features - "upgrading" from an older machine
/ Modern safety features - "upgrading" from an older machine #1
WinterDeere
Super Star Member
Rural 'burbs, north of Philly
John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
Okay guys, initiate me gently. I'm upgrading from a 1986 Deere 855 to a 2019 Deere 3033R. Obviously a more capable machine, but with the half hour of seat time I got between the various models I tested at the dealership, I'm really wondering how I'm going to adapt my work style around the safety and emissions features of this new tractor. I'm sure this is something many of you have already done, so I'm looking to learn from what you've learned.
The largest part of my work with my tractor involves driving a short distance and hopping off to do some quick work off the loader bucket while the machine idles. That may be picking up downed branches from my yard after a storm, raking out mulch in various garden in the spring, or moving firewood from the loader bucket to a firewood rack. Whereas I could hop on and off the old machine without doing anything other than taking my foot off the hydro pedals on the 855, it seems the modern machine must be sifted to neutral and then a hand brake applied. Additionally, there seem to be all sorts of warnings against idling, due to exhaust temp affecting the exhaust particulate filter.
I must have had the new machines turn themselves off on me a half dozen times, when my butt left the seat for one reason or another, something over which I've never had to worry with my old machine. Is this something you guys quickly got yourselves used to, something you disabled, or a "feature" that still frustrates you today?
/ Modern safety features - "upgrading" from an older machine #2
I’ve only ran a Deere machine briefly but I’d disabled that shift into neutral stupidity. I’m not a big fan of the seat safety either. I disabled it on my last tractor. Luckily neither of my backhoes had one.
/ Modern safety features - "upgrading" from an older machine #3
No neutral safety, no parking brake safety, no seat safety here. I can idle as long as I want (no more DOC).
/ Modern safety features - "upgrading" from an older machine #4
Disabling the seat switch will make life much more pleasant.
I agree, for myself. But what of liability, and kids or others using the machine?
/ Modern safety features - "upgrading" from an older machine #6
Shifting to neutral to dismount would be a non-starter for me. My tractor doesn't require neutral. The two situations that the seat switch kills the engine are when the hst pedal is pressed, and getting out of the seat with the PTO engaged. I can circumvent the PTO by tipping the seat forward, which allows unattended PTO use.
Anyway, old habits die hard. I suspect you will adapt and get used to your new machine. As far as idling dpf machines, I generally set the minimum rpm at about 1500 with the throttle lever, and let the coupled hst pedal manage the throttle above that for non PTO activity.
I don't let anyone operate my machinery, so if the seat switch bothered me sufficiently, I would not be against disabling it. There is a thread here somewhere that a user added a switch to disable or enable the seat switch, which may be of interest to you.
/ Modern safety features - "upgrading" from an older machine #8
Re: Modern safety features - "upgrading" from an older machine
Funny you should mention this, I had already thought of doing the same, perhaps even with a keyed switch. Today, I am the only person who uses my machine. But with two kids at home, I hope that changes soon, I'm getting too old to do all this work on my own! I'd like to not have safety features defeated when they're young and learning to operate.
/ Modern safety features - "upgrading" from an older machine #10
Generally new tractors over 25 horsepower will have a diesel particulate filter (DPF), tractors of under 25 horsepower do not. I have a 2019 L2501 Kubota and it's almost as straightforward and simple as my 1974 Mitsubishi. The only time I can't get off the seat without killing the engine is when the PTO is engaged. It is HST and I can leave it in gear with the engine running, not set the brake, and climb off with no problem. I know nothing about Deere other than they're green and yellow, oh and the new compact ones have Yanmar engines and are assembled in Augusta, GA.
/ Modern safety features - "upgrading" from an older machine #11
Some like their feet, others don't. Remember, HST machines can creep if they fall out of adjustment. Brakes are there for a reason.
/ Modern safety features - "upgrading" from an older machine #12
My 2016 3520h Branson has none of the safety features and I don’t mind because I respect the machine. When I need to get off the seat or run the chipper via PTO, I dig the grapple or bucket in the ground every time for good measure.
/ Modern safety features - "upgrading" from an older machine #13
I have a newer JD 2025r. Probably similar to yours in terms of safety items. Yes you have to put it in neutral but you don’t have to set the brake but should. I have 75 hours on mine and still forget sometimes.
If you are using the pto and back up you have to hit the switch before reversing. JD calls it RIO. That’s the one that bugs me. Every time I mow I forget at least a couple of times. On some machines this can be turned of using the LCD display.
/ Modern safety features - "upgrading" from an older machine #14
That's one thing mine does NOT have. I can change direction at will while mowing or tilling.
/ Modern safety features - "upgrading" from an older machine #15
Don't worry about idling. When your machine eventually needs a regen, it will perform it. The Kubotas start flashing an "RPM-Up" warning light if you aren't working at a high enough RPM, in addition to a light indicating a regen is occurring. Probably the Deeres have something similar. I've had two Kubotas with DPFs that perform regens and I've never worried about idling for too long. Last fall I was working out in the field trimming a waterline at night; I left my Kubota idling for an hour and a half just to provide lighting. Not a care in the world, and nothing bad happened to the machine, either. Idling a lot simply means the DPF will fill up a little faster with soot, and you'll need to regenerate more often. No big deal.
As far as safety features, does Deere "require" you to set neutral and the parking brake on an HST machine? I mean, if you DO engage neutral, the brake should definitely be on. But with an HST, it pretty much doesn't move. However, I'll make the following caveats to that statement:
-The tractor is more likely to roll the higher the HST range you are in (e.g. it will roll easier in High Range than Low range).
-On any type of slope, HST can still roll and the parking brake should be applied. Just use your head.
The seat safety switches can usually be defeated easily. However, I've never done it - you just get accustomed to getting out of the seat with the tractor stopped and your PTO off and your feet off the pedals.
Enjoy your new machine and post some pics!
/ Modern safety features - "upgrading" from an older machine #16
Before I would disable anything I would give it a month. It could become a "muscle memory" thing where you just do it without thinking. I shortened my ROPS so I could leave it up all the time. Now I fasten my seatbelt every time I move the tractor, it is just second nature. If after a month it still really annoys you do what you want.
Doug in SW IA
/ Modern safety features - "upgrading" from an older machine #17
Only slowly. A HST machine that you put in neutral can roll quite rapidly.
/ Modern safety features - "upgrading" from an older machine #18
The only safety I'm in favor of is the tractor shutting down the pto when your butt leaves the seat. If I somehow fall off the tractor while mowing, I want that mower deck turning off, just in case my hand or foot somehow wedges under that deck. Since I mostly don't mow with my massey tractor, I just disabled the seat safety switch altogether, so that takes care of everything.
On my craftsman tractor I mow with, I disabled the stupid RIO switch so I don't have to screw around with that anymore. But I found no way to disable the in-gear safety switch w/o also disabling the pto safety, so I just deal.
/ Modern safety features - "upgrading" from an older machine #19
My 2025R JD does not require you to set the brake when you get off of it but it does require it to be in neutral. I had mine start to roll away on me once when I didn't get the brake set. The Kubota BX I had before didn't require neutral to get off of it and if you were on flat ground it was never a problem just to hop off. I without a doubt want mine to shut off if my but comes out of the seat while the PTO is running, such as a tip over or if you fall off. The need to hit the pto switch to back up while the pto is running is stupid. How is it safer to look at the dash to find the pto button instead of just looking backwards?
/ Modern safety features - "upgrading" from an older machine #20
It's incredibly stupid and annoying! Every time you get off the seat, whether to move a branch or just your butt lifts off when you lean over or whatever, you gotta mess with moving the key back and forth and repressing the switch. In my case, I gotta do that often, so I was like screeeeew thiiiiiiiis!!!, found the rio switch where it mounts, ripped it out where the reverse pedal hits it, zip-tied it outta the way. End of story.
2019 ATLAS COPCO QAS 25 T4F NB-3 PHASE GENERATOR (A60429)
2019 ATLAS COPCO...
2022 BIG TEX 22GN-35BK+5MR T/A 48FT GOOSNECK TRAILER (A59906)
2022 BIG TEX...
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
2014 Aerway Aerator (A55973)
2014 Aerway...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
