My quick hitch is hydraulic
/ My quick hitch is hydraulic #1
PikaPika
FINLAND
Kubota L345 DT
WANT QUICK HITCH TO BE MORE FLEXIBLE
A ) THE TOP HOOK SHOULD BE EASILY ADJUSTABLE MANUALLY OR HYDRAULICALLY
B ) LOWER HOOK LATCHES SHOULD WORK AUTOMATICALLY
C ) LOWER HOOKS SHOULD BE ADJUSTABLE MANUALLY OR HYDRAULICALLY FOR
CAT 1 AND CAT 2 IF SUCH PROPERTY IS NEEDED
D ) ALL ADJUSTMENTS SHOULD BE DONE EASILY FROM THE TRACTOR CABIN
ALL THIS CAN BE DONE, BUT IS IT TOO COMPLEX?
Here is some of my prototypes: NEW QUICK HITCH - YouTube
Re: My quick hitch has hydraulic top hook and it is adjustable from cab for cat 1-2
WANT QUICK HITCH TO BE MORE FLEXIBLE AND UNIVERSAL
/ My quick hitch is hydraulic #3
Welcome to TBN.
Very unique. I've never saw anything like that. Could be further adapted to latch/unlatch hydraulically for larger tractors where reaching the latch is not possible.
I was thinking mostly the safety of driver and his handyman.
If we can hitch from the cabin then all right.
For small tractors my manual version could be enough.
For tractors cat 2 and cat 3 the hydraulic version is best.
For biggest tractors reaching the levers of hitch is impossible.
Then this hydraulic hitch is working best.
/ My quick hitch is hydraulic #5
IIRC, most quick hitches (aside from the Pats and their clones) latch without needing to be touched, if you have top and tilt, you should be able to hook up from the seat.
Unhooking, you need to flip up a latch on each side to let it unhook.
As for the rest, I am in favor of adapting your equipment to match the quick hitch...
Aaron Z
I tried to make all working automatic or from cabin.
I have hand latch in upper hook only for safety. Hydraulic upper hook itself keeps implement tight.
Lower latches open automatic when hydraulic upper hook goes to its uppers position.
They close by spring force.
/ My quick hitch is hydraulic #7
It one has all his implements set up properly and QH adjusted proper only time operator should have to leave seat is to release the implement when disconnection ( PTO on included) ... I think you have made a simple task unduly complicated...
Dale
Hello Dale and everybody QH interested
I understand when you have all your implements made QH-ready.
I have 10 old implements width 26-28 inches and height 22-27,5 inches, non standard
If all implements had same width then it was much easier to make the hitch. No width linkage needed.
Anyway I like my hydraulic upper hook and hydraulic top link. Lower latches works automatically under mud and ice 2 feet snow on my implement in winter.
In Europa people do't know QH. Most they have extendable 3-pt arms or lower links with quick couplings , like LH
Quick Coupler Hooks | LH Lift
I made many trials. Here is one like PAD's but hooking/unhooking from tractors seat.
/ My quick hitch is hydraulic #9
I admire your engineer thoughts. :cool:
/ My quick hitch is hydraulic #11
Yeah, and in Europe they drive on wrong side of the road....
Dale
Nope, that's only England. In mainland Europe they drive on the correct side of the road like we do here in the US. Its "fun" taking a British car across the channel & driving on the right side of the road from the wrong side of the car.
/ My quick hitch is hydraulic #12
Very impressive! That's a quick hitch done right!
Thank You mpsmith60 and others replying!
There is much speak of pin bushings in old posts.
Can we leave these out?
If hitch hooks have milled groves for both cat 1 and cat 2 then it can be possible.
I hope you see my picture.
Here is one of my early hitches that can be able to keep implement tight as a bear.
For me this is working.
/ My quick hitch is hydraulic #14
This hitch is ingenious! I know it must have taken tons of time, imagination and perseverance. I never imagined anyone could do this. Thanks so much for sharing.
Thanks mpsmith60, Kelly, Oldold , Allen, Dl Meisen, aczlan and DiyMyWay your replays
Kelly asked steering from cabin. It works fine. Here is one example:
Farm valve - Piippohydraulic
They have 6 solenoid valves for 6 cylinders in one hydraulic body.
They make hydraulic stabilizer bars too. See the video,
Allen asked the fabrication of my QH. I do not now.
It needs thousands of people to seek such QH.
Markus
Markus
Many companies are seeking best method of hooking/unhooking implements.
I found two interesting hitching systems.
John Deere: Connect and Go: The 4R Series Hitch Assist - YouTube
Gangsystems: Das Schlepperdreieck vom Technologieführer ✭✭✭✭✭ | innovative Technik ✔ | 100% Made in Austria ✔
My own universal: UNIVERSAL QUICK HITCH FOR TRACTORS - YouTube
At the end of my video is my patent pending.
I made about 12 different hitches and some with quick coupler to lower links.
Markus
Gangsystems: Das Schlepperdreieck vom Technologief?rer ✭✭✭✭✭ | innovative Technik ✔ | 100% Made in Austria ✔
Markus
Thank You for watching! Like to hear Your opinions.
If we want to use both cat 1 and cat 2 implements by quick hitch without any sleeves,
then hooks and latches needs very little redesign.
These hooks can take both pin sizes, cat 1 or cat 2.
My hitch can have those hooks.
Markus
Markus
Here is better picture
Mr kylemorley wrote in Yestrday' Tractor:
"I dream of some self centering quick hitch that would allow simply backing up to the implement and instantly hitching all three points, and disconnect with a single pull of a lever. I gather they do exist, but would cost more that the tractor".
I agree that. The price should be hundreds not thousands !!
I myself tried to go two ways:
a) first QH UNIVERSAL QUICK HITCH FOR TRACTORS - YouTube
b) secondly with lower link couplers and manual stabilizer bars, all adjusted from cabin.
Want more talk of fast 3-point hitching
Markus
2007 KENWORTH T800 QUAD/A DUMP TRUCK (A59914)
2007 KENWORTH T800...
2007 FREIGHTLINER CL120 6x4 T/A DAY CAB TRUCK TRACTOR (A59914)
2007 FREIGHTLINER...
John Deere 620 Quick Attach Loader with Bucket (A65640)
John Deere 620...
2016 Ford F-350 Pickup Truck (A62613)
2016 Ford F-350...
2007 International 4300 S/A Dump Truck (A64556)
2007 International...
2012 PETERBILT 386 (INOPERABLE) (A65643)
2012 PETERBILT 386...
