My quick hitch is hydraulic
   / My quick hitch is hydraulic #11
Yeah, and in Europe they drive on wrong side of the road....
Dale
Nope, that's only England. In mainland Europe they drive on the correct side of the road like we do here in the US. Its "fun" taking a British car across the channel & driving on the right side of the road from the wrong side of the car.
   / My quick hitch is hydraulic #12
Re: My quick hitch has hydraulic top hook and it is adjustable from cab for cat 1-2
WANT QUICK HITCH TO BE MORE FLEXIBLE AND UNIVERSAL
A ) THE TOP HOOK SHOULD BE EASILY ADJUSTABLE MANUALLY OR HYDRAULICALLY
B ) LOWER HOOK LATCHES SHOULD WORK AUTOMATICALLY
C ) LOWER HOOKS SHOULD BE ADJUSTABLE MANUALLY OR HYDRAULICALLY FOR
CAT 1 AND CAT 2 IF SUCH PROPERTY IS NEEDED
D ) ALL ADJUSTMENTS SHOULD BE DONE EASILY FROM THE TRACTOR CABIN
ALL THIS CAN BE DONE, BUT IS IT TOO COMPLEX?
Here is some of my prototypes: NEW QUICK HITCH - YouTube
Very impressive! That's a quick hitch done right!
Thank You mpsmith60 and others replying!
There is much speak of pin bushings in old posts.
Can we leave these out?
If hitch hooks have milled groves for both cat 1 and cat 2 then it can be possible.
I hope you see my picture.
Here is one of my early hitches that can be able to keep implement tight as a bear.
For me this is working.
   / My quick hitch is hydraulic #14
This hitch is ingenious! I know it must have taken tons of time, imagination and perseverance. I never imagined anyone could do this. Thanks so much for sharing.
Thanks mpsmith60, Kelly, Oldold , Allen, Dl Meisen, aczlan and DiyMyWay your replays
Kelly asked steering from cabin. It works fine. Here is one example:
Farm valve - Piippohydraulic
They have 6 solenoid valves for 6 cylinders in one hydraulic body.
They make hydraulic stabilizer bars too. See the video,
Allen asked the fabrication of my QH. I do not now.
It needs thousands of people to seek such QH.
Markus
Markus
Many companies are seeking best method of hooking/unhooking implements.
I found two interesting hitching systems.
John Deere: Connect and Go: The 4R Series Hitch Assist - YouTube
Gangsystems: Das Schlepperdreieck vom Technologieführer ✭✭✭✭✭ | innovative Technik ✔ | 100% Made in Austria ✔
My own universal: UNIVERSAL QUICK HITCH FOR TRACTORS - YouTube
At the end of my video is my patent pending.
I made about 12 different hitches and some with quick coupler to lower links.
Markus
Gangsystems: Das Schlepperdreieck vom Technologief?rer ✭✭✭✭✭ | innovative Technik ✔ | 100% Made in Austria ✔
Markus
Thank You for watching! Like to hear Your opinions.
If we want to use both cat 1 and cat 2 implements by quick hitch without any sleeves,
then hooks and latches needs very little redesign.
These hooks can take both pin sizes, cat 1 or cat 2.
My hitch can have those hooks.
Markus
Markus
Here is better picture
Mr kylemorley wrote in Yestrday' Tractor:
"I dream of some self centering quick hitch that would allow simply backing up to the implement and instantly hitching all three points, and disconnect with a single pull of a lever. I gather they do exist, but would cost more that the tractor".
I agree that. The price should be hundreds not thousands !!
I myself tried to go two ways:
a) first QH UNIVERSAL QUICK HITCH FOR TRACTORS - YouTube
b) secondly with lower link couplers and manual stabilizer bars, all adjusted from cabin.
Want more talk of fast 3-point hitching
Markus
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
2012 DRAGON 150BBL ALUMINUM VACUUM TANKER TRAILER (A52472)
2012 DRAGON 150BBL...
2023 JACTO JATAO-1000 LOT NUMBER 70 (A53084)
2023 JACTO...
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
