I have a really off the wall question about trenching an underground wire
/ I have a really off the wall question about trenching an underground wire #31
Instead of bury Cat6, why not just use a wireless bridge? I have a wireless bridge run to our barn at about 400'. I'm running 10 cameras on it without issue. Still have enough bandwidth when we are in the barn to be able to stream music or videos to our phones. Simpler/faster/cheaper than running the wire. 10 minutes I can set a bridge up and have internet service in the out building.
What bridge are you using, I致e been looking at doing something like this?
Yes, please jwstewar - what brand and model are you using?
/ I have a really off the wall question about trenching an underground wire #32
Does this work in a metal barn? (meaning walls, roof, and doors are all metal)
/ I have a really off the wall question about trenching an underground wire #33
You are gonna need a window or an outside antenna.
/ I have a really off the wall question about trenching an underground wire #34
Or a weatherproof outdoor bridge that can use a wired antenna for inside.
/ I have a really off the wall question about trenching an underground wire #35
Not answering your question... but I'd simply go wireless. No muss, no fuss.
Last time I wired my entire house, every room, with Cat 6, within 6 months all that expense and work was wasted. Wireless eliminated the need totally.
/ I have a really off the wall question about trenching an underground wire #36
AND for those that are interested, the wireless eliminates the RFI (Radio Frequency Interference) that is inherent in using copper cable for Ethernet. Since I am a big HF radio enthusiast I appreciate getting rid of all the Ethernet radiation from the copper cable. Yes, I managed to suppress a good deal of it with proper ferrite chokes, but it was an expensive hassle that is easily eliminated by using the 2.4 Ghz or 5 Ghz wireless router. So not only easier and cheaper to use wireless to start with, but it is also "greener" for the "environment" from a RF pollution standpoint. Ironic isn't it.
/ I have a really off the wall question about trenching an underground wire #37
AND for those that are interested, the wireless eliminates the RFI (Radio Frequency Interference), in the HF band, that is inherent in using copper cable for Ethernet. Since I am a big HF radio enthusiast I appreciate getting rid of all the Ethernet radiation from the copper cable. Yes, I managed to suppress a good deal of it with proper ferrite chokes, but it was an expensive hassle that is easily eliminated by using the 2.4 Ghz or 5 Ghz wireless router. So not only easier and cheaper to use wireless to start with, but it is also "greener" for the "environment" from a RF pollution standpoint. Ironic isn't it.
I fixed it for you. ;)
/ I have a really off the wall question about trenching an underground wire #39
Quote Originally Posted by k0ua
AND for those that are interested, the wireless eliminates the RFI (Radio Frequency Interference), in the HF band,...
What's the Harbor Freight band?
Bruce
/ I have a really off the wall question about trenching an underground wire #40
Despite posting on other threads today, OP hasn't returned to this one to explain what type of device would be in use or if there is utility power at the distant end.
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A58216)
1994 SHOP MADE...
CFG Industrial MX15RX (A60463)
CFG Industrial...
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
2014 Dodge Journey Van (A59231)
2014 Dodge Journey...
Giyi PG72 QA 72" Grapple (A60463)
Giyi PG72 QA 72"...
