wont lift pallet
/ wont lift pallet #1
BalsomsViewFarm
northern nh
kioti ck4010se
Built a pallet fire wood box. Tried to lift it with slip on pallet forks, no luck. Think of getting a quick attachment with forks to get the weight closer to the tractor?
/ wont lift pallet #2
What does the box weigh empty? Did you try loaded or unloaded?
If you mean forks that clamp onto the front of the FEL, there have been a few threads about that not being very efficient at lifting.
/ wont lift pallet #3
How big is the box? And yes SSQA forks would be a lot better.
/ wont lift pallet #4
My itty bitty SCUT will lift 800 pounds at the FEL..... Think your tractor might have a problem that even a SSQA is not going to help....
(before everyone gets their panties in a twist, this was staged [under controlled conditions] as an example for need of ballast box)
520 pound (by JD manual) mower..... Need to have rear ballast box to do it though....
Dale
/ wont lift pallet #6
Pictures? Size of tractor? Need more details
/ wont lift pallet #7
Insuffecient information.
/ wont lift pallet #8
What was the nature of your "no luck" - rear tires lifted or pressure relief valve kicked in? You have a good size tractor so it should be able to lift a good load. Even without more details, getting the load closer to the loader pins will make a significant improvement, but you also must have a counter weight on your 3pt hitch such as a heavy implement or a heavy ballast box.
/ wont lift pallet #9
also need to take into account the weight of a true pallet forks attachment. if i remember mine comes in at like 400# without anything on the forks. Whats the lift capacity of your tractor
/ wont lift pallet #10
The bucket and the clamp on forks almost certainly weighs more than the dedicated forks.
/ wont lift pallet
Some info, CK4010SE , 40hp lift capacity 1930 lbs. Backhoe on tractor. Wood box 42hx48wx48d. Would rather keep backhoe on for ballast. Have 6 of these boxes made and full. My plan was to store them in the big barn and take them into the garage as needed. Still have a few more to make and fill so taking some wood out of the full ones might work with quick hitch forks instead of the clamp on ones. Thanks for the suggestions.
/ wont lift pallet #12
Google says a cord of seasoned wood weighs 2000 to 3500lbs (128 cu. Ft.). Dry / Green weight table
Your 56 cu.ft. might weigh 1500lbs - a guess. SSQA Forks will work way better than clamp on forks lifting that kind of weight, and you have a backhoe (900lb) for counter balance. Your quoted lift capacity is at the pins, but this load will average 2 feet out on forks so you may have reduce the amount of wood slightly even with SSQA forks. Hopefully someone else doing exactly the same think can confirm.
Maybe your Kioti dealer would let you test a set of forks. Any neighbors with a set? Moving wood into you garage on pallets as needed this winter will reduce handling soooo much. I'd go for it.
/ wont lift pallet #13
My Branson 3725's loader has a listed capacity of 2100 lbs at full height. It will lift an IBC tote cage full of just split hardwood without issue though I have not tried lifting it to full height. I'm using SSQA forks from palletforks.com. An IBC tote cage is about the same size as your boxes.
/ wont lift pallet #14
If all else fails, get a couple of straps,
run them under your boxes and then bring your loader in over the boxes,
(remove your bucket first) then using the straps fasten onto the torque tube (cross member) on your loader.
You should be able to easily lift your boxes then.
/ wont lift pallet #15
Very good idea.
BTW, I Use IBC totes to carry wood and SSQA pallet forks with no problems but my lift capacity is higher. 2700 at the pins.
I made some carriers out of cut down pallets. Better off using something 32" deep (two rows of wood) so the load is closer to the pins. Increase height to what your loader will safely handle. I went 60" with the scraps I had, but can go higher.
/ wont lift pallet #16
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
2018 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A61572)
2018 Takeuchi...
1998 PITTS LT-40-8L 4 BOLSTER LOG TRAILER (A64276)
1998 PITTS...
2020 INTERNATIONAL LT625 SLEEPER (A59910)
2020 INTERNATIONAL...
2023 SANY SY225C EXCAVATOR (A63276)
2023 SANY SY225C...
2005 John Deere 7320 (A60462)
2005 John Deere...
