wont lift pallet
   / wont lift pallet #1
BalsomsViewFarm
northern nh
kioti ck4010se
Built a pallet fire wood box. Tried to lift it with slip on pallet forks, no luck. Think of getting a quick attachment with forks to get the weight closer to the tractor?
   / wont lift pallet #2
What does the box weigh empty? Did you try loaded or unloaded?
If you mean forks that clamp onto the front of the FEL, there have been a few threads about that not being very efficient at lifting.
   / wont lift pallet #3
How big is the box? And yes SSQA forks would be a lot better.
   / wont lift pallet #4
My itty bitty SCUT will lift 800 pounds at the FEL..... Think your tractor might have a problem that even a SSQA is not going to help....
(before everyone gets their panties in a twist, this was staged [under controlled conditions] as an example for need of ballast box)
520 pound (by JD manual) mower..... Need to have rear ballast box to do it though....
Dale
   / wont lift pallet #6
Pictures? Size of tractor? Need more details
   / wont lift pallet #7
Insuffecient information.
   / wont lift pallet #8
What was the nature of your "no luck" - rear tires lifted or pressure relief valve kicked in? You have a good size tractor so it should be able to lift a good load. Even without more details, getting the load closer to the loader pins will make a significant improvement, but you also must have a counter weight on your 3pt hitch such as a heavy implement or a heavy ballast box.
   / wont lift pallet #9
also need to take into account the weight of a true pallet forks attachment. if i remember mine comes in at like 400# without anything on the forks. Whats the lift capacity of your tractor
   / wont lift pallet #10
The bucket and the clamp on forks almost certainly weighs more than the dedicated forks.
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
2019 CATERPILLAR 289D3 SKID STEER (A51246)
2019 CATERPILLAR...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
8065 (A51572)
8065 (A51572)
