wont lift pallet
   / wont lift pallet #1
BalsomsViewFarm
northern nh
kioti ck4010se
Built a pallet fire wood box. Tried to lift it with slip on pallet forks, no luck. Think of getting a quick attachment with forks to get the weight closer to the tractor?
   / wont lift pallet #2
What does the box weigh empty? Did you try loaded or unloaded?
If you mean forks that clamp onto the front of the FEL, there have been a few threads about that not being very efficient at lifting.
   / wont lift pallet #3
How big is the box? And yes SSQA forks would be a lot better.
   / wont lift pallet #4
My itty bitty SCUT will lift 800 pounds at the FEL..... Think your tractor might have a problem that even a SSQA is not going to help....
(before everyone gets their panties in a twist, this was staged [under controlled conditions] as an example for need of ballast box)
520 pound (by JD manual) mower..... Need to have rear ballast box to do it though....
Dale
   / wont lift pallet #6
Pictures? Size of tractor? Need more details
   / wont lift pallet #7
Insuffecient information.
   / wont lift pallet #8
What was the nature of your "no luck" - rear tires lifted or pressure relief valve kicked in? You have a good size tractor so it should be able to lift a good load. Even without more details, getting the load closer to the loader pins will make a significant improvement, but you also must have a counter weight on your 3pt hitch such as a heavy implement or a heavy ballast box.
   / wont lift pallet #9
also need to take into account the weight of a true pallet forks attachment. if i remember mine comes in at like 400# without anything on the forks. Whats the lift capacity of your tractor
   / wont lift pallet #10
The bucket and the clamp on forks almost certainly weighs more than the dedicated forks.
2023 EAST TEXAS TRAILER (A52472)
2023 EAST TEXAS...
2019 Dodge Challenger GT AWD Coupe (A51694)
2019 Dodge...
2011 Kenworth T300 Jerr-Dan 21WSRB Rollback Truck (A52377)
2011 Kenworth T300...
TOOLBOX (A52472)
TOOLBOX (A52472)
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
100 GAL FUEL TANK W/PUMP (A52472)
100 GAL FUEL TANK...
