Found a great chainsaw sharpener
/ Found a great chainsaw sharpener #1
gsganzer
Elite Member
Sunset, TX
L3800 w/FEL and BH77, BX 2200 w/FEL and MMM
I've spent a bunch of time sharpening my chainsaws over the years. Back when I was a certified arborist going through college, it used to be a breeze to whip out a round file and touch up a saw freehand during gas-ups or breaks. I'm real particular on having a sharp saw and as I've gotten older, I don't use a chainsaw frequently enough to stay proficient with a file and get the edge and symmetry I prefer. So I went on a quest for a better alternative.
I ruled out the bench sharpening models, because I want to be able to touch a saw up in the field and I couldn't justify spending $200+ for an Oregon bench model and figured the cheaper knock-offs are probably junk. I looked at some of the various jigs and file fixtures and couldn't see where I'd get much improvement over my free-hand method or they looked like a convoluted contraption that would just lead to frustration.
One sharpener that kept popping up in my research was the Timberline Chainsaw Sharpener. So on a whim and crossed fingers, I splurged and bought one the other week. I had a chance to use it over the weekend and man am I impressed!:cool2: Rarely do you find a tool that actually works as simply and as well as this one does. At about $140 it's not cheap, but it gives you the portability to sharpen in the field with precision that would be unmatched with a hand file. And because it actually machines the tooth with a carbide cutter, you don't risk overheating teeth like can happen with the abrasive wheel grinders.
Look at some of the reviews on-line and you'll get some great feedback and info on how this sharpener works. I would recommend you start with a new chain, I don't think you'd want to waste your time trying to true up an old chain. Also, take your time to "bed" or "seat" the chain/cutter the first time you use it on a new chain. After the first "seating", using the sharpener is a breeze for all the subsequent sharpening's. Replacement carbide cutters are a little pricey at around $25, but they're supposed to last for 40+ sharpening's. I think you'd probably go through at least 3- 5 round files with that same number of sharpening's (I like a sharp file), so the replacement cutter price isn't too out of line. I haven't had to use it on a damaged chain (hitting metal nails or rocks). In that instance, you might still need to "dress" the damage with a round file, to save some wear and tear on the carbide cutter. Like I said, I haven't had to find out yet, but the carbide cutter could certainly repair a damaged tooth.
I thought I'd let some others know about a great product that actually works as simply as it's touted and gives results beyond expectations.
/ Found a great chainsaw sharpener #3
I put one of those on my Christmas list last year but they couldn't find one so they replace my old Dremel which had died. That's OK by me as I can do a very good job sharpening my chain saw with the Dremel and the proper sized grinding stones.
/ Found a great chainsaw sharpener #4
I see them for $99.00 at logging/sawmill shows... I've used one, after a small learning curve, it worked pretty good...
SR
/ Found a great chainsaw sharpener #5
I bought one last year and agree with you the sharpener is a great product.
/ Found a great chainsaw sharpener #6
They are great, fast and accurate. I highly reccomend the Timberline sharpener.
/ Found a great chainsaw sharpener #7
I love mine as well.
/ Found a great chainsaw sharpener #8
A co-worker just bought his first saw and I'm encouraging him to get this for sharpening. Partly so i can borrow it.
If I didn't have two grinders and two file kits I'd buy it.
/ Found a great chainsaw sharpener #9
Looks like a great tool. I've used an Oregon bar mounted file system for years. It sets the angle, depth, and even levels the rakers. Works good, but maybe not quite as slick as this system.
/ Found a great chainsaw sharpener #10
That thing looks pretty slick. I'll probably pick one of those up.
/ Found a great chainsaw sharpener #11
I also bought a timberline chainsaw sharpener with 7/32" Carbide Cutter reading this source 1 Best Chainsaw Sharpeners to Buy in May 219: Top Choices Reviewed A simple turn of the crank will move the chain through the stones, easily cutting them down for any chain with a 30-degree angle.Lets hope it lasts for longer period,It has a other version also with 3/16'' it depends on type of your needs.
/ Found a great chainsaw sharpener #12
Cuban,
Look at one of these:
https://www.amazon.com/Pferd-Chain-Sharp-Filing-Guide/dp/B003M4JLE2/ref=asc_df_B003M4JLE2/?tag=bingshoppinga-20&linkCode=df0&hvadid={creative}&hvpos={adposition}&hvnetw=o&hvrand={random}&hvpone=&hvptwo=&hvqmt=e&hvdev=c&hvdvcmdl={devicemodel}&hvlocint=&hvlocphy=&hvtargid=pla-4583726540700757&psc=1
I like that it does the rakers as the same time, does not require power, and does not require chain to be removed.
It will not yield the best possible sharpening but its ease of use and price makes it a good option for the occasional user. I went with it after a lot of research. I am a terrible hand filer. I have the Granberg unit and it is OK, but a bit cumbersome, and it requires the rakers to be addressed with a secondary operation.
My buddy raves about the cheap Harbor Freight electric unit. He has 4 or 5 chains and just switches them out in the field. I plan on using it on one of my old chains to see how it performs. Still, giving the chain a quick couple of strokes with the Pferd between tankfuls will be worth doing before waiting until the chain is dull. I have not used the Pfred after hitting a rock so cannot comment on how it works with a damaged chain.
/ Found a great chainsaw sharpener #13
Thanks, just ordered one direct from Timberline about $100 cheaper than local suppliers.
/ Found a great chainsaw sharpener #14
Looks like it'll do a heck of a lot btr. job than my old eyes and cramped up hands will ever do. Seen video, now to talk the boss into buying one. We cut our own firewood (white / red Oak), i get from sawmill. Some logs have a nail/wire etc in them, mostly so far it's been just one or two nails per log, if any. I do have a chain for each saw, just for that situation, must wear your ppe though. Learned something here, thanx
/ Found a great chainsaw sharpener #15
I can’t help but be suspicious of some of these product review websites. I know some of them are sponsored or funded by the companies making the products. Plus, this one mentions the cutting stones in the Timberline sharpener. There are no stones, it uses a carbide cutter. I wonder how thorough their reviews really are.
/ Found a great chainsaw sharpener #16
They work pretty good for a maintenance sharpening but for restoring a chain after cutting nails I think you’ll be disappointed.
/ Found a great chainsaw sharpener #17
I've had my Timberline for about a year now. I really like it.
/ Found a great chainsaw sharpener #18
Just for my own curiosity: what sort of adjustments (if any) need to be made to use it with chains of different pitches?
I currently have a mix of 3/8 low profile, and .325 pitch chainsaws/polesaws I use around the house and have been casually looking for a quicker/easier way to sharpen them (beyond the 3-in-1 chain sharpens that Stihl and Pferd make). I may not need to cut stuff often, but when I do it's generally not light work (and it's highly preferable to spend more time cutting & less time sharpening).
/ Found a great chainsaw sharpener #19
I think you’ll need a different carbide and guide. I only have 2 saws and I put 3/8 full chisel on the smaller one which is really too much chain for a 50cc saw but it eliminated the sharpening issue.
/ Found a great chainsaw sharpener #20
Only adjustment with the Timberline is a different size carbide bit for each pitch. I sharpen 1/4" pitch (1/4" carbide bit) and .325" (3/16" carbide bit) with mine.
2021 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2021 CATERPILLAR...
2022 21ft Scout 210 Dorado Boat with 2011 18ft Magic S/A Boat Trailer (A64557)
2022 21ft Scout...
2022 EZ-GO ELITE...
2025 60in Bucket Skid Steer Attachment (A64553)
2025 60in Bucket...
(UNUSED) JOHN DEERE RC10R ROTARY MOWER (A64278)
(UNUSED) JOHN...
2022 EZ-GO ELITE...
