Buying Advice *UPDATE* Just tell me what to buy!
/ *UPDATE* Just tell me what to buy! #21
Interesting, so my Kubota Grand L3560 (weight is listed as 3880) and I have the tires filled (around additional 800lbs) would be enough weight wise to pull the disc. (Yes I'm new to tractors and still learning.)
Weight of a cab is about 700 pounds, approximately the same as loading rear tires. As you have the cab I recommend inflating tires with air. There is only so much 37 horsepower can do.
LINK: https://www.tractorbynet.com/forums/attachments/332493-tandem-lift-disc-harow-monroe.html?highlight=
You are probably aware to level ground with a Disc Harrow you need to pull at a good clip.
I pull the Tufline with 20" pans in HST/PLUS MEDIUM, toggling between MEDIUM/HIGH and MEDIUM LOW as necessary. Cannot go faster and remain in the tractor seat.
ADJUSTMENT: https://www.tractorbynet.com/forums...ing-three-point-hitch-mounted.html?highlight=
/ *UPDATE* Just tell me what to buy! #22
This might sound a little simpleton.....but it was my thought process.
I don't know the real number but let's say I cut 100 acres of general pastures. Ride can be smooth in areas and....can be bumpy in areas.
I decided that if I buy a new tractor, my thought process is going to be first, to look at the front tires as I want a machine with larger front tires to help smooth out the ride.
Plan & simple as that.
Well, that was my goal.... I ended up finding a good value so bought an International 1066 which by my definition, has the small front tires. Still, with the very large rears it rides pretty good.
My JCB has the smaller implement front tires and when I hit some divots, I wish it had larger tires.
(someone dug some stumps out decades ago so there are little surprises in various areas. I've learned over time where they are so can manage them but still, a larger tire would ride over them easier)
So that's how I'd do it if I were you.....who's got the biggest, baddest front tires?!!!
Maybe I can just drive in reverse?!? Jk.
Thanks for all the responses. One thing I’ve gathered from all my research is that it’s hard to go wrong. I mean, everyone seems to love their tractor regardless of brand and size. It just goes to show that tractors may be one of the best tools a person can buy.
I’m a firm believer that having the right tool makes you want to tackle the job. Im doing so much work on this house and property just to be able to move in. I told my wife that I fear moving in and just being ‘done’ with all the work. Living in a 5 acre weed patch. It’s my biggest motivation to get a utility tractor. Every project we’ve discussed for after we move in would be a whole lot easier with a tractor.
Moving on to a different topic, what kind of margin is there in tractors. I’ve got a quote for 41k for DK4710SE Cab with some extras and a backhoe. If I offer 38k, would that be out of line?
/ *UPDATE* Just tell me what to buy! #24
What kind of margin is there in tractors. I致e got a quote for 41k for DK4710SE Cab with some extras and a backhoe. If I offer 38k, would that be out of line?
Pose this question in the KIOTI BUYING/PRICING FORUM.
List options. "Some extras" is not enough description.
Be aware that pricing varies by region, with California supporting the highest prices.
If someone tells you they got "X" price in in Georgia, where tractor is imported and assembled, you should not expect the same price in distant California.
I believe they were:
- Top and Tilt
- 3rd Function Valve
- Link Pedal
- HST cruise
- Armrests
/ *UPDATE* Just tell me what to buy! #26
Go with the DK, with a cab, or even the NX. My ck works well for what it is, but, given a do over, I would go at least to the DK frame size.
These tractors have a lot of plastic in the instrument panels and I wonder about the long term effects of weather exposure on them.
Plus, the cab makes all weather operating more pleasant.
Forget the backhoe. Rent, borrow, or buy a mini for trenching work. The mini excavator is superior to an add on backhoe.
/ *UPDATE* Just tell me what to buy! #27
My hoe was a 6500 dollar add on, ,cant buy a mini for that, I have it whenever I want it :thumbsup:,,,
I have not dug a hole with a shovel since 2013.
/ *UPDATE* Just tell me what to buy! #28
Thanks for the warm welcome and thanks grm61 for answering my question of what to buy. I値l get a Kioti NX 5010 with a cab.
I had a great time here.
Close thread.
Hmmm... not sure what to think here. A couple hours after posting you are set to buy. :confused3:
Are you being sarcastic or??? I see you continue to participate so I am not sure. I hope you came here for some honest experienced discussion.
[/COLOR]
Yes I agree. It’s the most expensive, yet I actually see myself using it a lot. Hard to stomach, but will probably regret not getting it.
/ *UPDATE* Just tell me what to buy! #30
I just purchased our family a house on a modest 5 acres. It痴 got some hills, some pasture, some trees etc.
I have owned a Max 28 for approximately 5 years, 28HP - 22HP PTO, and although it does just what I need, there are times when it is lacking.
It will haul 60" Attachments, the Brush Cutter works great with this setup, the Box Blade works but fills up and this 28HP Tractor starts to stumble, I haven't really used the Grader/Scraper Blade for the road, I've tried it, but I can't tell you the full impact on the tractor but the 28HP appears to work ok in Low Range. My next and maybe last Attachment that I still haven't purchased, will be the Post Hole Digger, not even sure my 22HP PTO and 2800 lbs. will do the job or not (Hard Clay in my area).
If I was to get a new Tractor or could start over, the Tractor would be at least a 35 to 45 HP, and 50% to 100% heavier than the Max is, (2800 lbs.), so I would be looking for 4000 to 5000 lbs Tractor.
I always believe in buying larger than what is needed, but in the Max28 case, I purchased by the specifications posted by the Manufacturer, not the best move because it won't even pickup what my smaller tractor did before I sold it, the SC2450 (Used it in New England, small jobs, to move snow and dirt in approximately 2 acres.
This post may not help much but the idea is to make sure you get it big enough, so you don't regret it later on. Once you decide on a specific model/weight Tractor that should work, go one higher.
Ltr
Novice Tractor Owner/Operator
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
Mower King ECSSTR072 (A60463)
Mower King...
2016 Land Rover Discovery Sport 4WD SUV (A61569)
2016 Land Rover...
2022 John Deere 1025R (A53317)
2022 John Deere...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2017 CATERPILLAR 816K LANDFILL COMPACTOR (A59823)
2017 CATERPILLAR...
