Buying Advice *UPDATE* Just tell me what to buy!
   / *UPDATE* Just tell me what to buy! #41
I think all the posts and Thejoj are getting out of bounds and have forgotten the size of the property. There is no way a 5 acre plot needs a 50 HP tractor to perform maintenance on it. In California, what does he need with a $5000 cab add on to his tractor, surely not for blowing snow and a little sweat does the body good in summer. I rarely use my cabbed tractor and the heat doesn't bother me and I am 70 years old.
Get back to reality folks, a B2650 Kubota (or equivalent in any brand) is at the top of the line as far as needed HP goes.
Since most of the CUT brands out there are very good tractors, go for the one that suits your rear end and body size AND your wallet. Ergonomics should be the guide for what tractor you buy, followed by Price and lastly dealer. Lots of folks put the dealer in the top position, but truly, most of the time, tractors never return to the dealer for service if the owner is in any way mechanically inclined.
If you cant turn a wrench or have no intention, then put the dealer second although dealer and price might go hand in hand.
   / *UPDATE* Just tell me what to buy! #42
I just noticed you are in Clements. I'm in Sonora. I always make sure to go through Lockford and get sausage. That place is the best.
Your reference to the smaller dealer is probably those guys at A1. I would agree they are very helpful and where I purchased my tractor recently.
I think for 5 acres you would find the ck3510 to be plenty of tractor for your needs. It's very capable machine. I have 20 acres and it does 99% of what I want. There is always some monster rock or giant oak stump that will need a way larger tractor. That's when you rent an excavator or a dozer and just do it the right way. For basic clearing and land maintenance a 30-40 hp tractor is all you will need.
Don't get me wrong a larger tractor is always nice. But how often will you need more than 28hp for PTO implements or need to lift and move around things over 1500 lbs?
Almost 3 year update:
Still have and love the CK3510SE HST . Over 250 hrs and no problems. I have used the following implements equally:
- Forks
- Grapple
- Loader bucket
- Box blade with rippers
- Flail Mower
- Disc
Won’t get rid of any of them.
I can’t imagine not having the following features:
- Hydro Transmission
- Spring Seat
- Linked Pedal
- Hydraulic top and tilt. This is mandatory.
- Telescopic lower arms for hooking up 3 point attachments.
- Skid steer quick connect
- Side view mirrors
Things I wish it had:
- Gas tank under body instead of up high behind head. I use gas cans and its a pain to stand on the rear implement and try to balance.
- USB charger and maybe some storage on the sides of the dash for a phone/keys/etc. I know there is a couple little holders below the seat, but they always seem full of dirt, rain water, twigs, etc.
- Entry step on both sides instead of one.
- More storage/better toolbox. Would love to carry some straps, chain and shackles at all times. I help my neighbors out a lot and would like more essentials with me.
Things it has but I never use:
- Cruise control? or whatever it was supposed to be. Never found it useful, but maybe I’m doing it wrong. Didn’t seem to hold speed, just rpms if I remember correctly.
- Cup holder. Too bouncy a ride, spills everything. Then when you go to drink something, the lid is full dust. Wah poor baby…
- Draw bar. Took it off and have never needed it. Also, if I had a PTO implement on and it dropped low enough, the plastic cover on the PTO shaft would hit the end of the draw bar and shred it. Also, I have a UTV with 2” ball to move around trailers and such.
- Plastic toolbox. Took it off, pretty much useless.
- Safety shutoff when getting off seat. Bypassed it.
Things I was worried about before buying:
- Not enough power. It does everything I ask of it. Will it move earth like a skip loader? No, but it has plenty of power going up my hills while pulling a disc or with a full load in the bucket.
- DPF Filter burn off. Never was an issue or an inconvenience, rarely ever happens.
- Should i get a cab? Maybe. I thought weather was why I needed it, but I live in CA. If weather is ‘bad’, I don‘t use the tractor. Simple enough. The only time I kinda wished I had it is when I was clearing some big brush/small trees at my neighbors. Stuff was falling alol over me for 3 days. I guess it could keep my beer dust-free…
- Do I really need a flail mower instead of a rotary? I think so. I mow around trees and in tight spaces that I couldn’t do with a rotary. Although, I need to replace the knives after a couple years, but I think I finally found all the hidden rocks, metal and barbwire. Which makes a good point, the flail allows you to lift the 3 point up and tilt it(with hydraulic top arm) so that you can get off the tractor and see everything in there at waist height. I‘ve had to stop and unravel barbwire, garden hoses, etc. I would think you would be lying on your back to do this on a rotary? Not sure though.
- Is getting a Kioti over a Deere or Kubota a mistake? Doesn’t appear so, and to be honest, I may be a lifer. However, if their prices were all the same, it would be a tougher decision.
- Will I regret not getting the backhoe attachment? Maybe. I can think of a few instances where I would have tried it. Would I have been successful or frustrated? Still need to try one to find out its power and how tedious it is to move around on. I resorted to renting a mini ex a couple times.
Implements I want to try and wouldn’t mind your feedback:
- 3-point post hole digger. Do they make one that could mount to the skid steer attachment and use the 3rd function valve?
- 3-point trencher
- Drag harrow
- Rototiller
- Some type of lawn aerator
I think that covers it all. Let me know if you have any questions.
   / *UPDATE* Just tell me what to buy! #44
I'm glad you like your purchase.
(perhaps you could 'update' your profile to reflect that you have a CK3510SE HST. 😀 )
   / *UPDATE* Just tell me what to buy! #46
- Forks
- Grapple
- Loader bucket
- Flail Mower
- Disc
- Spring Seat
- Linked Pedal
- Side view mirrors
- 3-point trencher
- Drag harrow
- Rototiller
I bought a USB charger on Amazon for $12 and installed it. But make sure that you connect to a circuit that is only hot when the ignition is on. Otherwise it will drain your battery. For my phone, I bought a small clip case that works well connected to the rops or seat. For fueling, buy a small pump with a hose to attach to your can and forget about lifting and spilling. Or a fuel caddy with a hose. For a toolbox, see my photo.
   / *UPDATE* Just tell me what to buy! #47
I just purchased our family a house on a modest 5 acres. It’s got some hills, some pasture, some trees etc.
The place hasn’t been maintained in a long time so I have been fixing it up on the weekends. I work for a construction company and get almost free heavy equipment on the weekends. I’ve been working for a few months using large equipment. Full size excavators, skip loaders, rollers and backhoes. I’ve cleared a lot of the property, cut in a new driveway, removed trees/stumps and demoed concrete.
I’ve got most of the heavy lifting out of the way and need a maintenance tractor for disking, mowing, grading, tilling, loader work, you know, a little of everything.
Im looking at compact tractors and everyone says they’re perfect for that and can do it all. I just have no idea what to expect as I’ve been using 100+ HP machines and they have struggled at times to move dirt, stumps and concrete.
Should I be looking at a 45-55hp or can a compact 25-35 do it all?
And what’s the consensus on cabs? I’ve used both open and cabbed backhoes, the cab was quite nice.
I figure this will be the only tractor I will have for 15+years.
Just someone tell me what to do.
PS. I’ve been looking at Kioti CK and DK models, Kubota B and L and that’s it so far.
John Deere with no worries, Kubota if need more power, and that's about it, all the rest have logistical or supply issues....
   / *UPDATE* Just tell me what to buy! #48
Thanks for the 3-year update!
Yes, they do make SSQA post hole diggers, but your 3rd function will likely not have enough hydraulic flow or constant duty cycle capability to power one sufficiently. These tend to be made for skid steers with high flow auxiliary hydraulics.
3-pt mounted post hole diggers are a little cumbersome to get hooked up, but they work well. Find a used one for cheap.
   / *UPDATE* Just tell me what to buy! #49
   / *UPDATE* Just tell me what to buy! #50
Land pride makes a low flow SSQA auger that is spec’d to operate off of 6-15 gpm flow. It may or may not meet his needs but there are some videos of one being operated off of a small compact tractor.
   / *UPDATE* Just tell me what to buy! #51
For the drink, try a water bottle like those used for bicycling.
   / *UPDATE* Just tell me what to buy! #52
I know back in 2001 I was looking to upgrade to a new tractor from my JD 850 to a Kioti DK 35.
I had several members on this site back then saying, Kioti wasn't as good, don't hold up, can't get parts, bla. bla
All of it was false.
After 21 years (2415 hours) my Kioti DK has been fantastic tractor. Built every bit as well as my JD was, every bit as reliable, and parts are easy to get.
   / *UPDATE* Just tell me what to buy! #53
Glad to hear that since I bought a DK4510 last year. So far has been a great tractor. (y)
   / *UPDATE* Just tell me what to buy! #54
Those who drink the Koop aid will be saying it for a hundred years!
Yesterday as I wrenched on a locals JD for him, his new neighbor stopped asking about tractors and what to be looking at.
I had a good laugh when he tried taking a cheep shot at everything but his beloved Deere while I was right there fixing his. Knowing full well mine is older and has twice the hours and most likely 3 times the abuse but it ran fine and pulled his deere up and out of the field with no issues.
But in his mind it’s not a deere or kubota so it doesn’t count and next month his break down will become just normal maintenance and he will conviently forget it ever really broke, his wait for parts will shorten from the week or two that was quoted to just a few days with every person he ever talks about tractors to and if he washes and waxes that green paint while drinking his green Kool aide he might just forget that it ever broke at all as it has a strange hypnotizing effect on the average owner. Kind of like when someone wants to believe in a politician, they will find a way to believe the hog wash no matter what the facts say and try thier best to convince the rest of thier like minded kind to believe in them too!
   / *UPDATE* Just tell me what to buy! #55
I haven't tried hydraulic but have had a 3pt PTO post hole drill for many years. They are easy to find used. A hydraulic one would be a great advantage & I would sure try togo that way if I had to have one. Post hole diggers may be great tool for dirt and lots of pasture and fence posts to put in, but here in the mountains they are less useful than I thought it would be. It hardly ever gets used. I always end up using the backhoe and a small bucket. Plus the backhoe gets a lot of work just moving heavy things around.
Bottom line: I'd skip the post hole digger and find a decent hoe. One with a subframe....
And a four post canopy is a nice compromise between open station and cab.
rScotty
   / *UPDATE* Just tell me what to buy! #56
OK, you said “Just tell me” so… After you put in a house, drive and yard around the house you have at most 4.5 acres left. What would you possible do with a 50 HP tractor on 4 acres? A 16hp Kubota BX series with a belly mower will be able mow, maintain a gravel drive and till a big garden.
   / *UPDATE* Just tell me what to buy! #57
I know this controversy is over as far as OP is concerned, but I'll just barge in to say my 24.5 (hee hee, what happens at 25?) Bobcat with fel and forks-and hopefully soon a 3-pt winch, is perfectly sized for what I call my postage stamp-18 acres of woods and plantation. Perfect!
I do snow, small scale logging, firewood junk, haul crushed stone, demolish old buildings and decks, with mine. Admittedly, not trying to drag a large implement thru the dirt. But I've yet to find the limitations of this machine for tasks I've put to it
   / *UPDATE* Just tell me what to buy! #58
6 acres is what I use for my lawn which I mow with my zero turn mower. All of my tractor needs are done with my B26 TLB. I did use my LS P7010 lots of time when I first bought my almost 12 acres, but all my heavy lifting is done, just as you have already done. So my 2010 LS has only 160 hours on it and 120 of them were put on in the first year.
I really think for 5 acres a B series Kubota will do all you need to do. Add a small tiller for garden work, a 4-5 foot bush hog for your small pasture and you should be good to go. Since I got my tiller, I have not hooked up to my tandem disk since.
Yep. I’d much rather mow with my zero turn. I have 52 acres and also mow 6 acres like you with a zero turn. A 33 hp B series has done everything I ever wanted to do including a lot of tree removal, ground work, wood chipping, bush hogging, raking, plowing, box blading, maintaining 1500 feet of gravel drive. I can’t imagine what someone would do on 4 or 5 acres with a 50hp tractor except destroy it. I sure don’t want to get the tractor out every time I mow and tear up the yard.
   / *UPDATE* Just tell me what to buy! #59
I have 5 acres and 39 HP, and 20 hp tractors. Wish I had bigger, can’t unload a full ton pallet with mine. I now mow with a ZTR.
I agree. If I was just maintaining a drive and mowing, then that’s all you need. But Ive truly pushed this tractor to its limit many times. A sub-compact just wouldn’t work for much of what I do. My neighbor(40 acres) has a sub-compact Kubota and he enjoyed it for many years, until I got mine. Now, he just calls me when he needs something done.
2018 FREIGHTLINER M2 26FT BOX TRUCK (A59905)
2018 FREIGHTLINER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
GIYI VB59-59" HYD VIBRATING BUCKET (A60430)
GIYI VB59-59" HYD...
2019 VOLVO A45G FS OFF ROAD DUMP TRUCK (A60429)
2019 VOLVO A45G FS...
2348 (A60432)
2348 (A60432)
