Tool box or the lack of one..
   / Tool box or the lack of one.. #1
Boomerman44
Winston Salem NC
LS R3039
To tool or not to tool ... That is the question.. Wow I had a mid 80's Yanmar that I traded in on a used LS R3039 recently and I could not believe that it really doesn't have a tool box ... I always carried a hammer a good pair of pliers a can of WD-40 and a few spare snap pins for the implements in little Red! a pair of fencing pliers , gloves ect. Now I have to try to figure out what I can do about this little problem! Any Ideas ?
   / Tool box or the lack of one.. #3
we've got another thread going on our XG3035 models. the OP over there did a really nice job adding his, and I copied that today on mine. Painted it with the Rustoleum Safety blue paint. here's mine...
Great job ! I am really liking layin my arm on the fender / cup holder while operating my FEL . But I like your style!
   / Tool box or the lack of one.. #5
Seen many ammo boxes attach behind the seat to ROPS.
   / Tool box or the lack of one.. #6
Gotta have a tool box! Even just a few basic items can mean the difference between continuing operations and a long walk back to the house!
   / Tool box or the lack of one.. #7
my FEL joystick isn't mounted to the fender like some are though, so that's not an option for me anyway.
   / Tool box or the lack of one.. #8
Gonna have to look into something. The 125 comes with something they call a toolbox, but we may disagree on that.
Ok So I have looked around and saw how all of you people have solved the lack of a tool box problem and I decided to make me a tray to mount to my right side step mounting bolts. I am going to attach mine with 3- M8 flat head socket head screws. I got the logo off of the internet and used my vinyl cutter to make the decal to show thru the bracket. I used self adhesive rubber strips to pad the tray to mount the 50 cal. ammo box in. see the pics.IMG-0759.JPGIMG-0760.JPGIMG-0761.JPGIMG-0762.JPGIMG-0763.JPGIMG-0764.JPGIMG-0765.JPG
   / Tool box or the lack of one.. #10
Looks awesome!
   / Tool box or the lack of one.. #11
Nice. I was able to just make a plate to go where the tiny plastic one mounted using the ROPS fasteners on my LS. I like yours much better - being able to remove the ammo can is nice.
Where in W-S are you? I'm in W-S too and Welcome, NC.
   / Tool box or the lack of one.. #12
I have the one on the floorboard that I mentioned in another thread. Then I picked up a plastic ammo type can at RK for $6 that I was able to mount to the shelf for the toybox LS provided. I keep pins and latches in that one and tools in the one on the floorboard.
   / Tool box or the lack of one.. #15
Boomerman 44, have you ever thought of selling a few of the LS logos (you know , for the cost of the paper hint hint)
   / Tool box or the lack of one.. #16
Nice job on the bracket. I mounted mine in the same spot but used “L” brackets to hold the ammo can.
   / Tool box or the lack of one.. #17
So I saw this thread, and the other one, and was thinking 'neat, I'm doing this'. And then realized that while I will be getting one of those metal carports to park under, I'm still in LA and it rains. A lot. Means mud & water splash even when it's 'dry' (just ask my dog - she comes home muddy in a f'ing drought).
So the Cabella's ammo can is water proof, so that's great! But if I put a right side step toolbox too (and I love that idea) how much do I need to worry about water proofing that?
   / Tool box or the lack of one.. #18
   / Tool box or the lack of one.. #19
I used a new 50 cal. ammo box from harbor freight and they seal out all water completely. I own a commercial machine shop so making the bracket was easy. I just used a tape measure to figure out the hole spread that is 100 mm apart or 3.937 inches. I used a few pieces of 2"x2"x1/8" angle and some 1/8" x2" hot roll flat bar. I tig welded them together with bronze rod and tried not to build up a lot of bead. I also used 2 short pieces of 1/8"x1" angle at the front to allow the box to open without removing it. I welded the box frame to a piece of 1/4" x 1-1/2" flat bar that had the 3 countersunk holes in it .I tried to no avail to find the safty blue rustolium paint but Lowes doesn't carry it anymore. I had to go with sail blue enamel. this stuff dries super slow so don't be in a big hurry. I just have to use a couple of zip ties to keep the hoses of the FEL out of the way of the box opening. Wa-LAA toolbox solved... LOL One word of caution ... If you build this same style give yourself a good 1/4" of space side to side and front to back for the ammo can. I only left about 1/8" and she was tight. I had to tweak it a little to make it right.
2021 CATERPILLAR 926M WHEEL LOADER (A60429)
2021 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
2013 VOLVO VNL (A55745)
2013 VOLVO VNL...
TUGGER TRAILER (A55745)
TUGGER TRAILER...
GMC 2500HD 4wd Service Truck (A56438)
GMC 2500HD 4wd...
