Tool box or the lack of one..
   / Tool box or the lack of one.. #1
Boomerman44
Winston Salem NC
LS R3039
To tool or not to tool ... That is the question.. Wow I had a mid 80's Yanmar that I traded in on a used LS R3039 recently and I could not believe that it really doesn't have a tool box ... I always carried a hammer a good pair of pliers a can of WD-40 and a few spare snap pins for the implements in little Red! a pair of fencing pliers , gloves ect. Now I have to try to figure out what I can do about this little problem! Any Ideas ?
   / Tool box or the lack of one.. #3
we've got another thread going on our XG3035 models. the OP over there did a really nice job adding his, and I copied that today on mine. Painted it with the Rustoleum Safety blue paint. here's mine...
Great job ! I am really liking layin my arm on the fender / cup holder while operating my FEL . But I like your style!
   / Tool box or the lack of one.. #5
Seen many ammo boxes attach behind the seat to ROPS.
   / Tool box or the lack of one.. #6
Gotta have a tool box! Even just a few basic items can mean the difference between continuing operations and a long walk back to the house!
   / Tool box or the lack of one.. #7
my FEL joystick isn't mounted to the fender like some are though, so that's not an option for me anyway.
   / Tool box or the lack of one.. #8
Gonna have to look into something. The 125 comes with something they call a toolbox, but we may disagree on that.
Ok So I have looked around and saw how all of you people have solved the lack of a tool box problem and I decided to make me a tray to mount to my right side step mounting bolts. I am going to attach mine with 3- M8 flat head socket head screws. I got the logo off of the internet and used my vinyl cutter to make the decal to show thru the bracket. I used self adhesive rubber strips to pad the tray to mount the 50 cal. ammo box in. see the pics.IMG-0759.JPGIMG-0760.JPGIMG-0761.JPGIMG-0762.JPGIMG-0763.JPGIMG-0764.JPGIMG-0765.JPG
   / Tool box or the lack of one.. #10
Looks awesome!
   / Tool box or the lack of one.. #11
Nice. I was able to just make a plate to go where the tiny plastic one mounted using the ROPS fasteners on my LS. I like yours much better - being able to remove the ammo can is nice.
Where in W-S are you? I'm in W-S too and Welcome, NC.
   / Tool box or the lack of one.. #12
I have the one on the floorboard that I mentioned in another thread. Then I picked up a plastic ammo type can at RK for $6 that I was able to mount to the shelf for the toybox LS provided. I keep pins and latches in that one and tools in the one on the floorboard.
   / Tool box or the lack of one.. #15
Boomerman 44, have you ever thought of selling a few of the LS logos (you know , for the cost of the paper hint hint)
   / Tool box or the lack of one.. #16
Nice job on the bracket. I mounted mine in the same spot but used “L” brackets to hold the ammo can.
   / Tool box or the lack of one.. #17
So I saw this thread, and the other one, and was thinking 'neat, I'm doing this'. And then realized that while I will be getting one of those metal carports to park under, I'm still in LA and it rains. A lot. Means mud & water splash even when it's 'dry' (just ask my dog - she comes home muddy in a f'ing drought).
So the Cabella's ammo can is water proof, so that's great! But if I put a right side step toolbox too (and I love that idea) how much do I need to worry about water proofing that?
   / Tool box or the lack of one.. #18
   / Tool box or the lack of one.. #19
I used a new 50 cal. ammo box from harbor freight and they seal out all water completely. I own a commercial machine shop so making the bracket was easy. I just used a tape measure to figure out the hole spread that is 100 mm apart or 3.937 inches. I used a few pieces of 2"x2"x1/8" angle and some 1/8" x2" hot roll flat bar. I tig welded them together with bronze rod and tried not to build up a lot of bead. I also used 2 short pieces of 1/8"x1" angle at the front to allow the box to open without removing it. I welded the box frame to a piece of 1/4" x 1-1/2" flat bar that had the 3 countersunk holes in it .I tried to no avail to find the safty blue rustolium paint but Lowes doesn't carry it anymore. I had to go with sail blue enamel. this stuff dries super slow so don't be in a big hurry. I just have to use a couple of zip ties to keep the hoses of the FEL out of the way of the box opening. Wa-LAA toolbox solved... LOL One word of caution ... If you build this same style give yourself a good 1/4" of space side to side and front to back for the ammo can. I only left about 1/8" and she was tight. I had to tweak it a little to make it right.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
1985 Ford Ltl9000 Tender Truck (A56438)
1985 Ford Ltl9000...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2018 GENIE...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
