Tool box or the lack of one..
   / Tool box or the lack of one.. #11
Nice. I was able to just make a plate to go where the tiny plastic one mounted using the ROPS fasteners on my LS. I like yours much better - being able to remove the ammo can is nice.
Where in W-S are you? I'm in W-S too and Welcome, NC.
   / Tool box or the lack of one.. #12
I have the one on the floorboard that I mentioned in another thread. Then I picked up a plastic ammo type can at RK for $6 that I was able to mount to the shelf for the toybox LS provided. I keep pins and latches in that one and tools in the one on the floorboard.
   / Tool box or the lack of one.. #15
Boomerman 44, have you ever thought of selling a few of the LS logos (you know , for the cost of the paper hint hint)
   / Tool box or the lack of one.. #16
Nice job on the bracket. I mounted mine in the same spot but used “L” brackets to hold the ammo can.
   / Tool box or the lack of one.. #17
So I saw this thread, and the other one, and was thinking 'neat, I'm doing this'. And then realized that while I will be getting one of those metal carports to park under, I'm still in LA and it rains. A lot. Means mud & water splash even when it's 'dry' (just ask my dog - she comes home muddy in a f'ing drought).
So the Cabella's ammo can is water proof, so that's great! But if I put a right side step toolbox too (and I love that idea) how much do I need to worry about water proofing that?
   / Tool box or the lack of one.. #18
   / Tool box or the lack of one.. #19
I used a new 50 cal. ammo box from harbor freight and they seal out all water completely. I own a commercial machine shop so making the bracket was easy. I just used a tape measure to figure out the hole spread that is 100 mm apart or 3.937 inches. I used a few pieces of 2"x2"x1/8" angle and some 1/8" x2" hot roll flat bar. I tig welded them together with bronze rod and tried not to build up a lot of bead. I also used 2 short pieces of 1/8"x1" angle at the front to allow the box to open without removing it. I welded the box frame to a piece of 1/4" x 1-1/2" flat bar that had the 3 countersunk holes in it .I tried to no avail to find the safty blue rustolium paint but Lowes doesn't carry it anymore. I had to go with sail blue enamel. this stuff dries super slow so don't be in a big hurry. I just have to use a couple of zip ties to keep the hoses of the FEL out of the way of the box opening. Wa-LAA toolbox solved... LOL One word of caution ... If you build this same style give yourself a good 1/4" of space side to side and front to back for the ammo can. I only left about 1/8" and she was tight. I had to tweak it a little to make it right.
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
1998 PETERBILT 377 MIDROOF SLEEPER (A58214)
1998 PETERBILT 377...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2004 TAKEUCHI TL140 SKID STEER (A60429)
2004 TAKEUCHI...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2021 KENWORTH T680...
