Best non-implement accessories for tractor?
/ Best non-implement accessories for tractor? #1
Tymanthius
Baton Rouge, LA
LS XG3135
Hiya! I've got a grant from RestoreLA coming and I've done my shopping/research, and I figure the LS XG3135 w/ FEL and backhoe is probably my best bet. I'm going to add a bolt on grapple as well and see if I can pick up some forks. Already have a box and 4 & 5 ft rotary cutters, plus a cpl other items.
But I'm curious what the best accessories are to add. I think I'm going to go w/ the Pat's Quick Connect system b/c my implements are hodge podge, and thinking maybe adding a Tractor Caddy (or having a friend weld one up).
Hooks on the buckets, of course, and I've been looking at the tool box mods. :)
Chains . . . anything else?
/ Best non-implement accessories for tractor? #2
Auxiliary hydraulics are far and away the most time and labor saving add on component for any size utility tractor...the more the better...!
/ Best non-implement accessories for tractor? #3
Hooks on the FEL bucket, and a piranha bar, are probably my favorites so far.
Chain saw holder.
Something I'm still missing is a tool box for mine, big enough to hold chains, wrench for where my lower arms attach (they have to come off to swap my backhoe on... I have thoughts of using clip pins here but haven't done anything about that yet either), a rag, gloves, who knows what else...
/ Best non-implement accessories for tractor? #4
One big, clean, dry roll of paper towels. Good for cleaning up all sorts of situations. Especially when I'm out - half mile from the house.
/ Best non-implement accessories for tractor? #5
:thumbsup:
I'll have at least 2 ports (for driving the backhoe) and am thinking of adding 2 more. Plus I want a front grapple, so that should at least have a diverter(?).
/ Best non-implement accessories for tractor? #8
For me it's a fire extinguisher. I want to at least have a fighting chance to save my tractor if it decides to light up.
/ Best non-implement accessories for tractor? #9
That's a tough one! For me, right now since the days are getting shorter, I am looking at better lights
/ Best non-implement accessories for tractor? #10
Backhoe thumb is a great addition ....
/ Best non-implement accessories for tractor? #11
I love my ratchet rake. The way it built give you a spot for a clevis on top or bottom
/ Best non-implement accessories for tractor? #12
Someone here awhile back suggested a magnetic strip on back to hold lynch pins and the like while changing implements.
/ Best non-implement accessories for tractor? #13
That's not a bad idea at all! I typically put the pins on the implement or something, they fall in the mud/snow/weeds/etc. A little mag strip would solve that issue! That's going to happen!
I like that! I have one for my knives in the kitchen, so I know how strong they are.
/ Best non-implement accessories for tractor? #15
mine has a place on the lift arms to stick them, a little piece of tube welded on. I even did that to my old ford, welded on some tube to just stick them into.....
/ Best non-implement accessories for tractor? #16
Not sure what you mean by "bolt on" grapple.
But since you want a bucket, grapple, AND forks....to me a SSQA is a must
/ Best non-implement accessories for tractor? #17
Buy the best seat you can afford.
Nothing but air ride for me at this point.
Google Titan's Bolt on Grapple. It's just a grapple that bolts to your existing bucket instead being a hot swap item.
Also, the tractor comes with skid steer quick attach. I thought that was standard on all LS's?
/ Best non-implement accessories for tractor? #19
I like that, papacahz. I was thinking about mounting a metal plate back there with a few holes to stick them through while they're out, until I read the magnet idea.
There's so much resourcefulness on this forum, it's almost scary.
/ Best non-implement accessories for tractor? #20
Just googled.
For the price, and also wanting forks....just get a ssqa, and actual grapple, and actual forks.
IH Farmall B Tractor (A66285)
IH Farmall B...
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
2017 Ford F-150 Pickup Truck (A64556)
2017 Ford F-150...
Denyo DCA-600SPK 500kW Sound-Attenuated Diesel Generator (Trailer NOT included) (A63689)
Denyo DCA-600SPK...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
2018 Case 580N EP 4x4 Loader Backhoe (A64553)
2018 Case 580N EP...
