Best non-implement accessories for tractor?
/ Best non-implement accessories for tractor? #1
Tymanthius
Baton Rouge, LA
LS XG3135
Hiya! I've got a grant from RestoreLA coming and I've done my shopping/research, and I figure the LS XG3135 w/ FEL and backhoe is probably my best bet. I'm going to add a bolt on grapple as well and see if I can pick up some forks. Already have a box and 4 & 5 ft rotary cutters, plus a cpl other items.
But I'm curious what the best accessories are to add. I think I'm going to go w/ the Pat's Quick Connect system b/c my implements are hodge podge, and thinking maybe adding a Tractor Caddy (or having a friend weld one up).
Hooks on the buckets, of course, and I've been looking at the tool box mods. :)
Chains . . . anything else?
/ Best non-implement accessories for tractor? #2
Auxiliary hydraulics are far and away the most time and labor saving add on component for any size utility tractor...the more the better...!
/ Best non-implement accessories for tractor? #3
Hooks on the FEL bucket, and a piranha bar, are probably my favorites so far.
Chain saw holder.
Something I'm still missing is a tool box for mine, big enough to hold chains, wrench for where my lower arms attach (they have to come off to swap my backhoe on... I have thoughts of using clip pins here but haven't done anything about that yet either), a rag, gloves, who knows what else...
/ Best non-implement accessories for tractor? #4
One big, clean, dry roll of paper towels. Good for cleaning up all sorts of situations. Especially when I'm out - half mile from the house.
/ Best non-implement accessories for tractor? #5
:thumbsup:
I'll have at least 2 ports (for driving the backhoe) and am thinking of adding 2 more. Plus I want a front grapple, so that should at least have a diverter(?).
/ Best non-implement accessories for tractor? #8
For me it's a fire extinguisher. I want to at least have a fighting chance to save my tractor if it decides to light up.
/ Best non-implement accessories for tractor? #9
That's a tough one! For me, right now since the days are getting shorter, I am looking at better lights
/ Best non-implement accessories for tractor? #10
Backhoe thumb is a great addition ....
/ Best non-implement accessories for tractor? #11
I love my ratchet rake. The way it built give you a spot for a clevis on top or bottom
/ Best non-implement accessories for tractor? #12
Someone here awhile back suggested a magnetic strip on back to hold lynch pins and the like while changing implements.
/ Best non-implement accessories for tractor? #13
That's not a bad idea at all! I typically put the pins on the implement or something, they fall in the mud/snow/weeds/etc. A little mag strip would solve that issue! That's going to happen!
I like that! I have one for my knives in the kitchen, so I know how strong they are.
/ Best non-implement accessories for tractor? #15
mine has a place on the lift arms to stick them, a little piece of tube welded on. I even did that to my old ford, welded on some tube to just stick them into.....
/ Best non-implement accessories for tractor? #16
Not sure what you mean by "bolt on" grapple.
But since you want a bucket, grapple, AND forks....to me a SSQA is a must
/ Best non-implement accessories for tractor? #17
Buy the best seat you can afford.
Nothing but air ride for me at this point.
Google Titan's Bolt on Grapple. It's just a grapple that bolts to your existing bucket instead being a hot swap item.
Also, the tractor comes with skid steer quick attach. I thought that was standard on all LS's?
/ Best non-implement accessories for tractor? #19
I like that, papacahz. I was thinking about mounting a metal plate back there with a few holes to stick them through while they're out, until I read the magnet idea.
There's so much resourcefulness on this forum, it's almost scary.
/ Best non-implement accessories for tractor? #20
Just googled.
For the price, and also wanting forks....just get a ssqa, and actual grapple, and actual forks.
2019 ISUZU NPR 4X2 S/A 20FT BOX TRUCK (A59914)
2019 ISUZU NPR 4X2...
2022 EZ-GO ELITE...
2014 Ford Explorer (A62613)
2014 Ford Explorer...
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
(16) Kinze 60 Cell Bean Plates (A65640)
(16) Kinze 60 Cell...
2015 ABU TRAILER 14 FOOT UTILITY TRAILER (A65643)
2015 ABU TRAILER...
